2000 5.3 s10 build questions/options - S-10 Forum
 12Likes
post #1 of 56 Old 04-12-2019, 08:15 PM Thread Starter
User is: Double0Dime is offline
ok guys, I finally registered here after lurking around in the shadows for a couple years. I picked up a 2000 standard cab s10 with no motor or trans for 700 bucks. it was originally a 2.2 auto truck. I then got my hands on a 2001 5.3 out of a Silverado and a 99 4l80 out of who knows what....thinking 2500 or 3500 truck. After tearing into the 5.3 it was awful looking inside, caked up oil under valve covers, everything leaked, the cam bearings felt like sand paper and the cross hatching was no longer with us. This was originally supposed to be a cam valve spring job and slap in..lol hahah. My 862 heads had some very small looking cracks in between the valves. I was told its not unusual and they would be fine to use by the machine shop, but that's not good for me so I had a set of ls1 heads laying around that are in really good shape. I cant remember exactly what number they are right now but the combustion chambers are bigger than the truck heads. So needless to say my block crank and heads are at the machine shop right now. I am getting the valves done on heads, honing block, polishing crank and he is installing my pac 1218 springs for me. The goodie list I have so far is pac 1218 springs, sloppy stage 2 cam, new lifters and trays, new rocker arms with trunion upgrade, texas speed stock length chromoly pushrods, shallower oil pan and another pocket full of money on gaskets knock sensors ect. I was looking at the summit brand domed forged pistons to make up for the compression loss.This truck is going to be part time street and a lot of track beatings. Im torn between a single turbo or a nitrous system. Sorry for such a long post but my questions are what tuning, front suspension, fuel pump, injectors, and headers(either nitrous or turbo) and what turbo or what nitrous system seems to be the flavor of the month. thanks a lot in advance. I live in Delaware by the way, and will be posting pics and updates of the build along the way.
post #2 of 56 Old 04-12-2019, 11:48 PM
New Member
Re: 2000 5.3 s10 build questions/options
You might want to talk to your machine shop before spending $500 on 2cc domed pistons. If they mill the heads and deck the block to assure they are flat you may gain back some of the 7 cc's you lost by going to the LS1 heads. You also want to consider the fact that turbos don't necessarily like high compression ratios to start with. It might limit how much boost you can run before you have to start pulling timing.
Give one of the Turbo manufacturers a call and explain your project. Their sales or support people should be able to help decide what should or shouldn't be done.
Welcome to the forum.
post #3 of 56 Old 04-13-2019, 08:12 AM Thread Starter
Thanks for the response. Do you know anyone that uses the summit brand piston? It looks like a wiseco to me.
post #4 of 56 Old 04-13-2019, 10:59 AM
Old Fart
User is: goes2fast is offline
You should check out Boosted 6's build thread since he built a truck similar to what you want to do. He ended up with a very fast fun truck.
https://www.s10forum.com/forum/f213/...sonoma-780033/
And welcome to the group!
post #5 of 56 Old 04-13-2019, 09:49 PM Thread Starter
I checked his build out and it is far and above anything i am doing but it is so nice and running 8s! I would be happy if my truck broke into the 10s. The more I look around and price things the more I'm leaning towards a 150 shot of nitrous. I don't have the fan skills or tools to do a turbo setup and I definitely don't have the money to pay someone. Does anyone on here have a simple 5.3 nitrous set up? I pulled the bed off the truck today and will start cleaning and painting the frame then start messing around with the fuel system which I'm still unsure what pump and hoses to go with. I'm thinking about a walbro 255 and some braided -6 feed and return. Any suggestions on stock tank or fuel cell please let me know. Thank you
post #6 of 56 Old 04-14-2019, 12:28 PM
Old Fart
I'm not a fan of NOS, seen too much carnage from nitrous explosions. Even the pros have things go wrong and go boom. If you can't afford a turbo, can you afford to replace all the parts that get damaged when it goes lean and explodes everything? If you can't afford a turbo go NA and better parts. 500 hp is easily attainable with the right combo.
post #7 of 56 Old 04-14-2019, 03:13 PM Thread Starter
I'm not in too much of a rush. I guess I could wait and save some more money for the turbo setup. My problem would be finding someone to do all the hot side work for me and not charge me an arm and leg. I took some pictures of my truck but haven't figured out how to post them yet. I took the bed off last night. I went to a local u pull it in Maryland and didn't find the unicorn s10 8.5 rear I was looking for but did find 3 d4 axle code explorer 8.8s which are 3.73 Posi disc brake rears for 150 each. I think i am going to buy 2 of them incase 1 is **** and I'll steal the short side axle out of it.
post #8 of 56 Old 04-14-2019, 04:24 PM
New Member
User is: lilbowtie is offline
Since your going to be spending a lot of time at the track it would be a good time to put a cage in it. You say 10's but it only takes 150 HP to do that. Once you start you'll feel the need for speed.
post #9 of 56 Old 04-14-2019, 07:58 PM Thread Starter
Well tonight I was messing around and decided to take the AC and blower motor off the firewall because I'm not using it and could use the extra space. What a pain in the butt that was. The inner wheel well fender headlights battery tray and half the grill had to be removed to get to the bottom bolts. I was going to leave that side inner wheel well off and move the over flow tank and computer to the firewall but I'm not sure I like it. If it was just going to be a race car I would leave it. Maybe if the fuse box and abs box wasn't on the driver side I would remove them both. I am planning on doing a cage eventually but right now I'm almost overwhelmed with all the things that need to be done just to get it running. I did a photo bucket account so I will try to get pics up soon. Nothing really to look at but a s10 with no bed and drivetrain. Lol
post #10 of 56 Old 04-14-2019, 11:45 PM
New Member
If you use postimage.org instead of Photobucket, your pictures won't have that stupid logo in the middle of them when posted on the forum.
They also post the pics full size on their site and you can post that link also for things like wiring diagrams that get too small to read when posted in the forum. Or to better show detail. Also no ads on their website so everything loads faster.
goes2fast likes this.
post #11 of 56 Old 04-14-2019, 11:59 PM
B4U Task Force
Rhotpursuit's Avatar
I've found that the Hot Link for Forms tag is the easiest to use....goes2fast likes the direct link...either way...no thumbnails.
Apple Red 96 SS
post #12 of 56 Old 04-15-2019, 09:05 AM
New Member
I would have suggested removing the frt clip as one piece, which you can still do to make easy to work on. I don't care for no fender-wells either.
post #13 of 56 Old 04-15-2019, 10:22 AM Thread Starter
I will steal my wife's laptop tonight when I get off work and get you guys some pictures. I thought about taking the whole front clip off but didn't know if it could be done without messing with all the brake line abs stuff on the driver side. I will probably leave the inner wheel well out until I replace upper control arms and any other front suspension. Anyone have good recommendations for upper control arms shocks and coils for up front? My truck was originally a 2.2 so I'm guessing the stock springs won't be any good.
post #14 of 56 Old 04-15-2019, 07:18 PM Thread Starter
I hope this worked
post #15 of 56 Old 04-15-2019, 07:19 PM Thread Starter
http://s346.photobucket.com/user/Cdi...m.jpg.html?o=3
http://s346.photobucket.com/user/Cdi...rvow.jpg.html?
o=4http://s346.photobucket.com/user/Cditeodoro/media/IMG_20190414_150552_zpsmi86ej1m.jpg.html?
o=2http://s346.photobucket.com/user/Cditeodoro/media/IMG_20190414_150543_zpsjpna90sa_1.jpg.html?o=0
post #16 of 56 Old 04-15-2019, 07:47 PM Thread Starter
Sorry for the crap pics. I took them with my Walmart phone in my garage. Once I get into actually doing things I will make sure pictures are better. Let me know what you guys think.i have the bed off for fuel system and rear work thats coming soon.
post #17 of 56 Old 04-15-2019, 07:52 PM
User is: LT1coupe is offline
It's a whole lot easier to pull the front end. I was amazed how easy it goes on and off. In my case I removed the ABS controller & had zero issues bleeding it conventionally when I put it back YMMV
LT1coupe is offline
post #18 of 56 Old 04-15-2019, 09:18 PM Thread Starter
So are the rad supports underneath? And then it just pulls right out?
post #19 of 56 Old 04-15-2019, 10:38 PM
I removed it in pieces so I could handle the pieces by myself. Pulled the bumper, grill & hood, unbolted and removed each fender leaving the inner fender attached to the fender, and finally the two bolts holding the core support.
LT1coupe is offline
post #20 of 56 Old 04-16-2019, 08:03 AM
New Member
The stock upper control arms are just fine but if you feel the need go for it. Stock springs will do the job but way too stiff for me, ordered softer. Shocks are going to be your choice - I'm using Strange adjustable. That is one clean truck.
post #21 of 56 Old 04-16-2019, 08:59 AM Thread Starter
I think i will take the whole front clip off for easier access. I always thought that the stock upper control arms interfered with headers and that's why alot of people used tubular uppers. The truck is surprisingly clean for being from the northeast. I see alot with rotted rockers and cab corners around here. If I get the front clip off tonight I will take some more pictures. Thanks for the info.
post #22 of 56 Old 04-16-2019, 09:27 AM
I'm running new 4.3 moog springs with an iron block, bilstein shocks & a blazer sway bar. The ride is firm, but not harsh.
I rebuilt the entire front end and added camaro calipers & rotors while the sheet metal was off.
Ride height is close to stock
LT1coupe is offline
post #23 of 56 Old 04-16-2019, 11:21 AM Thread Starter
Lilbowtie those are some slick headers. Are they custom or off the shelf?
post #24 of 56 Old 04-16-2019, 11:23 AM Thread Starter
Lt1coupe you have a really nice truck also. I was hoping to have mine a little lower in the front so maybe if I bought new 4cyl springs that would put me an inch or 2 lower than yours. What do you guys think of 2.2 springs with ls?
post #25 of 56 Old 04-16-2019, 11:50 AM
Old Fart
Why is everyone too lazy to learn how to post full size pics so we can see details? It is so mush easier to see what is going on if the pics are bigger both for asking questions and the answers.
post #26 of 56 Old 04-16-2019, 11:55 AM
B4U Task Force
Careful...you'll be accused of hounding people unmercifully....lol
Apple Red 96 SS
post #27 of 56 Old 04-16-2019, 12:07 PM
Old Fart
I know, but I don't get it this is the only forum that has this problem, so I keep hoping for change.
post #28 of 56 Old 04-16-2019, 12:16 PM
B4U Task Force
That's what happens when Fisher Price equipment is used....lol. I decided I'm going to quit suggesting full-sized pics unless they ask....otherwise...I pass.
Apple Red 96 SS
post #29 of 56 Old 04-16-2019, 12:47 PM Thread Starter
Are my pictures not coming up big enough? Sorry it was my first time posting pictures on here. Should i use something besides photo bucket? I do need to get a good camera instead of using my phone.
post #30 of 56 Old 04-16-2019, 12:56 PM
B4U Task Force
goes2 fast...you're up.
Apple Red 96 SS
post #31 of 56 Old 04-16-2019, 01:00 PM Thread Starter
Did I just stir this guy up? I looked at a couple of his posts and he seems like he gets pretty upset about pictures. I'll postimage and see if that's better.
post #32 of 56 Old 04-16-2019, 01:07 PM
B4U Task Force
No...but his point is valid. A picture taken several feet away and posted as a thumbnail doesn't leave much in the way of clarity. Thumbnails don't always enlarge when clicked on. I like postimage...no adds easy to use...allows multiple folders to file your pics. If you use postimage, I prefer the Hot Link for Forums tag....goes2fast likes the direct link tag. Either works. Try posting some pics in the Test forum and see what works best for you. If you have questions, post them up 'or use PM's and we can help you.
Apple Red 96 SS
post #33 of 56 Old 04-16-2019, 01:30 PM Thread Starter
Ok thanks. When I get home from work tonight I will give it a try. Thanks.
post #34 of 56 Old 04-16-2019, 03:36 PM
New Member
Those are Hedmans and I had them ceramic coated. I don't think 2.2 springs will drop you any as I mentioned earlier I bought different springs because the 2.2 were too stiff. Here is a look with 2 inch drop spindles up front and a 3 inch drop in back - 25/15's frt 28/15's rear
Not directed at you dime but larger pic's would be nice - can you post vids
post #35 of 56 Old 04-16-2019, 06:47 PM Thread Starter
https://postimg.cc/gallery/2986p8eq4/
Ok so this is the postimage gallery I just made real quick. Can you guys let me know if this works and pics are a good size. If so I will use this gallery from now on.
post #36 of 56 Old 04-16-2019, 07:17 PM
B4U Task Force
No worky. When you click the "Share" button, it will come up with a list of options. Click on the far right side of the Hot Link for Forum tag...that copies it to your clipboard. In your S10 post, click "Edit" then "Paste.
Apple Red 96 SS
post #37 of 56 Old 04-16-2019, 08:32 PM Thread Starter
post #38 of 56 Old 04-16-2019, 08:46 PM Thread Starter
Well not too much happened tonight. I almost have the rad support out but my wife is at school tonight so I have a 10 and 6 year old to tame.. Lol. I am planning on picking up my 8.8 at the junkyard tomorrow even though my dad thinks the stock 7.5 will be fine and he also told me the 4l80 I have is overkill... I didn't know there was a such thing. I hope I got the picture situation straightend out. So tomorrow I will hopefully have pics of truck with rad support off and the 8.8 explorer rear.
dfulkshi likes this.
post #39 of 56 Old 04-16-2019, 08:50 PM
B4U Task Force
OK...I just went thru 5 of your pics and edited them. This is what they should look like when you choose the Hot Link for Forum tag. I left the last pic as a comparison. I can fix that one also...just wanted to show you the difference.
Apple Red 96 SS
post #40 of 56 Old 04-16-2019, 09:10 PM Thread Starter
Wow! That's much better. So I'll make sure I edit them before I post. Thanks alot with all the help I appreciate it. This could be a long build so I want to make sure the pictures are good so you guys stay around and help me with this swap. Thank you
post #41 of 56 Old 04-16-2019, 09:18 PM Thread Starter
post #42 of 56 Old 04-16-2019, 09:22 PM Thread Starter
This is pretty much where I left off tonight.
post #43 of 56 Old 04-16-2019, 09:22 PM
B4U Task Force
No Problem man. If you need more help...let me know.
BTW..you can still put more than one pic in a post. Just make sure to hit return/enter between pics. You can even enter text between pics if they need a little explanation.
Apple Red 96 SS
post #44 of 56 Old 04-17-2019, 07:00 PM
Old Fart
Much better, I can see what is going on now!
post #45 of 56 Old 04-17-2019, 07:23 PM Thread Starter
Got the support out today and picked up an 8.8 3.73 Posi from an explorer today
post #46 of 56 Old 04-20-2019, 07:11 PM Thread Starter
So I took the driver side inner wheel well out and managed to not have to mess with the abs box. I unbolted it at the wheel well and left the bracket bolted to the fender. And as you can see my sway bar link is broken. I was planning on rebuilding from end anyway but this truck was tagged in 2018 so it was probably broken for a while. I also have a small update from the machine shop. I found some forged JE pistons that have a 7.5cc dome and will put my CR at 11:1 with a thinner head gasket and the quench will be perfect (whatever that means) .. I think he said stock was .55 or .51 compressed and this gasket is .39 or. 40. So obviously the turbo set up is not happening. He told me I should be easily at 500hp at the flywheel and be able to run pump gas. He also said that it will love a small shot of nitrous. So I'm figuring with a 150 or 200 shot I should be putting 550 plus to the tire which is plenty for me.
post #47 of 56 Old 05-11-2019, 03:09 PM Thread Starter
post #48 of 56 Old 05-11-2019, 03:28 PM Thread Starter
So there's the stock length 8.8 installed pretty much. The only things I have to do is grind the old sway bar perches off so I can install shocks then get the brake line adapter piece so it will Bolt on to the stock s10 line and then put a new cover and gasket on it and put fluid in it. I got the u bolts from Dayton and I think they are 3 1/4 by 9? Really nice bolts and came with nice nuts and washers also. They are expensive but they fit perfect. They are a little long because eventually I'm gonna put a lowering block back there but won't know how much until I get wheels tires and bed on. There's roughly 9 inches from frame to wheel mounting surface so I'm guessing the stock 10 Bolt had around 7 since this rear is 4 inches wider. For like the past 2 weekends I've been beating old leaf spring bushings out! What a nightmare that was. I seriously considered buying new ones because it was such a pain in the ***. So im still chipping away at this thing guys. My engine is actually done and sitting at the machine shop but I'm not ready for it yet. I still want to finish up the rear end and do the fuel system first. Does anyone have part numbers for the brake line adaptor I need and also the universal that bolts to the 8.8 rear?
post #49 of 56 Old 05-11-2019, 08:45 PM
B4U Task Force
Try drilling holes thru the bushings...
Apple Red 96 SS
post #50 of 56 Old 05-12-2019, 12:58 AM
Old Fart
Some people burn them out with a propane torch as well, I did it the way Rhotpursuit suggested the only time I have had to do that, and it was still a lot of work.
Similar Threads
2000 2.2 to 5.3 Components Used teambogus LSx Discussion 5 03-05-2019 12:16 AM
2000 s10 5.7 vortec/0411 swap Chriswalker V8 Discussion 5 02-02-2019 01:27 AM
Will 2002 V6 work in my new 2000 S10? InkaholicMike 262ci Forum (4.3) 5 09-03-2016 10:19 PM
Buy or build 5.3 03Grunt LSx Discussion 1 08-15-2016 04:40 PM
Advice Needed Beginner S10 Offroad Build cdetweiler S10 / Sonoma 3 07-28-2016 08:12 PM
You may post new threads
You may post replies
