Posi unit for 87 Blazer - S-10 Forum
post #1 of 21 Old 03-17-2019, 03:25 PM Thread Starter
User is: Bunky is offline
I picked up a 87 Blazer 2wd has 350/700r4 308 gears. I would like to out a posi traction unit in it but don't want to spend a lot because down the road I will probably but a better housing in the truck.
I'm told it should have a 7.5 rear end in it. What options is there ?
I came across a used unit out of a newer 90's Camaro with very low use are these the same ?
Bunky is offline
post #2 of 21 Old 03-17-2019, 03:28 PM
New Member
User is: dime-dozen is offline
Re: Posi unit for 87 Blazer
theres about 3 styles(manufacturers) of 7.5 differentials
do you have any idea which it is?
post #3 of 21 Old 03-17-2019, 03:48 PM Thread Starter
No I don't know and I don't have the Blazer here yet ?
Bunky is offline
post #4 of 21 Old 03-17-2019, 04:25 PM
EZA
New Member
User is: EZA is offline
If it has the 87 rear it is a 7.5" 26 spline. The easiest and cheapest thing is to find a later 7.6 with factory gov-lock or keep looking until you find an 8.5". Don't waste money on the 7.5" 26 spline.
EZA is offline
post #5 of 21 Old 03-17-2019, 05:02 PM Thread Starter
So the 7.6 is a direct bolt in? What uses this rear end ?
Bunky is offline
post #6 of 21 Old 03-17-2019, 05:44 PM
EZA
New Member
Any 2wd pickup or blazer, 28 spline was 89 up though there will be varying gear ratios. The code should be in the glove box G80 is the gov-lock. I think we have a sticky with gear ratio codes. Get the whole rear end, I believe 98 up are disc.
EZA is offline
post #7 of 21 Old 03-17-2019, 05:59 PM Thread Starter
Thanks for the help I will have to check into finding one.
Bunky is offline
post #8 of 21 Old 03-17-2019, 06:03 PM Thread Starter
Oh and I currently drive a 98 S10 2wd and it has drum rear brakes
Bunky is offline
post #9 of 21 Old 03-17-2019, 06:52 PM
New Member
all S10 trucks are drum brake except the 98+ 4WD
post #10 of 21 Old 03-17-2019, 07:18 PM
EZA
New Member
Actually, I wasn't aware the pickups didn't get them, I've only had first gens until I bought a 2003 crew cab. No problem though the 2wd blazer rear end will bolt in, got one in my first gen.
EZA is offline
post #11 of 21 Old 04-03-2019, 07:51 PM Thread Starter
Ok so I decided after no luck on finding a 3:73 S10 posi I went with the 8.8 Ford so today I went a picked up a 8.8 out of a 91 explorer and was told it's a 3:73 ratio. This is the ring gear picture does anyone know how to decode this?
Bunky is offline
post #12 of 21 Old 04-03-2019, 08:02 PM
B4U Task Force
Rhotpursuit's Avatar
It should have a tag on the rear with all of the pertinent info. If not...count the teeth and do the math.
Apple Red 96 SS
post #13 of 21 Old 04-03-2019, 08:06 PM Thread Starter
Yes there should of been but there wasn't some where along the way it was removed
Bunky is offline
post #14 of 21 Old 04-03-2019, 08:14 PM
B4U Task Force
take the ring gear teeth divided by the pinion teeth=rear ratio.
Apple Red 96 SS
post #15 of 21 Old 04-03-2019, 09:09 PM
EZA
New Member
Is the 8.8 a limited slip, I thought that was what you were looking for.
EZA is offline
post #16 of 21 Old 04-03-2019, 10:04 PM Thread Starter
Yes the 8.8 is a Limited slip unit.
Bunky is offline
post #17 of 21 Old 04-03-2019, 10:07 PM
Been there Done it
oldeerslayer's Avatar
Doesn't ford put the number of teeth on the ring gear like most vehicles? Like 41-11 for 3.73?
I suspect the 41? in the pic is part of that. Ford didn't offer a 41-10 (4.10 ratio).
post #18 of 21 Old 04-04-2019, 08:27 AM Thread Starter
Well I heard that they did I read that it was the two numbers after the letters and the next two letters. Which would be the 41.
Bunky is offline
post #19 of 21 Old 04-04-2019, 11:26 AM
EZA
New Member
You can divide the ring gear number of teeth by the pinion number of teeth to be sure.
EZA is offline
post #20 of 21 Old 04-04-2019, 11:30 AM
B4U Task Force
Apparently he doesn't want to do that...post 14.
Apple Red 96 SS
post #21 of 21 Old 04-16-2019, 06:18 AM
jayyk31's Avatar
User is: jayyk31 is offline
Passenger side axle tube, facing forward, about 6" inboard of the pumpkin. Use a wire wheel or brush to make it readable. You will get the axle code from what was in it when it left the factory.
82-87 = 7.5 26 spline
88-92= 7.5 26 spline AND 7.6 28 spline
93 on= 7.6 28 spline
Go with a Truetrac if you have the 26 spline axles. If you have the 7.6 with 28 spline axles grab a Zexel Torsen from a 4th gen f body. Direct swap, same as Truetrac, it's a helical gear LSD...
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
Similar Threads
Blazer Gas Tank Swap/Build/How-To Connor94 S10 / Sonoma 51 05-17-2019 12:26 AM
Blazer Dual Piston Brakes, Powdercoated, Rebuild Parts, Spindles, and more Harley Parts 8 09-07-2018 05:50 PM
99 blazer Four connector pcm in 2002 extreme blazer, will it work? S10REX Xtreme / ZQ8 0 07-30-2016 07:13 PM
wtb posi unit blazed2 Wanted, to Buy 0 04-20-2016 08:26 PM
You may post new threads
You may post replies
