Hummer oil pan pn numbers - S-10 Forum
 1Likes
  • 1 Post By 98Sonosls
post #1 of 36 Old 05-10-2019, 06:07 AM Thread Starter
EZA
User is: EZA is offline
Checking the LS oil pan sticky and it list two different numbers for the Hummer oil pan. One number beside Hummer 3 and one below where it says oil pan: Does anyone have the proper number for the pan for the 2wd S10 swap? Also I read that some had to or chose to notch with this pan, anyone not notching what motor mounts did you use?
EZA is offline
post #2 of 36 Old 05-10-2019, 06:20 AM
Jaboc33's Avatar
User is: Jaboc33 is offline
Re: Hummer oil pan pn numbers
I got my headers, engine mounts, and oil pan from current performance when I ordered my harness as a package. They fit great.
I canít say what the pan number is but they sell it with everything you need
Sent from my iPhone using Tapatalk
1999 s-10 xtreme zq8 with 1999 ls1 t-56
Jaboc33 is offline
post #3 of 36 Old 05-10-2019, 06:38 AM Thread Starter
EZA
Current Performance list the 19212593 calling it the muscle car pan and same as the Hummer. Also that it fits without notching...thanks for clearing that up.
EZA is offline
post #4 of 36 Old 05-10-2019, 07:05 AM
Jaboc33's Avatar
Also, the pan does not hang as low as some claim it does. Iíll try to take a picture when I get home tonight
Jaboc33 is offline
post #5 of 36 Old 05-10-2019, 12:27 PM Thread Starter
EZA
Thanks, is your truck dropped...how much?
EZA is offline
post #6 of 36 Old 05-10-2019, 12:41 PM
Jaboc33's Avatar
Stock zq8 height. So maybe +/- 2Ē?
Jaboc33 is offline
post #7 of 36 Old 05-10-2019, 12:49 PM
B4U Task Force
Rhotpursuit's Avatar
Stock ZQ8 is 1.5 plus another .5 for tires. If taller or shorter tires are used, the drop is different.
Apple Red 96 SS
post #8 of 36 Old 05-10-2019, 01:05 PM
Jaboc33's Avatar
Yes thatís true. I should have specified that lol. 245/50/16
Jaboc33 is offline
post #9 of 36 Old 05-10-2019, 01:15 PM
Jaboc33's Avatar
Jaboc33 is offline
post #10 of 36 Old 05-10-2019, 01:21 PM
B4U Task Force
Double tap...lol
Apple Red 96 SS
post #11 of 36 Old 05-10-2019, 01:25 PM
B4U Task Force
Yes that’s true. I should have specified that lol. 245/50/16
Without looking it up, I have no idea if those are shorter or taller...One thing to consider when going to a wider tire, is the possibility of a big brake upgrade or drop spindles or both. The big brake upgrade (LS1) will push your tire to the outside by the width of the rotor mounting face, along with drop spindles, you my have some interference with the fender edge.
I would hope that with the added power, added braking would be in your future.
Apple Red 96 SS
post #12 of 36 Old 05-10-2019, 02:32 PM
Jaboc33's Avatar
Jaboc33 is offline
post #13 of 36 Old 05-10-2019, 02:39 PM
Jaboc33's Avatar
I drove around for a summer on stock brakes and it was terrifying
Jaboc33 is offline
post #14 of 36 Old 05-10-2019, 03:07 PM Thread Starter
EZA
I have some 2" drop spindles, 1" coils and 3" drop leaf springs...3"X 3" drop. Starting off with 245/50/16's on ZQ8 wheels because I have them. I do have the LS1 brakes that I plan to add and the rear is an 8.5 with full-size disc. Florida does have excellent paved roads, think there would be clearance problems with this combo?
EZA is offline
post #15 of 36 Old 05-10-2019, 03:14 PM
B4U Task Force
What are the specs on the tires?...width, height...Stock ZQ8 tires are 26.1" tall. You need to get in there and take some measurements. Are your Zeeks going g to clear the full size discs/calipers out back??
Apple Red 96 SS
post #16 of 36 Old 05-10-2019, 04:09 PM Thread Starter
EZA
Tire chart lists them at 25.65 height 9.65 width. By full-size disc, I meant whatever came on the S10 8.5/6. The ZQ's with 245/50/16's are on the rear now and apparently no problem. I will give them a good visual when I roll it back into the garage.
EZA is offline
post #17 of 36 Old 05-14-2019, 11:35 AM
User is: Dragonmedic67 is offline
Maybe the country roads up by you are excellent. Down here in Tampa Bay area its crap rodas, construction or speed bumps/tables that hate anything lowered.
post #18 of 36 Old 05-14-2019, 01:31 PM
LS3 Cruisin'
98Sonosls's Avatar
User is: 98Sonosls is offline
Not a big fan of it hanging that far below... I'd probably have welded a short piece of angle iron to the bottom of the trans member, setup like a V to at least deflect anything, or reduce the force the pan would see from something hitting it.
Although the added oil capacity and ease of access to the drain plug is certainly nice.
Harley likes this.
post #19 of 36 Old 05-14-2019, 01:33 PM
LS3 Cruisin'
98Sonosls's Avatar
Depends, do you run xtreme valences? If not then you're fine. If so then expect the next speed table or speed bump to do some body-work to your valences... Underside of mine is fairly beat up...
post #20 of 36 Old 05-14-2019, 02:47 PM
Jaboc33's Avatar
why my truck is, and will remain stock height.
Jaboc33 is offline
post #21 of 36 Old 05-14-2019, 04:00 PM Thread Starter
EZA
Yeah, the "country" roads up here are great as were the roads in West Palm when I lived there. At this time the body and suspension is stock. I plan to get my drive train installed and see how she sits before doing mods. I can always sell the drop stuff if I decide not to use it, it came off the truck in which I had installed a sbc.
EZA is offline
post #22 of 36 Old 05-18-2019, 08:48 PM
User is: dime-dozen is offline
is it me or does that left rotor look like is glowing red hot?
post #23 of 36 Old 05-18-2019, 08:51 PM
I would for sure install a mini skid plate on the front crossmember to save that oil pan and possibly that motor
post #24 of 36 Old 05-18-2019, 10:05 PM
B4U Task Force
Only if the rotor is on the outside of the wheel...
Apple Red 96 SS
post #25 of 36 Old 05-18-2019, 10:50 PM
well then what is it thats glowing red hot?
post #26 of 36 Old 05-18-2019, 11:15 PM
Jaboc33's Avatar
A stop sign
Jaboc33 is offline
post #27 of 36 Old 05-19-2019, 01:05 AM
AvsDime's Avatar
User is: AvsDime is offline
If it hangs down to far for your liking, Holley makes one that is shorter. But, it is far from cheap.
AvsDime is offline
post #28 of 36 Old 05-19-2019, 11:17 PM
Randy
Tranzman's Avatar
User is: Tranzman is offline
I picked up a New 19212593 GM pan kit for $199 a week ago. The Holley pan was $388 on amazon and I still needed to get a dipstick and tube. I'm going to risk the GM pan. I'll weld up and install a skid plate if needed.
"Most people do not listen with the intent to understand; they listen with the intent to reply."--Ernest Hemingway.
Black 2000 S10 Base 2.2L Flex Current LS10 swap project
Red 2000 Blazer LT 4x4 3.73 SOLD
Red 1998 S10 SS 4.3L Deceased 10/31/2014
Tranzman is offline
post #29 of 36 Old 05-20-2019, 01:44 PM
User is: ezrollin561 is offline
I'm going to CPW this week a pick up the oil pan and urethane mounts. The pan with pick up, stick, etc. is $235. I'm eager to see if the TBSS exhaust manifolds will clear. Also, I can see how much clearance with the stock suspension. I plan on the LS1 front brake swap and may install some 1" drop springs.
First Gen. 2wd sbc.
First Gen. 2wd 3.4
post #30 of 36 Old 05-20-2019, 11:49 PM
Randy
Tranzman's Avatar
I see Holley is making S-10 Swap manifolds now for $245, PART# 71223026HKR and Adapter pipes P/N 71223024HKR
Tranzman is offline
post #31 of 36 Old 05-21-2019, 12:04 AM
oldeerslayer's Avatar
Is that $245 a pair or each?
post #32 of 36 Old 05-21-2019, 12:15 AM
Randy
Tranzman's Avatar
A Pair, I didn't think that it's to bad of a price. i'm going to see if there are dimensions for those...
Tranzman is offline
post #33 of 36 Old 05-21-2019, 07:45 AM
I'd rather have those for my build than headers but I'm hoping the tbss exhaust will clear.
First Gen. 2wd sbc.
First Gen. 2wd 3.4
post #34 of 36 Old 05-21-2019, 08:19 AM
Not a bad price at all. Only cheesey headers are less money. Less under hood heat and no ting ting ting.....
The coated Patriot headers on my 6.2 1st gen SBC sound like bad lifters.
post #35 of 36 Old 05-21-2019, 11:03 AM
LS3 Cruisin'
98Sonosls's Avatar
Get your headers thermal barrier coated. The ceramic silver coating that some headers are advertised with isn't the same thing and doesn't do dick all. It'll cost as much for coating headers properly but man it makes a helluva difference!
post #36 of 36 Old 05-21-2019, 02:44 PM
How well does the thermal coating hold up?
First Gen. 2wd sbc.
First Gen. 2wd 3.4
Similar Threads
Leaky Rubber Feet Oil Pan and Oil Drop on Filter MikeT2002 S10 / Sonoma 2 01-17-2019 04:02 PM
Oil Pan Gasket 2001 4.3 S10 4x4 BuzzBates S10 / Sonoma 2 09-14-2018 11:10 PM
Oil cooler lines and adapter lessons learned (1999 Blazer LT 4WD) christine_208 262ci Forum (4.3) 9 10-04-2017 11:06 PM
Do I have to loosen/drop the oil pan to install a new front cover? Racer-X 262ci Forum (4.3) 11 09-20-2017 09:19 PM
Hummer h3 oil pan issue RegCab LSx Discussion 6 04-30-2016 12:50 PM
