How do I know if my truck is a ZR2? - S-10 Forum
post #1 of 13 Old 10-22-2007, 12:13 AM Thread Starter
User is: Ajax Bongo is offline
I bought it 2nd hand. The original owner completely customized his factory options at purchase and it has no stickers or anything advertising the version. I know it is a push button 4x4 with a huge skid plate in the front.
What are the tell-tale signs of an S-10 being ZR2?
post #2 of 13 Old 10-22-2007, 12:16 AM
User is: DuronClocker is offline
Send a message via AIM to DuronClocker
Re: How do I know if my truck is a ZR2?
It would have a "ZR2" RPO code. RPO code listings are usually found in the glove box on these trucks I believe (at least that's where mine is). Other common spots would be in the center console or the edge of the driver's side door.
'00 Jimmy 2-door 4x4/auto (pewter), 1" T-bar crank, 1/2" from leaf helper (shackles for another inch soon), 2" body lift, 255/70R16 GrabberAT2's on GTA wheels, some black accents
'98 Camaro Z28 LS1/6spd (navy blue), H/C/I, 3.89s/TrueTrac 9", full road race suspension, minor appearance stuff
[email protected] without the NX
post #3 of 13 Old 10-22-2007, 12:29 AM
Definite Obsessions
Madkaw_16's Avatar
User is: Madkaw_16 is offline
Send a message via MSN to Madkaw_16
Fender flares, 2'' body lift, bilstein shocks, 31x10.5x15's. I have a zr2, and my brother has a 4wd dime, skidplates were optional on 4wd without zr2 package.
camberedvideos.com
rockered on 22's build thread
https://www.s10forum.com/forum/f143/c...-build-430463/
post #4 of 13 Old 10-22-2007, 01:09 AM
My non-ZR2 also came with Bilsteins from the factory. The sticker on the door should also say the tire size is a 31" tire as mentioned above.
I though that ZR2's got a 3" suspension lift, not a 2" body lift. They front and rear track widths are also 4" wider than a non-ZR2. Fender flares could be added after the fact.
The only way for you to tell if you can't tell the frames apart (I'm assuming you don't know the differences) is to check the RPO codes for the ZR2 code, or to check the door tire tag for what size tires the truck came with.
Most 4x4 trucks came with a 235/70R15, and I believe 235/75R15 was also an option. The ZR2's came with a 31" tire that would probably be designated "31x9.5-15" or something along those lines.
post #5 of 13 Old 10-22-2007, 01:29 AM
Definite Obsessions
Madkaw_16's Avatar
Huh?, now i'm gonna have to check. I very well could be wrong, i'll look tomorrow, i still have my window sticker. it's a '00 LOL
camberedvideos.com
post #6 of 13 Old 10-22-2007, 05:07 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
lol, also if you look at the tire jack it has ZR2 stamped on it, at least mine does.
post #7 of 13 Old 10-22-2007, 09:16 AM
ZR2
Jigg's Avatar
User is: Jigg is offline
ZR2's do not have a 2" BL. The suspension itself is 2" higher (well, the mounting points are 2" lower, which lifts the truck 2"). The tires are 2" taller, which nets another 1" in height, for a total of 3" over stock.
The ZR2's came with 31x10.5/15's.
http://en.wikipedia.org/wiki/RPO_ZR2
Post a picture. I'll tell you for sure if it is or not
Jigg is offline
post #8 of 13 Old 10-22-2007, 07:14 PM
Wow, that's some good information on Wiki there.
post #9 of 13 Old 10-23-2007, 12:46 PM
User is: shortee611 is offline
ZR2 fender flares wont fit on a non ZR2 without major moding. There is a lip welded around the wheel well for the flare to mount to and also bolt holes going through the body. Take one off and you'll know what i mean. Plus they are expensive as all hell to replace. ( i smashed one)
post #10 of 13 Old 10-26-2007, 02:23 AM Thread Starter
No, turns out it is not a Zr2, it's just the 4x4.
That doesn't mean I can't have some fun with it though
Edit: I am going to look into some off-road style tires for it and maybe a suspension lift later on.
post #11 of 13 Old 10-26-2007, 08:13 AM
cdnuser's Avatar
User is: cdnuser is offline
The Zr2 is neither a body or suspension lift. There are differnent suspension mounting points on the zr2 that are different than the reg 4wd (which increases the width and height). The Zr2 also has a wider rear axle.
"Where do they teach you to talk like this? In some Panama City "Sailor wanna hump-hump" bar, or is it getaway day and your last shot at his whiskey? Sell crazy someplace else, we're all stocked up here". -As Good as it Gets
cdnuser is offline
post #12 of 13 Old 10-26-2007, 07:29 PM
no longer has a 95
95 S_Trucker's Avatar
User is: 95 S_Trucker is offline
Send a message via AIM to 95 S_Trucker
yea, they look wierd.
99 Blazer 2 Door, 4wd, NV3500, 8.5
99 K2500 LS CCSB 7.4, 4L80E
post #13 of 13 Old 10-26-2007, 08:25 PM
Registered dumbass
NC4x4's Avatar
User is: NC4x4 is offline
Send a message via AIM to NC4x4
[walmart employee voice]You'll know cause it has one of them BA stickers on the side.[/walmart employee voice]
97 Pickup
NC4x4 is offline
You may post new threads
You may post replies
