Engine mount question - S-10 Forum
post #1 of 11 Old 04-14-2019, 09:47 PM Thread Starter
User is: Javlin42 is offline
Question Engine mount question
I've got a 2wd 85 S10 Blazer that I'm currently doing a LQ swap in. I did quite a bit of research before I started this and I know that the truck oil pan wouldn't fit without notching the crossmember and then the oil pan would still hang below. However on my truck it is 1+ inch above the crossmember. I'm using cpw poly mounts and stainless works long tubes.
I have noticed that on my blazer I have these pedestals that the mounts fit on.
And in other posts and pictures that not all of the S10 come with these mounts/pedestals.
Should I remove them to set the engine down further? Are there bolt holes under these? Will my headers still work, cpw doesnt say abything about the pedestals on their website? What is everybody else doing?
Javlin42 is offline
post #2 of 11 Old 04-14-2019, 11:33 PM
oldeerslayer's Avatar
Re: Engine mount question
Post some good pics of what you have.
post #3 of 11 Old 04-14-2019, 11:40 PM
B4U Task Force
Rhotpursuit's Avatar
The Blazer has an additional pad. It can be removed.
Apple Red 96 SS
post #4 of 11 Old 04-15-2019, 12:14 AM
IIRC on the early trucks there are 3 bolts holding those frame mounts in. Unfortunately they didn't start welding the nuts to the frame until later so you need to get a box wrench in there to hold the nuts. Can be a real PITA on one of them, but it can be done.
post #5 of 11 Old 04-15-2019, 07:17 AM Thread Starter
Sorry guys I had tried to embed pictures but they didn't upload for some reason. Trying to use tinypic. I can email them to somebody if they could post them.
Javlin42 is offline
post #6 of 11 Old 04-15-2019, 09:34 AM
B4U Task Force
Host at www.postimage.org. Share using the Hot Link for Forums tag.
Apple Red 96 SS
post #7 of 11 Old 04-15-2019, 11:49 AM
EZA
User is: EZA is offline
You'd better use Postimage or he wiil hound you unmercifully (lol) until you do! Postimage does work great!!!
EZA is offline
post #8 of 11 Old 04-15-2019, 01:18 PM
B4U Task Force
I don't care if he draws pics on toilet paper. He said he was having trouble so I offered an alternative....j/s.
Apple Red 96 SS
post #9 of 11 Old 04-15-2019, 01:19 PM Thread Starter
Here is how the mounts are on my blazer
And I had run across some without that looked like this.
Javlin42 is offline
post #10 of 11 Old 04-16-2019, 12:37 PM Thread Starter
So just cut the stands off and and drill 3 holes to mount it? Any suggestions on figuring out where the holes need to be placed?
Javlin42 is offline
post #11 of 11 Old 04-16-2019, 12:51 PM
B4U Task Force
Install the mounts and lower it into place. If the transmission is attached, line the transmission up where it belongs. Tack weld the frame mount into place. Remove engine and finish the well, or mark and drill/tap holes.
Apple Red 96 SS
Similar Threads
LS engine mount types EZA LSx Discussion 6 04-10-2019 06:39 PM
2200 engine wiring harness question moonshadows 2.2L - 2nd gen 4-banging 18 01-23-2017 04:08 PM
CPW Engine Mount Question Varhalla LSx Discussion 3 01-23-2017 11:50 AM
Engine mount help Djacob174 2.2L - 2nd gen 4-banging 4 08-12-2016 06:28 AM
91 engine mount destroyer Big Nasty Offroad 262ci Forum (4.3) 5 06-21-2016 09:13 AM
