Spohn front end rebuild kit. - S-10 Forum
post #1 of 17 Old 12-22-2018, 12:59 PM Thread Starter
User is: Bottlefedcamaro is offline
Have any of yall used their steering/front end kit? It comes with center link, idler arm, inner and outer tie rods, adjusters and ball joints as an option. With upper and lower ball joints the kit is $356.80. Does anybody know whose competents are in the kits and if Its all serviceable? Ive used a drive shaft and a couple suspension pieces from them on a fbody I used to have and they were good solid pieces
post #2 of 17 Old 12-22-2018, 01:46 PM
User is: dime-dozen is offline
Re: Spohn front end rebuild kit.
pretty sure they dont make all those parts
cant go wrong with Moog tho
post #3 of 17 Old 12-22-2018, 01:54 PM
oldeerslayer's Avatar
Call them and ask. The description is too brief to really get much insight.
https://www.spohn.net/shop/1982-2003...-S-10-2WD.html
post #4 of 17 Old 12-22-2018, 04:07 PM Thread Starter
I emailed them just thought Id ask here in the mean time. Looking at the description of the ball joints, it sounds awfully similar to moogs problem solver joints, the cap has spohn stamped in it but reading the description, Id say its moog stuff, no way they make parts like that themselves
post #5 of 17 Old 12-22-2018, 05:44 PM
And if everything is Moog, you can probably put together your kit at Rockauto for less. Maybe even substitute some ProFrged stuff in there. Consider replacing your control arms. Those bushings wear out and by the time you buy the bushings and the ball joints, the whole control arms aren't that much more.
post #6 of 17 Old 12-22-2018, 07:35 PM Thread Starter
That kit can be pieced together on rock auto with moog parts for $271.90, FYI.
post #7 of 17 Old 12-23-2018, 07:25 AM
Since you just saved $80 consider Proforged for a few bucks more for each component. They have a lifetime warranty.
I just looked,Moog does, too.
That could come in useful the way S10's eat idler arms and ball joints. Save all the paperwork.
post #8 of 17 Old 12-23-2018, 11:10 AM Thread Starter
The kit in pro forged stuff is $305. Will probably go that route. I’m having a hard time deciding how to go about this. Truck needs brakes and wheel bearings, and like you said, might as well do control arms too. But it’s my dd, would be nice to do everything at once but that’s a lot of work to do over a weekend and it absolutely have to be done by that weekend
post #9 of 17 Old 12-25-2018, 03:25 PM
B95
Early Member
B95's Avatar
User is: B95 is offline
I would do brakes and wheel bearings first. Then control arms. If possible use 2 different weekends.
1995 Black S-10 X-Cab 4.3 CPI. '96 Jimmy 4dr Power-leather seats. '97 Camaro gauge needles. '98/99 Bravada core support, headlights and grille. Envoy bumper cover and fog lights. 2" drop spindles. Headlight wire upgraded with relays. Blazer floorshift and console. '96 Blazer leather steering wheel and air bag. '96 Jimmy leather door panels. 310,xxx miles. ZQ8 steering box. SS Mirrors.
B95 is offline
post #10 of 17 Old 12-25-2018, 11:55 PM
Or do one side one weekend and the other the following week. When you do your tie rod ends, measure the existing ones carefully and try to duplicate the dimensions.
Then get an alignment done by a reputable shop that does more than just a quick toe in adjustment. And tell them you just replaced everything.
post #11 of 17 Old 12-26-2018, 03:40 AM
jayyk31's Avatar
User is: jayyk31 is offline
Go proforged 100%
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #12 of 17 Old 12-26-2018, 02:53 PM Thread Starter
Spohn kit is proforged components
post #13 of 17 Old 12-26-2018, 10:47 PM
Harley's Avatar
User is: Harley is offline
I keep getting notified that the proforged centerlink is super cheap on Amazon. Nearly $40 each right now, which is $20 off MSRP with free Prime shipping. They've been knocking them down by about $2-3 at a time over the last week or two. FYI for anyone who wants to buy some steering parts.
http://a.co/d/fsxadB5
Harley is offline
post #14 of 17 Old 12-26-2018, 11:36 PM
any idea of the COO on the Moog and Proforged?
post #15 of 17 Old 12-27-2018, 01:31 AM
Harley's Avatar
Probably Venus.
Quick google came up with this thread:
https://www.chevelles.com/forums/16-...proforged.html
Harley is offline
post #16 of 17 Old 12-27-2018, 09:34 AM
would Venus be POO?
thanks for the good info
I use USA first if its available and decent quality
Im going to look at our local parts house,maybe NAPA and see if theres any USA stuff.
I need an idler for my 03 so on the hunt.
post #17 of 17 Old 01-01-2019, 11:19 PM Thread Starter
Originally Posted by dime-dozen View Post
would Venus be POO?
Any luck on USA parts?
