Steering making grinding noise - S-10 Forum
post #1 of 6 Old 06-10-2014, 03:25 PM Thread Starter
p61
p61's Avatar
User is: p61 is offline
'92 S-10. Steering making a grinding noise when I turn the wheel. It is not a belt noise. You can also feel it in the steering wheel a little.
p61 is offline
post #2 of 6 Old 06-10-2014, 05:28 PM
95supertruck's Avatar
User is: 95supertruck is offline
Re: Steering making grinding noise
Have you replaced any steering/suspension components recently? New wheels?
Brandon
1998 rcsb "xtreme clone", L33 5.3, 4l60e, 3.73, AWD
A link to my build
https://www.s10forum.com/forum/f30/5-is-alive-517535/
post #3 of 6 Old 06-10-2014, 06:23 PM Thread Starter
p61
p61's Avatar
Nothing new.
p61 is offline
post #4 of 6 Old 06-10-2014, 06:39 PM
If have someone turn the wheel while you look under the hood to see if that gives you any direction. I'd start with the power steering pump, then the gear bod and then keep going from there
Brandon
A link to my build
post #5 of 6 Old 06-11-2014, 01:25 AM
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
low fluid?
ℐustin
post #6 of 6 Old 07-01-2014, 06:46 AM
User is: jezy is offline
Hi I have rebuild front end and when I took a truck from a shop I have noticed grinding when I have maxed steering to the side no matter left or right , so I went back with a complaint but they showed me that tires are to wide and they hit something underneath. But after 2 days im not so sure about the wheels besides those wheels werent changed and I didnt noticed grinding before. SO Im confused... stock tires are 235 and I have 255 and the noise is like metal to metal not a rubber to metal
and I saw your comment about new suspension like in my situation, could you elaborate please?
its 4.3 extcab auto trans 1995 4x4
jezy is offline
