Post your rig setup - Page 2 - S-10 Forum
post #51 of 90 Old 05-09-2012, 07:22 AM
That 3D picture dude guy
DfntPntbll's Avatar
User is: DfntPntbll is offline
Send a message via AIM to DfntPntbll Send a message via Yahoo to DfntPntbll
Re: Post your rig setup
If you are refering to the voltages on the GPU, they are fixed. Thats not something that can be changed without doing a pencil mod. If you mean the CPU, thats fixed as well. By default, it is offset. I found I got lower temps at full load with fixed. You are right about my 3d work using more than average. While rendering, I use 13Gb. lol
1998 Ext. Cab S-10 4.3L bagged front/lowered 6" and rear disc
1993 Std. Cab S-10 4.8L bagged, traditional 3.25" BD
ASE Certified Alignment Tech
post #52 of 90 Old 05-09-2012, 01:49 PM
Dropped'01's Avatar
User is: Dropped'01 is offline
Yea ive heard that 3d stuff burns up a lot of ram thats cool though. I was talking about the cpu because i have it on offset. For my board it was more stable using offset mode so the cpu downclocks to 1.6ghz at idle. That Hyper 212 seems to perform really well for the price especially w/ the push and pull setup that you got.
Are you modding out that case? It looks like you added a bunch of plexi..
'01 S10 2.2L 5 speed, 3"-4" drop, K&N FIPK, Flowmaster, 56mm TB, OBX header, STS Pulleys, Cavi Seats, envoy handles, 8k HID Headlights & Fog Lights, SS Mirrors & Gen III bumper cover, 18" 225's.
post #53 of 90 Old 05-09-2012, 03:14 PM
DfntPntbll's Avatar
Yeah. The side window and top window are added in. I also added a side 120mm and a top 120mm fan. The 140mm in top was already there, I just moved it back a bit when putting in the window. On yours, have you tried fixed and disabling the CPU throttling? There are a few (4-5 I think) that effect or contribute throttling and stability in fixed mode.
post #54 of 90 Old 05-09-2012, 05:30 PM
Dropped'01's Avatar
The cpu isn't throttling since its no where near 95c but i like it also because my idle temps are lower and the voltage drops to 1.000-1.008v. Im usually around 28c-30c at idle as compared to when i clocked it in fixed and running at 4.5 the idle temp would be higher. Now as soon as i start up a game or do something cpu intensive it will increase from 1.6ghz to 4.5ghz.
It looked like you were modding it out, thats cool that you were able to fit more fans and be able to see into the case.
post #55 of 90 Old 05-09-2012, 06:07 PM
DfntPntbll's Avatar
that makes sense. Main reason I set mine up as I did was my PC rarely is at idle with all the stuff I do for [email protected] Even my GPU's get used for it. so I wouldnt see a difference. The program shuts down as soon as I go to render or play a game, so I see no impact from that. The case modding was easy. All you need is a dremel, cutoff wheels, correct size hole saws, plexi, and 3M mounting tape and some ingenuity.
post #56 of 90 Old 05-09-2012, 07:48 PM
Dropped'01's Avatar
Well its all preference but since your folding constantly then it really doesnt matter. Some people run it fixed and some run them offset, its what ever you want.
Looks good w/ the plexi and the big window looks sweet so you can show off everything inside
BTW i see your renderings you posted...those look great
post #57 of 90 Old 05-10-2012, 09:22 AM
DfntPntbll's Avatar
Thanks. There are a few other things I want to do to this case, but that will happen in due time. The renderings are coming along kinda slow, but thank you.
post #58 of 90 Old 05-11-2012, 09:50 PM
NUKKA!!!
JDnoble18's Avatar
User is: JDnoble18 is offline
Send a message via MSN to JDnoble18 Send a message via Yahoo to JDnoble18
Warning!! Super long post!
Sorry for the super large pics too.
Here is a Antec Skeleton I refreshed after Christmas:
AMD Athlon II x2 245 OC'ed to 3.3
ECS black edition mobo
Corsair H50 watercooler
4gb ram
500 gb drive
Diamond HD 6770 1gb
Thermaltake 430w PS
Nmediapc blue LCD front panel system stats reader
This is my first case I built in....but I rewired the whole thing with red LED's and remotely controlled lighting system. I salvaged the receiver and transmitter from an old set of fog lights.
Here are some other random builds I've done (any questions just ask):
'90 S-10 4x4 4.3 --SOLD
'90 Camry 2.0 5 spd 318k and going strong!
'07 Impala 3.5 102k
'08 Silverado z71 5.3 34k
post #59 of 90 Old 05-29-2012, 07:46 PM
Petitioning Low Rollers
mazdawg09's Avatar
User is: mazdawg09 is offline
cant give you much info just know it cost me a ton of money. all i know is i have a 26" led monitor and enough ram to run photoshop, cinema 4d, and multiple internets at the same time. plus i doon need to turn on a light in my room at night because it is so bright
Check out Lowrollers.com
PROJECTS:
white 01 2.2 ext cab(on air)
orange 91 mazda b2600(also on air)
WTB:
00 envoy front bumper
post #60 of 90 Old 06-16-2012, 02:27 AM
theonedub's Avatar
User is: theonedub is offline
Upgraded my old i7 to a 2600k and new motherboard:
i7 2600k @ 4.3ghz 1.280v, 16GB DDR3, 256GB Corsair Performance Pro SSD, 2TB Caviar Green, 1TB Samsung F3, GTX 580 Lightning, Antec 750w PSU, 650D case, and H100 AIO.
My secondary computer that was replaced a couple months ago:
Athlon II X3 440/AMD 6850 setup- relatively plain.
The new secondary, built from leftover parts from upgrades and some other stuff I had sitting around that I had forgotten about. Selling it now to cover some unexpected vet bills:
Intel i7 860, 4GB DDR3, EVGA P55 SLI, 1TB F1, CM 690 II ADV case, etc.
Not sure if I will build another secondary, but I do have my eye on a case I like, so who knows
OEM C6 Wheels | KP 6 Link | Dominator 2500/2600 | AZ OB2 | SMC Valves
post #61 of 90 Old 06-16-2012, 07:23 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
:haha @ you already overclocked yours. still thinking about doing mine still...
might as well post it.
https://www.s10forum.com/forum/f179/b...h-pics-484370/
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #62 of 90 Old 06-16-2012, 07:43 PM
theonedub's Avatar
Looks good- 570 SLI is a pretty strong setup. Overclocking these newer i7s is pretty easy. I would almost bet you could get to 4.0ghz @ stock voltage by just upping the multiplier to 40x.
post #63 of 90 Old 06-19-2012, 02:57 AM
Tech Mod
beandip's Avatar
Probably. but yeah these new i7s are stupid easy to overclock. but for now i dont have a reason to overclock yet.
-Jonathan
beandip is offline
post #64 of 90 Old 06-25-2012, 10:37 AM
HopnDude's Avatar
User is: HopnDude is offline
My rooms usually a mess. But, my rig;
Denon AV unit controlling some Technic's Speakers for my gaming/music
AMD 1100T OC'd to 3.85ghz per core/liquid cooled
OCZ Revo Drive 120gig for OS
2x Western Digital 2T drives (Raid 1 config for file backup/storage)
16gigs DDR3 1600 (1733 oc'd)
Radeon 6950 (lightly tweaked)
Quad 21.5" screens
It's alright, get's the job done.
HopnDude is offline
post #65 of 90 Old 07-25-2012, 01:39 PM
theonedub's Avatar
Rebuilt my secondary PC, but really want to build something smaller. Selling this one locally- its an i5 GTX 460 setup in a 500R case.
post #66 of 90 Old 07-26-2012, 08:22 AM
NUKKA!!!
JDnoble18's Avatar
That's a sick looking rig! How much are you expecting for it?
'07 Impala 3.5 102k
post #67 of 90 Old 07-27-2012, 02:19 AM
theonedub's Avatar
Thanks , I really like how it turned out.
I think total for the parts is about $750 retail + the Win7 Lic cost. I'd be alright with getting ~$650 or so to pay for part of my next build. I sold a similar computer albeit with a much weaker GPU and cheaper case for $550 last month, so I think the price is fair for my area. The longer it sits in my desk the more tempted I am to keep it, but it really is a little too much computer for what I need right now.
post #68 of 90 Old 08-29-2012, 01:20 AM
Erichhart's Avatar
User is: Erichhart is offline
Didn't Realize this thread was here.
Posting pics later,
*If anyone is down for a game of ARMA 2 or anything let me know
post #69 of 90 Old 10-28-2012, 06:05 PM
Nightmare
Von Rottes's Avatar
User is: Von Rottes is offline
Send a message via MSN to Von Rottes Send a message via Skype™ to Von Rottes
Mine is a princess.....
CPU: AMD Phenom II x4 925
GPU: Sapphire HD6870
RAM: 8gb Kingston HyperX blu
PSU: ThermalTake TR2 500watt
Motherboard: Gigabyte GA-970a-UD3
Cooler: Antec kuhler H2o 620
Fans: x2 push/pull 120mm, x2 120mm front intake x1 140mm side exhaust.
Case: Cooler Master HAF 912 With HAF 912 advance wide panel
Hard-drives: Western digital 500gb Green Media, 320gb Blue Games, 80gb Caviar OS.
Lights: logisys dual 12" CCFL
speeds:
CPU is at 3.5ghz
NB/HT is 2.5ghz
RAM is 1666mhz
GPU is 970mhz
RIP Joyce Fox
4/10/66-2/17/17
Nightmare
~ Thread Here ~ R.I.P
Betty White '92 SGT #0070 ~Thread Here
post #70 of 90 Old 11-03-2012, 01:18 AM
Solid Axle MOD
Sonomanclature's Avatar
Just got some parts in for my upgrade rig. I never looked at ta tape to actually figure the size of the case, little bigger than I expected. Dwarfs my Antec 900
Cooler Master Storm Trooper
AS Rock Fatality 990 FX (AMD)
Since I have always wanted one Logitech G510 ( still learning the key map, slightly off from my old 250 delux.
now Just have to order some ram and a new CPU.
94 Sonoma Dana44/60 5.7L 5spd
69 GMC C1500
06 Subaru Impreza
post #71 of 90 Old 11-05-2012, 10:32 PM
70chevelle8's Avatar
User is: 70chevelle8 is offline
The computer i bought at walmart in 2007.
Intel pentium d
vista
2gb ram
gigabite geforce gt220 graphics card
western digital caviar blue 500gb hard drive
seagate barracuda 250gb hard drive
pc power and cooling silencer mkii power supply
Just did the mods a month ago. It was my first time ever opening the case of a computer. Its for sale if anybody wants it.
I feed trolls.....
99 2.2 5 Speed Ex cab. - Totaled
01 Xtreme 4.3 Auto Ex cab. - Sold
02 Blazer 4.3 Auto 4 door. - Daily driver.
Youtube channel
post #72 of 90 Old 11-17-2012, 05:43 PM
User is: 5e3deluxe is offline
Macbook Pro, 2.2GHZ "Santa Rosa," 4gb RAM, OWC 128GB SSD, with numerous FW externals. Have a ThinkPadT30 I use for web QA. I don't actually work on the T30, just check how things render in Windows. I use Windows if someone pays me to do it, OTW, it's Mac all the way.
'98 Hombre, pretty much bone stock. Not interested in lowering, raising, or any of that. Just want a serviceable, economical truck.
post #73 of 90 Old 12-01-2012, 10:16 AM
JeremyCollins13's Avatar
User is: JeremyCollins13 is offline
Mine is probably the most basic computer here. Recently built a mini with microATX MB- biostar, 4GB DDR3 RAM - GSKILL, 400GB Western Digital HD, Lite On disk reader/writer (not blu ray though) and the cpu is Athlon 2. I think its 3.6 ghz. ITs currently running on the MB's built-in graphics but I have a card as well as a 1TB HD. Recently installed a built-in card reader. Aside from that I had to get a keyboard and mouse. Went through monoprice.com for those items. Total build with keyboard and mouse as well as 4 3ft usb extenders and a 15ft premium audio cable $300. Im quite happy with it. Its replacing my inspiron 9300 laptop that crapped out on me. That was an old pos laptop but it worked good while I had it. I got sick of that old laptop having no parts that could be upgraded (it was top of the line in its day $1600 laptop) I dont really push computers much at all so a basic one is plenty. A friend of mine has 3 over the top builds - i'll try to get pics/stats of them. They vary from $4500 water cooled down to about $2500. He also just built a mini server - 20 3TB HDs. I went to him one day and asked how cheap I could build a decent desktop and the parts order was placed that night. This is my 1st computer build and my 1st desktop. I built it myself in under an hour w/o issue and w/o any directions, working blind sorta. The case's front plate had a busted wire so the company sent me a replacement, turns out that wire is unused in my build so I may just airbrush the new plate for the hell of it.
Case was on sale $17 shipped http://www.newegg.com/Product/Produc...82E16811147123
Actually EVERY part of it was on sale and this was like a month ago.
After having built this Im extremely happy I didnt buy from walmart like i was going to. For the same price I would have some pos 32 bit system with a 1.6ghz dual core processor.... and all other stats matching or less than mine. Plus mine is New, not refurbished. I got a case I like rather than being stuck with whatever walmart offers. Mine is all decent brands too. The quality and features are far better than the premade trash in this price range. Im very happy with my computer. Quick question, how much ram would photoshop need?
post #74 of 90 Old 12-05-2012, 12:14 PM
Solid Axle MOD
got some more parts in, enough to make it run.
69 GMC C1500
06 Subaru Impreza
post #75 of 90 Old 02-27-2013, 02:53 AM
Solid Axle MOD
Bought the Girl a new case
69 GMC C1500
06 Subaru Impreza
post #76 of 90 Old 09-22-2013, 04:15 AM
little update on my setup... the internal card reader died so I need to replace it (any suggestions? just has to be windows 7 compatible and capable of reading sd, sdhc, micro sd, and micro sdhc cards but it would be nice if it also had usb port(s) on it as well) and my old 22" lcd monitor died too so I replaced it with a new 39" Insignia LED tv. Since this is my tv, computer, and video game console all in one the screen upgrade is very nice
Originally Posted by s10xtremist View Post
S10forum is a very open and accepting community.
^BULLSHIT
post #77 of 90 Old 09-23-2013, 08:10 AM
NUKKA!!!
JDnoble18's Avatar
http://www.newegg.com/Product/Produc...82E16820223109
That unit is nice, if you have room for an extra 3.5" device.
'07 Impala 3.5 102k
post #78 of 90 Old 09-23-2013, 07:11 PM
Thats exactly what I had. Complete pile of shit - kept making that "device disconnect" noise... sometimes 1-2 times a day, sometime 8 times in 3 minutes. Pissed me off so now it has a new home in the trash.
^BULLSHIT
post #79 of 90 Old 09-24-2013, 08:02 AM
NUKKA!!!
JDnoble18's Avatar
Haha, ok. I haven't used that one but it looked ok. I have used an HP take off similar to that though back in the day. I took it out because I hated having all the drive letters.....just bugged me to no end.
'07 Impala 3.5 102k
post #80 of 90 Old 10-09-2013, 05:41 PM
User is: dvotion is offline
Here's mine at least the top side of it...
Intel i7 930 @ 3.8ghz
12gb ddr3 1600 ram
an asortment of harddisks
2x MSI HD6970 1gb's
sound card
dvotion is offline
post #81 of 90 Old 01-14-2014, 10:42 AM
HopnDude's Avatar
Did some parts changes to my rig. Just a few small mods.
Sold the;
AMD Phenom II 3.3ghz x6
Antec Kuhler H2O 920 water cooling unit (got an RMA, sold the RMA)
Selling;
Radeon HIS IceQ 6950 2GB
Installed;
AMD FX-8350 4.0ghz x8)
Larkooler 330 Water Cooling Kit
Ordered;
2x Radeon Gigabyte R9 280X's
Currently I have it OverClocked to 4.6ghz per core, under stress test it sees roughly 50c which isn't bad at all.
I also picked up a new toy.
HP ProLiant GL380 G5p Dual Opteron 2.6ghz x6 core with 16gig ram and 8 146.4 SAS 10k drives with a dual 750w hot swappable power supply setup.
Picture was at my old house (just moved), sorry about the leopard print sheet, it was keeping the cold ass air off the electrical box from freezing my ass off at night.
^ before I swapped the processors, but shortly after I banked all the hdd bay's with sas drives. The HDD's are in 2x Raid 5 configuration.
I'll get everything all finished being setup in the new house, then I leave for Afghan in March. So it'll be waiting for my return for some gaming! The server is hosting a few VM's.
Minecraft (2x VM's currently running)
BF4 (VM setup, but I haven't looked into this yet to see if I can host it)
MW4 (same situation as VM above)
HopnDude is offline
post #82 of 90 Old 01-14-2014, 11:09 AM
NUKKA!!!
JDnoble18's Avatar
How do you like the larkooler?
Nice server BTW!
'07 Impala 3.5 102k
post #83 of 90 Old 01-14-2014, 12:32 PM
HopnDude's Avatar
The Larkooler 330, not to bad! It works pretty good. There's different configurations you can do for the radiator. My only gripe, is that it was missing the following screws.
Fan Grills > Fans
Fans > Radiator
I had 8 case fan screws laying around. Not a biggie there, but the other 8 I had to get from Lowes (home depot will not have them). They are really hard to find screws. But, for 1.18 I had the screws I needed to finish the install.
The pump is manually controllable (the speed). The CPU waterblock is designed like the expensive ass ones. The best part is that you can upgrade any of the components, add in video card water blocks if you'd like, etc.
Overall, for $130 from FrozenCPU.com it's not a bad buy.
EDIT: Thanks, the server is from a guy here in St Peters, MO. He get's them from the Military as they upgrade their hardware. I got it minus the drives, and with dual quad core 2.4's. So it's nice that I was able to upgrade that. I'd like to bank it with 24 or 36 gig's of ram though.
HopnDude is offline
post #84 of 90 Old 01-14-2014, 12:39 PM
Sans S10
Fannatick's Avatar
User is: Fannatick is offline
Wow, sweeet setup. I wanna grab one of those AMD 8350's for my next upgrade. Those 280's should be awesome.
That server is pretty sweet. I have access to a bunch of servers at work but I can't really justify it in my house. You gonna use that one for just VM's?
Originally Posted by JollyRojer
however had i jerked off first i woulda shown the bitch my heisman and been done.
1994 S10 Ext. Cab - 2.2 Auto, cherry red, manual everything - SOLD
2002 S10 Xtreme Ext. Cab - 4.3 - 5 spd - 2/3 drop, clear signals, Black with power windows/locks/mirrors - SOLD
post #85 of 90 Old 01-14-2014, 03:41 PM
HopnDude's Avatar
Yeah, that's pretty much all it's for. Not enough space for file storage. I've got two 2T WD Green drives in my Gamer on a Raid 1 config for storage. The server has maybe a total of 1T between both Raid 5 configurations.
HopnDude is offline
post #86 of 90 Old 01-14-2014, 09:00 PM
HopnDude's Avatar
New PB, hitting only 55c for a split second, hovering at 54c under constant load.
4795.09 x8
Settings;
218fsb
22x
1.48750v core
Found someone elses settings online. Gave them a shot, and their numbers turned out pretty solid.
HopnDude is offline
post #87 of 90 Old 01-18-2014, 11:25 PM
theonedub's Avatar
See there are some new PCs in the thread, my hardware has changed as well.
Current PC:
i7 3770K, GTX 680, 8GB RAM, 256GB SSD, & Full EK Water Cooling setup with dual 360 XTX Rads
Previous PC I am selling:
i5 3570K, GTX 780, 16GB RAM, 128GB SSD, Kraken AIO cooler, etc.
post #88 of 90 Old 02-12-2014, 06:15 PM
123-nico13's Avatar
User is: 123-nico13 is offline
have i7 4770k, asrock z87 fatal1ty killer,16 gig ram,120 gig ssd,1tb hdd,1.5tb hdd,evea 750w power supply,7870 powercolor myst ,27" planar monitor
post #89 of 90 Old 03-10-2014, 10:29 PM
DfntPntbll's Avatar
I got a new case and did some Sleeving with 550 paracord. I'm still working on it slowly, but it will eventually have a H2O setup. Pretty much the same specs, just new layout.
Case: Corsair Carbide AIR540 Black
CPU Type: Mobile QuadCore Intel Core i5-2500K, 4500 MHz (45 x 100)
Motherboard Name: GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 USB 3.0 ATX Intel Motherboard
Motherboard Chipset: Intel Panther Point Z77, Intel Sandy Bridge
System Memory: 16344 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: Corsair Vengeance LP CML8GX3M2A1600C9 4 GB DDR3-1333 DDR3 SDRAM (low profile to clear heatsink fan)
DIMM2: Corsair Vengeance CMZ8GX3M2A1600C9 4 GB DDR3-1333 DDR3 SDRAM
DIMM3: Corsair Vengeance CMZ4GX3M1A1600C9 4 GB DDR3-1333 DDR3 SDRAM
DIMM4: Corsair Vengeance CMZ8GX3M2A1600C9 4 GB DDR3-1333 DDR3 SDRAM
GPU1: AMD Radeon HD 6870 (reference design)
GPU2: AMD Radeon HD 6870 (reference design)
Disk space: 1.2TB
Input devices: Logitech g13 keypad, Logitech g600 MMO gaming mouse
Monitors: 2x 22" and 1x 28"
Cable routing done with cable combs from lutro0-customs.com
post #90 of 90 Old 12-29-2014, 10:44 PM
Maybe later.
tytotheler92's Avatar
This place sorta died..
I built a PC a few months ago, finally got the last few pieces that I wanted however I forgot to take a picture of that.
Before Video Card:
Whole:
Specs:
Operating System
Windows 7 Professional 64-bit SP1
CPU
Intel Pentium G3258 @ 4.20GHz (Overclocked from 3.20Ghz)
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 800MHz (10-10-10-30)
Motherboard
MSI Z97 PC Mate(MS-7850)
Graphics
2048MB ATI AMD Radeon R7 200 Series (MSI)
LCD 1 ([email protected])
LCD 2 ([email protected])
Storage
119GB SanDisk SDSSDHP128G SCSI Disk Device (SSD)
465GB Intel Raid 1 Volume SCSI Disk Device (SSD)
1863GB Western Digital WDC WD20EZRX-00DC0B0 SCSI Disk Device (SATA)
Optical Drives
HL-DT-ST DVDRAM GH24NSB0 SCSI CDROM Device
Audio
Realtek High Definition Audio
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
