No A/C compressor ground relay signal - S-10 Forum
post #1 of 13 Old 04-05-2019, 07:13 PM Thread Starter
LT1coupe's Avatar
User is: LT1coupe is online now
Current performance harness & I'm not getting a ground signal to energize the A/C compressor clutch relay. The electric fan comes on with the AC switch. I can jump the relay & the compressor runs fine.
I have the low pressure switch jumpered & have verified the ground.
I'm thinking the computer is not sending the ground signal. Idea's?
2001 S10 Extended Cab
LQ9, T56, Explorer 3.73, Camaro Disc, Hydroboost
post #2 of 13 Old 04-05-2019, 11:37 PM Thread Starter
LT1coupe's Avatar
Re: No A/C compressor ground relay signal
I have verified the power to the computer from the AC switch & the ground signal from the low pressure switch.
So I've either got a computer issue or a programming issue. I have an HP Tuner
post #3 of 13 Old 04-06-2019, 08:55 PM Thread Starter
LT1coupe's Avatar
I checked and changed the programming to no avail. So I took the power input from the AC control & the ground signal from the low pressure switch to activate a relay & sent the ground signal through the original wiring to the stock relay.
I have AC!
post #4 of 13 Old 04-10-2019, 11:25 AM
LS3 Cruisin'
98Sonosls's Avatar
User is: 98Sonosls is offline
Are you using a red/blue or blue/green PCM. The 059 Blue/Green's won't work on a low pressure switch and won't send an a/c request signal. A variable high pressure transducer is required on the high pressure side for the computer to control fans correctly. The a/c request gets wired through the low pressure before the PCM just as a failsafe.
The Red/Blue 0411's work fine and you'd just need to check all the pins in terms of ensuring request, and signals are coming in and out on the correct pins.
post #5 of 13 Old 04-10-2019, 03:01 PM Thread Starter
LT1coupe's Avatar
Thanks, it has a red and blue connectors. I have verified the blue 12v input from the body module & the green ground signal from the low pressure sensor.
I'm getting a P0480 & a P0530 code.
My bypass with an additional relay did make the AC function, but now I have a relay ticking like a clock when it calling for the fan because of temperature, not because of the AC load. It does it now even with my extra relay unplugged. I may have f'd up.
I'm assuming the 480 code for the fan is the primary culprit & but don't understand the secondary code "refrigerant pressure sensor A circuit"
I don't know if that is a tuning selection or?
post #6 of 13 Old 04-10-2019, 03:33 PM Thread Starter
LT1coupe's Avatar
This is what I have programmed currently
post #7 of 13 Old 04-13-2019, 07:49 PM Thread Starter
LT1coupe's Avatar
Ok, replaced the PCM with the same year, same part number but this one has a slightly different operating system & would not accept my tune file. I had to change all the parameters manually. Now the AC works as it's supposed to & no more solenoid clicking, BUT the fan that comes on with the AC, now runs anytime the engine is running!
It has to be a programming issue, but I haven't found it so far. Anyone have an idea what I did wrong?
post #8 of 13 Old 04-18-2019, 08:57 AM
jayyk31's Avatar
User is: jayyk31 is offline
What tune and operating system are you running???
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #9 of 13 Old 04-18-2019, 11:07 PM Thread Starter
LT1coupe's Avatar
To be honest I'm not sure how to answer that. I tuned it with HP tuners both computera say the were PO1, both # 09354896 & this one says CYCB the original I don't know.
post #10 of 13 Old 04-23-2019, 02:20 PM
LS3 Cruisin'
98Sonosls's Avatar
You have the wrong PCM, that's your issue.
You have a #09354896, while it is a P01 512kb LS1B PCM, it is specific to the vette, camaro, and Silverado. The vehicles it was used in utilized a high-pressure 5v transducer on the high side for hi/low speed fan control where electric fans were used and engine crank fan clutch control. The PCM you have is not a true 0411, it actually isn't an 0411 at all.
You need a #12200411, colloquially "an 0411" this has the proper support for analogue cycling with low pressure switch & AC request signal, and its OS will not look for a high pressure signal, It also won't control the hi/low speed fans on high pressure tables like the #09354896 will.
The #0411 is common to the S10's from 00-04' (ergo why it directly supports S10 ac systems...). The 0411 happens to be cross compatible with both types of A/C setup and can be made to work with either. This, along with multi x crank support, is part of the "versatility" that makes the 0411 the typical choice for most swaps.
post #11 of 13 Old 04-25-2019, 09:58 PM Thread Starter
LT1coupe's Avatar
Thank you,
I have one coming, the original computer came with the used CP harness I bought & was supposedly originally programed by them.
I knew something was up when I could not load my tune into the replacement.
post #12 of 13 Old 04-27-2019, 10:03 PM Thread Starter
LT1coupe's Avatar
That was it, my original tune file loaded & the AC and fans work like they should.
Thanks!
post #13 of 13 Old 04-30-2019, 09:01 PM Thread Starter
LT1coupe's Avatar
Spoke too soon. The 1st time I drove it & it got up to fan temp the ticking returned. The computer is switching the fan relay in & out like a clock ticking, just like the other one did....It's also not engaging the compressor...
Similar Threads
95 chevy s10 blower relay and clutch control relay burning up greasemonkeys10 Heating and Air Conditioning 9 09-03-2018 09:58 AM
Confused on A/C 98Sonosls LSx Discussion 12 07-29-2018 10:59 PM
How to test A/C pressure sensor hoserj99 Heating and Air Conditioning 14 11-04-2016 04:24 PM
2000 S10 No Start, No Fuel Pump Prime Signal stonecutter 262ci Forum (4.3) 14 10-19-2016 08:43 PM
A/C with engine swap strykersd Heating and Air Conditioning 0 07-13-2016 06:55 PM
