Power Steering Question - S-10 Forum
post #1 of 5 Old 08-04-2018, 10:23 PM Thread Starter
92sonomaguy's Avatar
User is: 92sonomaguy is offline
I have a 92 s10 and I am going to convert it to power steering, do I need to use the tie rod arms that came with the power steering or am I ok to use the old ones off my manual steering truck?
post #2 of 5 Old 08-06-2018, 06:40 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Re: Power Steering Question
I'm pretty sure the only difference is the steering gear and the pitman arm. Everything else should be interchangeable.
TelAmeriCorp
post #3 of 5 Old 08-06-2018, 06:46 PM
Mattie L.'s Avatar
User is: Mattie L. is offline
As long as it is the same model year yes, you can reuse them
1997 s10
http://www.cardomain.com/ride/3071889
1969 El camino
post #4 of 5 Old 08-15-2018, 08:01 AM
jayyk31's Avatar
User is: jayyk31 is offline
Keep the manual sttering box pitman arm with the manual box and the power box pitman arm with the power box. Dont mix the power steering gear box with the manual gear box pitman arm. (Friggin tongue twister, lol!) . Everything else will stay the same.
-NEW DAILY. '86 Blazer 54k miles!!!
https://www.s10forum.com/forum/f20/my-new-gem-815417/
'92 EXTENDED Cab 408 LSx t56 Magnum!!!
Build thread-
https://www.s10forum.com/forum/f213/l...56-n-a-665850/
-2000 RCSB 2.2 5 speed.... SOLD!!!
jayyk31 is offline
post #5 of 5 Old 03-06-2019, 08:57 PM
I'm super serial
manbearpig's Avatar
User is: manbearpig is online now
I know this is an older thread but the later 4-bolt cap manual boxes use the same pitman arm as the power box. Only the early 3-bolt tops use a different pitman arm and center link.
