Subframe/chassis interchangeability. - S-10 Forum
 2Likes
  • 2 Post By Rhotpursuit
post #1 of 7 Old 04-14-2019, 04:00 PM Thread Starter
WalterLV's Avatar
User is: WalterLV is offline
Hi there, new to this forum.
Has anyone any experience, if gen1 and gen2 subframes are interchangeable? It started almost a year ago with a 88 2 door Blazer barn find, it has a 2.8 4x4 with no front diff and axles. Last week I bought a differential, it came with a mint 2nd gen car, that has been rolled over and had around 30k original miles on it.
As the donor car's chassis is in much better condition, than mine, the crazy idea came up, to switch the bodies, put a gen1 body on a gen2 chassis, rather than switching the diff, half axles, brakes and other stuff one by one.
Both cars are 4x4 2 doors, 1988 and 2000ish
Anyone done this before?
WalterLV is offline
post #2 of 7 Old 04-14-2019, 04:21 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Subframe/chassis interchangeability.
This might help some..
http://www.gmupfitter.com/publicat/p..._Truck_pgs.pdf
dime-dozen and thebadwrench like this.
Apple Red 96 SS
post #3 of 7 Old 04-15-2019, 01:20 AM Thread Starter
WalterLV's Avatar
It's great, now I'm trying to find the same manual for gen1. That would answer all the questions. Thanks, it's very useful.
WalterLV is offline
post #4 of 7 Old 04-15-2019, 01:41 AM
B4U Task Force
Well...it might come down to a tape measure and a lot of pics. I don't know of anything for a 1st gen.
Apple Red 96 SS
post #5 of 7 Old 04-15-2019, 02:27 AM
Mr Goodwrench's Evil Twin
User is: thebadwrench is offline
Looking at the part numbers for the frames, they are not the same so they are not technically interchangeable. They are similar though and with some ingenuity and determination, anything is possible... so they say. Probably be more work than it's worth, but I wouldn't really know
post #6 of 7 Old 04-15-2019, 06:57 AM
New Member
There will be some differences on the front bumper mounts when using that new of a frame. Not hard to cut and weld the ends while you have the frames striped.
post #7 of 7 Old 04-15-2019, 07:22 PM
time to get cereal
You're going to need to do some rewiring for the body harness too, keep most of the switchgear from the newer model since it is BCM controlled.
Similar Threads
engine interchangeability 1999 4.3 liter to 2002??? WESTERNREACH 262ci Forum (4.3) 0 01-28-2019 12:04 AM
Bed Interchangeability 1Fast92 S10 / S15 4 08-19-2018 12:51 PM
spindle interchangeability ? Jess 2wd Droppin' 20 04-24-2017 10:31 PM
1st gen to 2nd gen front hub interchangeability? GM 4wd IFS 3 03-31-2017 09:26 PM
Fuel pump interchangeability between 2nd gen trucks misterW 262ci Forum (4.3) 0 07-24-2016 01:28 PM
You may post new threads
You may post replies
