What all do I need to do in HPtuners for the engine to start? - S-10 Forum
post #1 of 3 Old 04-23-2019, 10:55 PM Thread Starter
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
Obviously I need to turn off VAT’s, but what else do I need to change in HPTuners to get it to run properly and not show any false DTC’s? What does everyone set their e-fans to come on/off at?
post #2 of 3 Old 04-24-2019, 03:13 PM
LS3 Cruisin'
98Sonosls's Avatar
User is: 98Sonosls is offline
Re: What all do I need to do in HPtuners for the engine to start?
Low, ~202F, high ~218 IIRC. Most of the year here it finds equilibrium around 208-209 on its own so my hi's don't usually come on unless I am sitting in traffic on a hot day.
The temp you want to run at depends partly on your cam, fuel, and timing. Your tune should be calibrated for the temp you intend to run at.
There's ton's of debate about temps though, some guys run in the 220's all the time, others stay under 200... LS are known to like it on the warmer side compared to SBC.
As for DTC's, disable and set to not report, whatever you didn't do? IE EVAP, EGR, o2's namely. But there's other odd things in there related more to the LS's found in Caddy's, such as oil level sensors, which you'll want to have off since you probably don't have an oil level sensor. Just go through the list and turn off what you don't want.
post #3 of 3 Old 04-24-2019, 11:38 PM
oldeerslayer's Avatar
Just the post cat O2, you'll want the others to continue operating.
Similar Threads
Please! 2000 S-10 2.2L, will not start when cold. sertek54 2.2L - 2nd gen 4-banging 3 02-08-2019 10:10 PM
Engine stutters at high RPM doesn't want to start on first crank sometimes TranceAmerica 2.2L - 2nd gen 4-banging 7 05-28-2018 01:20 AM
Engine Swap ready to start need help Kopboy55 262ci Forum (4.3) 1 05-25-2018 12:49 AM
Engine won’t start NateChevy Electrical / Lighting 3 04-21-2018 09:28 PM
93 S10 Blazer engine won't start. Jason1704 262ci Forum (4.3) 2 05-02-2016 08:17 PM
