Steering play - S-10 Forum
post #1 of 8 Old 03-30-2019, 12:09 PM Thread Starter
Bozziebear's Avatar
User is: Bozziebear is offline
Steering play
So my daily is the 94 s10 extended cab in my profile pic. I'd like to keep it running pretty much forever but the one thing I've been bothered by is steering play. I know it's a second gen but considering the steering column for these was a one year deal that I'd have better luck on this side of the forum. I've seen these things with worse play than mine but I want to nip it in the bud before it even starts to get worse. What should I look out for?
post #2 of 8 Old 03-30-2019, 12:33 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Steering play
Doesn't matter 1st or 2nd gen. You need to check all of the moving parts for play and replace as needed. Moog parts are the preferred choice.
BTW....this belongs in Steering/Suspension so....
Apple Red 96 SS
post #3 of 8 Old 03-30-2019, 01:00 PM Thread Starter
Bozziebear's Avatar
Sorry, I'm still relatively new on here and only have a chance every so often to post... so I'm still not great at navigating the site. So it'd pretty much be down to the steering box and the column joint then. The steering linkage was all in good shape when I checked out the entirety of the suspension a couple months back.
post #4 of 8 Old 03-30-2019, 01:35 PM
B4U Task Force
Re: Steering play
How did you check the individual components? It makes a difference.
Apple Red 96 SS
post #5 of 8 Old 03-30-2019, 09:33 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: Steering play
If all that checks out look into replacing the rag joint with a flaming river joint or a Jeep steering shaft swap. I doubt the problem is in the column itself.
TelAmeriCorp
post #6 of 8 Old 03-30-2019, 09:44 PM Thread Starter
Bozziebear's Avatar
Visual inspection for damage and corrosion. Checked every joint in the linkage for play. The toe on the truck is perfect and it drives straight as an arrow. So that'd leave me with the steering box and the rag joint. I'd much rather it be the joint than the steering box itself
post #7 of 8 Old 03-30-2019, 09:50 PM Thread Starter
Bozziebear's Avatar
I've seen the jeep shaft swap done a couple times and I may look into it. It seems to be a tougher shaft and I'm planning on upgrading it to be a decent performer. Due to a college student budget that's going to have to wait I'm afraid but it's proven to be as capable as any 2wd full size truck I've ever driven. Granted I've yet to tow anything behind it but that'll also wait until I have other projects to work on as well.
post #8 of 8 Old 03-30-2019, 10:13 PM
Mr Goodwrench's Evil Twin
thebadwrench's Avatar
User is: thebadwrench is offline
Re: Steering play
If it's been a few months since you checked out the steering system, I'd check it again now. A part that was in good working condition a few months ago may now have slop in it. I would get a friend to sit in the truck and move the steering wheel ONLY through its range of play, wiggle it back and forth. Tell them as soon as they feel resistance in one direction, go the back the other way. Do this with the front wheels on the ground and the truck not running so the front wheels themselves stay as stationary as possible.
While they are moving the wheel back and forth, look under the truck and look at the tie rods, inner and outer. Any play in them should be fairly visible by checking it in this manner. Also look at the drag link, there should be no up and down movement in it. If there is, it'll need an idler arm (VERY common in these front ends), a pitman arm or both. If the play is in the rag joint, just like the tie rod ends it should be fairly easy to see. The steering box could be sloppy too, in which case you'd see the input shaft of the steering box moving but little to no movement in the pitman arm.
How do you know the toe is perfect? How is the tread wear on the front tires?
14 years Professional Automotive Repair Tech. If you attempted to fix it, it will now cost you more for me to fix
My DIY Guide to OBD2 Scanners
"Blind belief in authority is the greatest enemy of truth" - Albert Einstein
"Ignorance is never a valid excuse" - Me
Similar Threads
94' S10 power steering to manual... Grumpystoys10 S10 / Sonoma 0 12-28-2017 06:38 PM
power steering for a 1987 s10 2.5 l engine possible or not?! Arnd Steering & General Suspension 1 05-29-2017 09:24 AM
Sources for New or Decent Reman Steering Box Yoder Steering & General Suspension 8 02-22-2017 02:31 PM
Rag Joint (flexible steering coupler) bobnorway Steering & General Suspension 4 11-16-2016 02:37 AM
