Shock extenders (front) - S-10 Forum
post #1 of 9 Old 03-20-2019, 01:07 PM Thread Starter
frankkom's Avatar
User is: frankkom is offline
Hello. I would like to know if there is a need to “extend” the shock absorbers or to change standard length for extended length shock absorbers when doing a coil spring lift via 1” spring spacers. Thanks.
frankkom is offline
post #2 of 9 Old 03-22-2019, 02:31 PM Thread Starter
frankkom's Avatar
Any?
frankkom is offline
post #3 of 9 Old 03-23-2019, 01:03 AM
89-S-Dime's Avatar
User is: 89-S-Dime is offline
Re: Shock extenders (front)
spring spacers? your talking about the ones being sold on EBay?
post #4 of 9 Old 03-23-2019, 11:27 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
It will still have same droop length as stock shock. You will hit bump stop before shock bottoms out.
I'd recommend getting actual lift spring if you can afford it. Otherwise save the money until you can afford it.
And the money for alignment after that.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #5 of 9 Old 03-23-2019, 01:08 PM Thread Starter
frankkom's Avatar
Yes. Those.
frankkom is offline
post #6 of 9 Old 03-23-2019, 01:15 PM Thread Starter
frankkom's Avatar
It is not the same high adding 1" coil spacers than switch to a 1" taller coil spring?
frankkom is offline
post #7 of 9 Old 03-23-2019, 04:32 PM Thread Starter
frankkom's Avatar
...You will hit bump stop before shock bottoms out.
Where are those bump stops located at? I can’t find them on my truck. May be my truck doesn’t have it? (May someone removed it before?)
frankkom is offline
post #8 of 9 Old 03-23-2019, 05:05 PM Thread Starter
frankkom's Avatar
Ok. I found them on a youtube video. Here a couple of screenshots:
ID:	315513   Click image for larger version
frankkom is offline
post #9 of 9 Old 03-25-2019, 05:49 PM
89-S-Dime's Avatar
You know if it was me, I wouldn’t even waste my time with those spring spacers, don’t even know anybody using those on S10’s they seem to of popped up on eBay over the last couple years, And they’re being sold by individuals and companies who are not really into lifting vehicles. Since you’ll be taking out the coils to put those spring spacers in anyway why not just get a pair of Moog springs instead, if you have a V-6 in your S10 a pair of Moog 5664s or if you have a four-cylinder in your S10 a pair of Moog 5662s they will lift your vehicle between one and 1 1/4 inch after the spring settles, I’ve been using these springs for close to 20 years to lift S10’s and they work great
Similar Threads
2003 S10 ZR5, 4.3, front actuator issues and MPG question uclj 262ci Forum (4.3) 7 01-03-2019 08:31 PM
Front airing up Lownoma1234 Baggin' It 3 12-17-2018 08:56 AM
T-case not engaging front driveshaft? Zr2host 262ci Forum (4.3) 4 12-03-2018 08:16 PM
Got a problem with front shock MetalMilitia92 Steering & General Suspension 9 04-25-2018 02:44 PM
Has anyone ever added a real, steel front bumper to a 2000 Sonoma ibbuckshot S10 / Sonoma 2 01-08-2018 09:00 PM
