Nintendo Controller to Air Ride Switchbox??? - Page 2 - S-10 Forum
post #51 of 72 Old 11-14-2008, 08:35 AM
paint color? ... Mud =D
83blazer28's Avatar
User is: 83blazer28 is offline
Re: Nintendo Controller to Air Ride Switchbox???
Originally Posted by MeltingPlastic View Post
yes that would work and yes it has been discussed... but it forces you to run new wires.. the wya im doing it your using the stock wires
how would you need new wires?
if you used like an SCR latch and a little relay you could run the bigger relay with the original nintendo wires
or maybe im not thinking far enough into it?
1983 blazer 2.8 - for sale
1970 mustang coupe - project
1989 C1500 Work truck - DD
post #52 of 72 Old 11-14-2008, 09:00 AM
Broken Handed Superman
MeltingPlastic's Avatar
User is: MeltingPlastic is offline
Send a message via AIM to MeltingPlastic
not thinking far enough into it.. the wires on the nintendo controller are serial data, clock, latch and 5v and gnd only.. to access the button commands you have to do what i'm doing which is using a shift register to convert the serial data back to parallel like they do IN the controller... reverse engineering man
Mike Grounded 4 Life
2002 X-Cab S10...
Project: The Cursed S10
post #53 of 72 Old 11-14-2008, 02:09 PM
83blazer28's Avatar
AH!
i understand now
believe it or not
post #54 of 72 Old 02-22-2011, 07:18 PM
User is: rroeder96 is offline
From what i read nobody has figured it out yet. I have the nes controller that does work my air ride in my truck....It took some time but I figured it out...
post #55 of 72 Old 02-22-2011, 07:23 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
User is: DJDAudio is offline
Send a message via AIM to DJDAudio Send a message via Yahoo to DJDAudio
Did you use the stock communication protocol? or just rewire the switches?
The opinions and views expressed in the above post are the intellectual property of DJDAudio. The above mentioned information shall also hold no legal binding against Doug DeHaven in the court of law.
---\\\CALCULATE Compressor fill time HERE ///---
QUOTE: (Kevdog00) "You sir are like the Einstein of Mini Truckin'! lol"
DJDAudio is offline
post #56 of 72 Old 02-23-2011, 12:15 AM
it is the stock controller only a few small mods had to be done but other then that its stock. Only thing that had to really change was the power output..
post #57 of 72 Old 02-23-2011, 12:17 AM
it also had to have a brain box designed by us here that the controller plugs into its about the size of a motorcycle battery...
post #58 of 72 Old 02-23-2011, 08:41 AM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Does your brain box, decode the controller? or are you just relaying the low current buttons to the valves directly?
Like Mike had talked about earlier, if anyone is interested in its serial protocol,
http://www.mit.edu/~tarvizo/nes-controller.html
It is an interesting system.
DJDAudio is offline
post #59 of 72 Old 02-23-2011, 09:25 AM
I figured it out, had it all simulated etc, just never did it.. No time nor interest really. It was just one of those things that i wanted to see if i could do. I'm sure i can dig up the simulation files somewhere on an old hdd or something. And you're right, you needed to change the power due to it being a 5V system and you having a 12-16v input basically
2002 X-Cab S10...
post #60 of 72 Old 02-25-2011, 04:50 PM
Well the guy i had figure everything out for me was a 50 year old baptist minister/ham radio operater. If I try to turn my morning alarm off it blows up in my face, so in short if i would of built this controller it would never work on anything again but now it works on my truck so im cool with who ever builds it.......
post #61 of 72 Old 02-25-2011, 07:20 PM Thread Starter
bank owned
kevdog's Avatar
User is: kevdog is offline
Damn... I totally forgot about this thread lol
[KEVIN]
- Ridin' Rich... Livin' Broke -
kevdog is offline
post #62 of 72 Old 02-25-2011, 08:33 PM
Yeah i brought it back from the dead after i found some old nes controllers hidden away and found myself wanting to build one for my dime, and now all the final test are done and the controller is working perfect....
post #63 of 72 Old 03-07-2011, 08:55 AM Thread Starter
bank owned
kevdog's Avatar
That's awesome! I would totally still be interested in this, but I took the air ride off of my truck.
[KEVIN]
kevdog is offline
post #64 of 72 Old 03-07-2011, 09:07 AM
b2200
98noma97's Avatar
User is: 98noma97 is offline
if i wasn't trying to sell my truck i would be all over this
[SIGPIC][/SIGPIC]
FOR SALE: http://www.mautofied.com/1988-Mazda-b2200_Mini-Truck/listing/100592144/
Originally Posted by joedoh View Post
holy geeze, they call em donks because thats the sound you make when you fall 4 ft to the ground. DONK
98noma97 is offline
post #65 of 72 Old 03-09-2012, 12:13 PM
svillarrial's Avatar
User is: svillarrial is offline
did anyone ever finish this controller i would like purchase one if someone can make it work
post #66 of 72 Old 03-09-2012, 12:22 PM
I've been looking to mess around with some stuff again(been bored and kinda broke lately) Maybe i'll dig up my old files or just start over... like i said, its pretty straight forward...
2002 X-Cab S10...
post #67 of 72 Old 03-10-2012, 01:05 AM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
Ill buy one if someone can build one to hook up to 8 valves....as long as its reasonably priced that is. This is cool
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #68 of 72 Old 05-15-2012, 05:27 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
So I now have the code and can make this work but...
COSTS:
$40 BS2 IC
$15 BS2 breadboard
$10 8X 5V relays
$10 NES controller reman.
$06 project enclosure
$05 5V automotive power supply.
$07 Terminal strips and grommets.
$93 Total with 0 Labor.
So for me to make any profit and cover my end I would have to sell a unit for $120
I doubt anyone would even think of paying that.
So for now I may build one with the parts I have.... just to say that I did
EDIT: I think this would go well with my Air Ride sofa haha
DJDAudio is offline
post #69 of 72 Old 05-15-2012, 05:32 PM
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
this may helpful for some of you not willing to cut the cord on your controller.
http://www.parallax.com/Store/Compon...2/Default.aspx
DJDAudio is offline
post #70 of 72 Old 06-23-2012, 10:25 AM
sick & twisted
1sikPuP's Avatar
User is: 1sikPuP is offline
so anything ever happen with this? im really interested in one..
bagged/bodied 88 Plymouth reliant,3/4 frame, SBC,49 ford shoebox dash
Zach
1sikPuP is offline
post #71 of 72 Old 06-25-2012, 01:45 PM
HopnDude's Avatar
User is: HopnDude is offline
Well, when it's done!....
I wanna see you type in some cheat codes, I wanna see what they look like in RW vs VG!....haha
HopnDude is offline
post #72 of 72 Old 06-01-2014, 11:07 PM
sick & twisted
1sikPuP's Avatar
im still really interested in this. ive been trying to learn PBASIC and program this on a basic stamp...anyone finish this yet? i really want one for my k car
Zach
1sikPuP is offline
You may post new threads
You may post replies
