my white 94 - S-10 Forum
post #1 of 101 Old 12-30-2011, 09:06 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
User is: hi_im_sean is offline
my white 94
just picked it up on tuesday for $3000. it has 98xxx miles, and was well cared for.
im going to fix all the little things wrong with it, and install an intrepid fan i have laying around.
needs an intake boot, wiper blades, valve cover gaskets (just starting to weep), a temp sender, map lamp cover, a cluster lamp or 2, fuel filter and maybe a cap and rotor. the previous owner just did oil change, radiator, oil lines, water pump, hoses, motor mounts and rear main less than a thousand miles ago. i think it needs a pressure reg or nut kit. it idles just a little rough and is hard to start when it gets warm. i put my pressure gauge on it today and it dropped a pound every 7-10 seconds after the key is turned off. other than that it runs fantastic, i scared my wife and left double lines on a friends street.
the only dent
tires are in good shape, but the are cheapys. i want to get some 16 or 17" rims and tires in a few thousand miles.
interior is good except the rip
engine bay is very clean for its age. no leaks... except the a/c
so the a/c doesnt work, heres why... pressure switch leaking
today i replaced the intake boot. it was really floppy and tore up, dry rotted etc. cleaned the butterfly and intake temp sensor while i was in there.
the temp gauge doesnt work, i found the wiring had come loose from its "bullshit" clip and was rubbing the steering shaft. the sender is bad too.
testing the cluster with a restistor, it read what it should
you can see how close it all is
it comes with a cassette! its some 70's porn music with a nice couple explaining how to use an s10 and all the features lmao
zq8 rpos
post #2 of 101 Old 12-30-2011, 10:04 PM
JAMCAR223's Avatar
User is: JAMCAR223 is offline
Re: my white 94
Nice find. My first s10 was a 95 ss. Black. I dropped it 2 more inches, tonneau cover, 16" Centerlines, custom pinstripes, amp& sub, billet grill, roll pan. It would smoke all the fullsize 350tbi's around. I had it for 1.5 years. It was cool...until someone stole it.
post #3 of 101 Old 12-30-2011, 10:22 PM
Electrical Mod
deathphoenix99's Avatar
Re: my white 94
great looking 94!
post #4 of 101 Old 12-30-2011, 11:38 PM
mhilt13's Avatar
User is: mhilt13 is offline
Re: my white 94
thats a nice clean truck. i was lookin for a 2nd gen reg cab the last two month in the 3-4 grand price range and everyone i looked at in that price range were all beat up good find super clean!!!
mhilt13 is offline
post #5 of 101 Old 12-31-2011, 01:39 AM
First Gen FTW!
TN-Noma's Avatar
User is: TN-Noma is offline
Send a message via AIM to TN-Noma
Re: my white 94
Sweet truck man, looks pretty clean, diggin the white.
-Matt- '93 GMC Sonoma Instagram: Mdlane85 My Build Thread
TN-Noma is offline
post #6 of 101 Old 12-31-2011, 01:47 AM
Check your ground
556mm's Avatar
User is: 556mm is offline
Re: my white 94
Damn that thing is nice.
556mm is offline
post #7 of 101 Old 12-31-2011, 02:02 AM
It puts the lotion on
deeznutz's Avatar
User is: deeznutz is offline
Nice truck! I'm even more jealous of the S-10 tape! Haha wtf is on that?
03 Crew Cab
deeznutz is offline
post #8 of 101 Old 12-31-2011, 09:33 AM
Electrical Mod
Re: my white 94
It's just information for the truck. I see them every now and then at the junk yards with some of the older trucks.
post #9 of 101 Old 12-31-2011, 10:02 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
yup
its just the owner manual read aloud with some common sense info thrown in there and some background music. maybe ill go record a minute of it for fun.
thanks for all the compliments! im very happy with it, the more i drive it, the more i like it. ive always owner blazers and entended cabs. this is my first standard cab short bed. that along with the zq8 steering box makes all the difference in the world. it parks like a car.
post #10 of 101 Old 12-31-2011, 10:20 AM
24digger's Avatar
User is: 24digger is offline
Re: my white 94
Very nice truck, thanks for sharing.
24digger is offline
post #11 of 101 Old 12-31-2011, 01:21 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
this morning i rehung the rear view mirror, fixed the temp gauge that wasnt actually broken, more on that later, repaired the wiring, and replaced some split loom, and discovered the battery hold down was missing. i noticed and remembered the control arm bushings are new too, standard moog stuff. looks like it might need an idler arm as well, i have a good one layin around somewhere.
the reading lights even work
the hold down from my 86 s15 is an exact replacement. im relocating the batt in the 86, so no need for it. and can anyone tell me what that cut wire coming out of that connector is?
so i fixed the temp gauge wiring and got a new sender, i plugged the new sender in and boiled a cup of water. stuck the sender in the water, with a ground clip of course, and the temp gauge read 180. the water had cooled off a little... drained the coolant, replaced the sender, filled it back up, and took her for a drive. still wont get above 130-140 ish. so the sender was never bad, the motor just isnt getting up to temp. i wonder if a thermostat is stuck open or maybe someone thought it didnt need one.
i lied about my dents, i found another one upon closer inspection, and a bunch of chips on the pass side of the bed.
and there is tar or urethane on each bottom corner of the tail gate and the suspender cables. i have a big can of goo gone.
i got underneath to take a really good look, everything looks great and clean except the y-pipe. the passenger side collector end looks like it got smashed. it so "clean" it looks like it was done from the factory for clearance issues but there is no need, and from what i can from the pics on lmctruck, its not supposed to be there. either way, anyone know where to get a decent y-pipe with something like a 3" outlet.
heres a badge for fun
post #12 of 101 Old 12-31-2011, 01:36 PM
Back Again
Jas98's Avatar
User is: Jas98 is offline
Re: my white 94
That's a nice truck man!!!
1998 Red Sonoma 2wd ext cab 4.3 Auto (Stock)
Jas98 is offline
post #13 of 101 Old 12-31-2011, 03:22 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
thanks!
thermo was stuck kinda open, but would come all the way open with pressure. new thermostat, success!
no wonder my heater took forever to get warm and never really got hot, it idles better now too.
post #14 of 101 Old 01-01-2012, 11:35 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Re: my white 94
Looks clean, can't go wrong with SS and definitely good deal on that.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #15 of 101 Old 01-02-2012, 08:39 AM
24digger's Avatar
Re: my white 94
I don't think that wire goes to anything, it like a blank just to fill the hole.
24digger is offline
post #16 of 101 Old 01-02-2012, 09:55 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
thats kind of what i was thinking, that part on the assembly line get clipped depending on the model or something like that.
Shitty website to be updated soon!
http://sadfab.com/
my projects:
94 S10 SS- https://www.s10forum.com/forum/f18/my-white-94-a-485474/
86 S15 corner carver- https://www.s10forum.com/forum/f30/86...beware-475623/
gay miata-http://www.miataturbo.net/build-thre...ru-td04-74776/
Gone postal, will be back later...
post #17 of 101 Old 01-02-2012, 01:04 PM
Electrical Mod
Re: my white 94
Didn't notice your question, but that's a rubber plug, not a wire in that connector.
post #18 of 101 Old 01-02-2012, 04:07 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
cool, thanks guys
anyone know if i can get the valve covers off without removing the intake?
and where in the hell does a cpi motor source it egr supply from? i cant see a thing on either exhaust mani.
http://sadfab.com/
my projects:
post #19 of 101 Old 02-24-2012, 07:00 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
just a little update
got a delco injector/reg assembly and a nut kit for $240 to my door from amazon. good deal if you ask me.
the fpr was the leaker, but i figured i would just do all of it, its a maintenance item in my opinion.
before
after
http://sadfab.com/
my projects:
post #20 of 101 Old 02-24-2012, 07:48 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: my white 94
Sweet truck man. I'd like to get my hands on one.
TelAmeriCorp
post #21 of 101 Old 02-24-2012, 08:11 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
thanks mostizzle, its my favorite s10 out of the 5 ive owned so far, well at least until the 86 is done.
just took it for a drive, no more miss at idle, stumbling in gear or hard starting.
http://sadfab.com/
my projects:
post #22 of 101 Old 02-24-2012, 08:36 PM
Chopper! Sic balls!
Mostizzle's Avatar
Re: my white 94
Good to hear. Too bad they didn't make them with 5 speeds. lol
TelAmeriCorp
post #23 of 101 Old 02-25-2012, 07:33 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
isnt that the dumbest thing gm ever did? i wish it was a 5 speed
http://sadfab.com/
my projects:
post #24 of 101 Old 02-25-2012, 11:09 AM
Electrical Mod
Re: my white 94
It'd been a lot faster probably with a 5 speed.
post #25 of 101 Old 02-25-2012, 04:51 PM
Chopper! Sic balls!
Mostizzle's Avatar
Re: my white 94
Manuals are a lot less power robbing than autos. You could always convert it to NV3500 or put a T56 behind it. lol
TelAmeriCorp
post #26 of 101 Old 02-25-2012, 10:12 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
i have thought about it. the t56 is worth almost as much as the truck but i would do a 3500 if it wasnt so difficult to get the pedal assembly in there, and i had less projects.
http://sadfab.com/
my projects:
post #27 of 101 Old 02-25-2012, 10:18 PM
Chopper! Sic balls!
Mostizzle's Avatar
Re: my white 94
I can dig it. Would be pretty sweet though!
TelAmeriCorp
post #28 of 101 Old 06-19-2012, 07:25 AM
eats "rice"
94sdime350's Avatar
User is: 94sdime350 is offline
Send a message via AIM to 94sdime350
Re: my white 94
Sweet SS man. That's what mine used to look like.
94SS s10. 350 v8 w th350 tran.w b&mshifter .Dana 60 3.73 rear end and a 3/4 drop. Borla mufflers. A Flip forward hood, Shaved, trailblazer headlights, Califorina combo, signal mirrors.
My ss10,1949chevy1tonPanel build... https://www.s10forum.com/forum/f30/ss-10-a-417720/
post #29 of 101 Old 06-19-2012, 06:41 PM
User is: RpoB4U is offline
Re: my white 94
nice looking '94SS. . . i had a black/graphite one new...! ! ! ! !
2000 S10 RcSs Xtreme black/grahite 203 thou on odometer
2003 Xtreme Blazer red/graphite resting /needing y-pipe
2011 HHR 2LT 2.4 red/graphite work hhr
RpoB4U is offline
post #30 of 101 Old 06-26-2012, 10:44 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
thanks.
i totalled my nissan truck that my mom had been commuting in, so she now drives the SS. i had to replace the fan clutch the other day, it locked up. she complained of it shifting funny and shitty gas mileage. i also replaced an oring in the compresor and gave her 1.75lbs of freeon, now itll freeze the cab when its 105 outside. i want to remove a rear leaf, zq8 coil, and throw an intrepid fan i have sitting around, i just have to much other shit to do! i hate how high it sits and how bouncy it rides.
http://sadfab.com/
my projects:
post #31 of 101 Old 06-26-2012, 10:54 PM
B4U Task Force
Rhotpursuit's Avatar
Re: my white 94
Well...the suspension mods you have in mind probably won't help the ride any. You might try some ZQ8 specific shocks from Bilstein.
Apple Red 96 SS
post #32 of 101 Old 06-26-2012, 10:59 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
problem is, i dont know why i have a zq8 on the rpo sheet because it has standard springs, not zq8, no hop shock etc. and i dont think i mentioned that i threw a set of bilstiens on it a month or 2 ago, which helped, but the spring rates are just to high. when its full of shit it rides great...
http://sadfab.com/
my projects:
post #33 of 101 Old 06-26-2012, 11:51 PM
B4U Task Force
Re: my white 94
The suspension pieces of ZQ8 didn't start until '96. Some people claim that the leafs are must regular leafs with one removed. I've never seen any documentation to that effect so I wouldn't put too much faith into that.
Apple Red 96 SS
post #34 of 101 Old 06-27-2012, 06:58 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
ive studied both sets of leafs, and it appears to be the case, but im not certain. either way, they seem to get about the same results, and removing a leaf is free. so if i have a std front sway bar, no hop shock, no rear sway, and standard springs... what part of the 94, 95 ss was zq8? the trim has its own code, as does the posi, etc.
http://sadfab.com/
my projects:
post #35 of 101 Old 07-05-2012, 02:28 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
Re: my white 94
I think it had bigger than stock sway bars that made it a "ZQ8". I am not really sure. I have wondered about that too. I changed all of mine out to the newer ZQ8. Added coil overs in front and the ZQ8 steering box as well.
Really nice truck you scored there!
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
https://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #36 of 101 Old 07-05-2012, 06:11 PM
B4U Task Force
Re: my white 94
There is a list of components that compromise the SS/ZQ8 package at the top of the SS page.
Apple Red 96 SS
post #37 of 101 Old 07-05-2012, 11:09 PM
Electrical Mod
Re: my white 94
The zq8's leaves are thicker than standard z83 leaves, regardless of 2 or 3 leafs.
post #38 of 101 Old 07-11-2012, 11:09 AM
"Stroke Me"
Super Stroker's Avatar
User is: Super Stroker is offline
Re: my white 94
Nice looking truck. Looks just like mine. Well, minus the 98 front end swap.
post #39 of 101 Old 08-01-2012, 09:52 AM
desertpatriot
desertpatriot's Avatar
User is: desertpatriot is offline
Re: my white 94
have you tried the 'hidden stitch' repair method for the rip on the driver side seat? it's amazingly easy with good results
2000 S10 LSx, 2.2L , 4L60E automatic, 181K miles, Blazer brake changeover front & rear (4w abs disk), Blazer sway bars front and rear, GU6 3.42 rear end
post #40 of 101 Old 08-20-2012, 03:05 PM
zfixerchick's Avatar
User is: zfixerchick is offline
Re: my white 94
What a beautiful truck! And a great price! I've had my 94 SS for just a little over a month and I feel the same way...I absolutely love it!
post #41 of 101 Old 08-22-2012, 09:52 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
my mother did the beach towel over the seat method. maybe when i take it back from my mom, ill try the hidden stitch, great idea.
thanks chick!
http://sadfab.com/
my projects:
post #42 of 101 Old 01-24-2013, 10:54 PM
9" racing glass pack
MotorNut123's Avatar
User is: MotorNut123 is offline
Re: my white 94
how is this done
PROJECT THREAD>
https://www.s10forum.com/forum/f30/my...-piece-508137/
1995 Chevy S10 Extended Cab LS
5 speed V6 Vortec (VIN Z) 2WD
S10's FTW!
I would gladly go shove your truck into the garage of a capable mechanic
post #43 of 101 Old 01-24-2013, 11:16 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
Originally Posted by MotorNut123 View Post
how is this done
http://tinyurl.com/akcjnpu
http://sadfab.com/
my projects:
post #44 of 101 Old 01-25-2013, 12:05 AM
Re: my white 94
http://lmgtfy.com/?q=how+to+spell+stitch
PROJECT THREAD>
S10's FTW!
post #45 of 101 Old 01-25-2013, 10:18 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
lol, i was wondering if you would catch that, and i bet you only did because google told you
http://sadfab.com/
my projects:
post #46 of 101 Old 01-25-2013, 05:03 PM
Re: my white 94
no i caught it before it even searched
PROJECT THREAD>
S10's FTW!
post #47 of 101 Old 01-25-2013, 05:21 PM
Hot Rod Enthusiast
s10kid17's Avatar
User is: s10kid17 is offline
Re: my white 94
This thing is so clean! I've seen some SS models around town here that are stock height and no zq8 options and I always wondered why. Now I know!
My 4.3 in my sonoma only gets up to about 130/140 (I have the digital dash so its hard to tell) I wonder if my thermostat is also stuck open..
Mike.
s10kid17 is offline
post #48 of 101 Old 01-26-2013, 02:32 AM
Re: my white 94
That's what mine gets up to, only around the first bold line. In the summer it's higher a little but that's expected. I haven't even looked at my t-stat.
PROJECT THREAD>
S10's FTW!
post #49 of 101 Old 01-26-2013, 02:38 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Re: my white 94
thanks s10 kid!
its a piece of cake to do the thermo. every one ive pulled out that has stuck open was a fail safe type. go figure
http://sadfab.com/
my projects:
post #50 of 101 Old 01-28-2013, 11:15 PM
Maybe later.
tytotheler92's Avatar
Re: my white 94
Originally Posted by hi_im_sean View Post
thanks s10 kid!
Yeah they're supposed to do that. haha.
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
