What is everyone running for a fuel pump? I plan on using the truck for cruising around. My swap project took a unexpected fast forward, I’m currently doing body work to the truck cab corners, dings in the doors from a$$holes hitting my truck with there door. I’m also changing the core support to accept the 98 n newer lights, when I pulled the passenger fender found the lower cab rotted out. The engine is coming out to fix it right and to undercoat the entire underneath. So I’m not going to put the V6 back in.
The Quantum unit won't work for me as I have a 2.2L tank and the Quantum folks say they don't have a drop-in assembly for the 2.2L. I had the one that said "(or LSX swap)", but you still have to have the 4.3 tank so, back it goes.
OK... is simply getting the pump only, from a vendor and installing it in my factory unit my only solution?
So how hard can it be to put in a 4.3 tank if that's what you need? The external dimensions should be the same if you get one for the same year and model that originally had a 4.3 with CPI or SCPI.
