lower ball joint removal - S-10 Forum
post #1 of 9 Old 03-22-2019, 01:40 PM Thread Starter
hyenad's Avatar
User is: hyenad is offline
Exclamation lower ball joint removal
I'm having a hard time removing the lower ball on my 1993 gmc jimmy. any help would be greatly appreciated
hyenad is offline
post #2 of 9 Old 03-22-2019, 07:50 PM
User is: dime-dozen is offline
Re: lower ball joint removal
what tools are you using? shop press? ball joint removal/installer?
post #3 of 9 Old 03-22-2019, 10:35 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Rent balljoint removal service from auto store. And use torch or MAPP to heat up the balljoint then press out what you can as well as hitting it dead on with a small sledgehammer.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #4 of 9 Old 03-22-2019, 10:49 PM
B4U Task Force
Rhotpursuit's Avatar
3# sledge is just about right. Support the lca, hold the treaded niece upright with a pickle fork and have at it.
Apple Red 96 SS
post #5 of 9 Old 03-22-2019, 11:54 PM Thread Starter
hyenad's Avatar
Thanks guys I will give that a try
hyenad is offline
post #6 of 9 Old 03-23-2019, 08:52 AM
TranceAmerica's Avatar
User is: TranceAmerica is offline
I did a two press procedures for each ball joint, first straightened and pressed out the stud with a cup under the surrounding the housing and just the clamp head. The second with a cup the same way under the housing from below then a cup above to press out the ball joint housing, only sledged very little to get the housing to fall through.
post #7 of 9 Old 03-23-2019, 09:18 AM
User is: ACLR8R is offline
Just rent the press, removal is usually pretty easy. I had a much harder time putting them back in, even with the ball joint in the freezer and heating the LCA, I was using a 3ft breaker bar to press them back in.
1997 SS, High Compression 5.3, Torquer V2, Milled 706 heads, 3200 FTI
ACLR8R is offline
post #8 of 9 Old 03-23-2019, 10:15 AM
Forum Dictator
What?'s Avatar
Issue with re-installing balljoint is not being leveled/even while being pressed in. You can use hammer and tap it to even back up. Otherwise it'll go in at angle and wouldn't be installed properly. It'll take couple tries to get the hang of it.
What? is offline
post #9 of 9 Old 03-23-2019, 01:21 PM
a piece of pipe just large enough to fit over the ball joint thats square cut can be used to determine if its going in straight.
If you are doing bushings,best to use a shop press.
Similar Threads
Tall lower ball joint question worm Performance Suspension 3 03-31-2017 03:02 AM
Moog ball joint problem Jhagan1980 Baggin' It 1 06-25-2016 10:36 PM
Lower ball joint boot 2wd Rhotpursuit Steering & General Suspension 6 06-07-2016 01:54 PM
Lower ball joint help Davecubs14 Steering & General Suspension 6 06-06-2016 08:36 PM
