'03 s10 SAS Toyota Front Springs - S-10 Forum
post #1 of 5 Old 01-08-2019, 08:47 PM Thread Starter
Engineer
HkB115's Avatar
User is: HkB115 is offline
So I've had a some d44's swapped in for a few years now and am running 37s. Because of where my hangers are, I'm running some suburban leaf springs up front. Now, they are working fantastic and all, but I had to put a fairly large relocation plate on them to fit my 37s in there, and I don't like the look of them anymore. The pin location on a set of rear 1989-1994 Toyota pickup leaf springs fits what I need perfectly, but I have no idea if they will support the weight of my truck or not. My other option is running a set of 1986-1996 Dodge dakota springs up there, which would give me a very nice shackle angle and should support the weight of my front+winch bumper, but the pin location is pushing it on where my tires might rub the fender when they get crammed. So the question is if anyone is running Toyota springs up front?
Truck is in the shop right now so I'm limited on the pictures.
2003 Chevy S10 LS Crew Cab "Big Red" https://i.imgur.com/FfTX2m2.jpg
GM 4.3L V6 Vortec (working towards 350 small block)
DANA 44 5.13 front & rear w/ lockers
Bumpers by Blue Lake Offroad/WAM Bumpers
Custom built rock bars & roof rack
HkB115 is offline
post #2 of 5 Old 01-09-2019, 03:08 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: '03 s10 SAS Toyota Front Springs
I don't have any answers but I'm going to move this to the SAS swap section with a reroute here in the suspension section. This way hopefully it'll have a better chance of getting the attention of someone that can help.
TelAmeriCorp
post #3 of 5 Old 01-10-2019, 08:43 AM
User is: _stucky is offline
Iím not sure as to if they will hold up to the weight of the truck. But on mine, I had a pair of main leaves built to put my axle right where I wanted it. Bolted to the rest of wagoneer spring packs.
Something else you could try, if the center pins are the same size, swap the main leaves onto your existing pack and see how it is. Sometimes you have to experiment a little.
Hereís the shop that built my leaves:
http://www.saintlouisspring.com
Let us know how it goes.
_stucky is offline
post #4 of 5 Old 01-14-2019, 03:55 PM
terry10's Avatar
User is: terry10 is offline
https://www.s10forum.com/forum/f221/...56/index3.html
not sure if it helps much but fairly certain he has yota rear springs of some sort on the front if this blazer
99 zr2 solid axle swap in progress
2006 Chevy Cobalt work car 368k and counting
2015 Chevy Equinox awd
terry10 is offline
post #5 of 5 Old 03-17-2019, 11:56 AM Thread Starter
Engineer
HkB115's Avatar
Sorry for resurrecting this, it's been a long and ****** winter here in Nebraska. I've decided I'm going to be going with the Toyota leaf springs with some add-a-leafs. This should be enough to keep it arched a little and not be completely flat. Looking to get a little bit of lift here, maybe about 2 inches, otherwise I'll just fab up some longer shackles.
Springs: https://www.sdtrucksprings.com/index...oducts_id=7504
Add-a-leafs: https://www.sdtrucksprings.com/index...ducts_id=31381
HkB115 is offline
