Is the memory on a HP 15-g039wm laptop expandable? - S-10 Forum
post #1 of 5 Old 11-17-2014, 04:04 PM Thread Starter
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
Question Is the memory on a HP 15-g039wm laptop expandable?
I've read it has a single slot and the 4gb memory is expandable to 8gb all you have to do is change it out and I've read that it isn't. Which is it?
http://www.walmart.com/ip/HP-Sparkli...37065076#about
ℐustin
post #2 of 5 Old 11-17-2014, 06:46 PM
It really is a POS!
poS_10's Avatar
User is: poS_10 is offline
Re: Is the memory on a HP 15-g039wm laptop expandable?
I haven't seen a PC laptop yet that you couldn't swap out the ram on. crApple on the other had with all their infinite wisdom...
00 Blazer LT - Black 4x4 4DR, Dynomax Ultraflo welded Click here to hear it
04 S-10 Crew Cab SOLD
04 Trail Blazer LT EXT 5.3L 4x4 - seating for 7, 300hp, removed onstar 100%, but otherwise stock.
poS_10 is offline
post #3 of 5 Old 11-17-2014, 06:58 PM Thread Starter
ZQ8 Blazer's Avatar
ok thanks.
ℐustin
post #4 of 5 Old 12-07-2014, 07:19 PM
LSX Jimmy
moon509's Avatar
User is: moon509 is offline
Send a message via MSN to moon509
Swapping the ram is easy, here is what I found. "This HP PC memory is upgradable to 8GB, this HP PC only has one memory slot, you will have to remove original memory to upgrade. The memory this HP PC supports is the DDR3 PC3-12800."
I actually took my old laptop apart and put in a new motherboard and upgraded the cpu, you need to know what chipset you have to upgrade the cpu. It was very cheap to do.
2000 GMC Jimmy 2wd 2 door / LQ9, L92 heads, 224/230 cam and LS3 intake, She has been parted, stripped and retired.
1998 Pontiac Firebird Formula, engine from the Jimmy and a built t56
2006 Trailblazer SS
2000 Olds Bravada- SOLD
moon509 is offline
post #5 of 5 Old 12-08-2014, 01:05 AM Thread Starter
ZQ8 Blazer's Avatar
okay, thanks for the input.
ℐustin
