Outfitters Designs 1 Ton Idler Arm Bracket - S-10 Forum
post #1 of 5 Old 03-05-2019, 09:46 PM Thread Starter
jacobxj17's Avatar
User is: jacobxj17 is offline
I have a 2000 ZR2 and I am considering putting on that 1 ton idler arm bracket outfitter designs sells, (https://www.outfitterdesign.com/1-to...m-bracket.html) , wanted to see if anyone had already put it on and seen any improvement from it. I want to do a 2 in body lift and the 2.5 inch RC suspension lift with some 33x10.5r15. Want to make the steering components stronger with the bigger tire set up.
post #2 of 5 Old 03-05-2019, 10:16 PM
ZR2_Fury's Avatar
User is: ZR2_Fury is offline
Re: Outfitters Designs 1 Ton Idler Arm Bracket
I made my own one ton idler bracket for mine. Ive had it on for around 40k miles now, haven't had steering play since.
Sent from my HTC U11 using Tapatalk
ZR2_Fury is offline
post #3 of 5 Old 03-05-2019, 10:54 PM Thread Starter
jacobxj17's Avatar
Do you have the blue prints for that bracket you made?
post #4 of 5 Old 03-07-2019, 10:06 PM
Sonoma RS's Avatar
User is: Sonoma RS is offline
I installed their 1 ton idler arm bracket on one of my trucks about four years ago. It has worked fine so far. I had to replace the stock idler arm every two years. The 1 ton arm has made it four years.
post #5 of 5 Old 03-11-2019, 11:56 PM
ZR2_Fury's Avatar
I don't at the moment but i can take measurements for you if you want.
I have the truck apart so its easy to get to.
ZR2_Fury is offline
Similar Threads
Idler arm ramp7 S10 / Sonoma 3 03-05-2019 11:29 AM
Idler arm issues cougardryvr Steering & General Suspension 5 12-23-2017 02:20 PM
S10 Zr2 4x4 upper control arm replacment issue Brandon1987 Steering & General Suspension 4 12-14-2017 09:52 AM
lower control arm bracket to small Greybeard Steering & General Suspension 16 09-28-2017 08:52 PM
Ovals! So many ovals! My accessory bracket tried to rip itself from the head :( Kilgore Trout 2.2L - 2nd gen 4-banging 2 07-23-2017 08:38 PM
