help removing super rusty front shocks. - S-10 Forum
 1Likes
  • 1 Post By Rhotpursuit
post #1 of 9 Old 03-27-2018, 09:09 PM Thread Starter
User is: mrrcom is offline
hey guys, got any tricks for removing the nut off the upper shaft of the front shocks?
i was trying a wrench and vice grips on the end but the threads are pretty much destroyed from rust. i was thinking about trying to cut the shaft but i cant see a space i can fit a 4.5 grinder
the new wheels look tight though
mrrcom is offline
post #2 of 9 Old 03-27-2018, 09:59 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
Re: help removing super rusty front shocks.
Used a sawzal when I had a 2wd
Sent from my iPhone using Tapatalk Pro
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #3 of 9 Old 03-27-2018, 10:14 PM
Harley's Avatar
User is: Harley is offline
If you're installing new shocks just take a grinder or sawzall to the nut itself. The large washer and bushing below the nut should be replaced and the new shock should come with them anyway, so don't worry about mucking them up.
Harley is offline
post #4 of 9 Old 03-28-2018, 08:42 AM
992drjimmy's Avatar
post #5 of 9 Old 03-28-2018, 02:21 PM
LS3 Cruisin'
98Sonosls's Avatar
User is: 98Sonosls is offline
For tight spaces like that I use a dremel, or an air die grinder with a 2" diamond disc in it. My sawzsall is too big to use on stuff like that. I have a right angle and straight air die grinder so one or the other usually works for me.
Other option is carefully use a set of torches to cut through the stud... assumes you A: have a set and B: know how to use them well .
Third option- soak it with wd45/pblaster for a few days and use vicegrips...
Fourth: same as above but use a propane torch to heat it up- then spray with wd40... the heat helps suck the wd40 into the rusted threads.
post #6 of 9 Old 03-28-2018, 02:34 PM
jrd1962's Avatar
User is: jrd1962 is offline
Dremel works good due to lack of room.Be sure to have plenty of cut-off wheels.
'01 S10 RCSB 2.2 5spd. daily driver-182,000 miles and counting
'87 Silverado-all original-279,000 miles
'86 3/4 ton 4x4 currently in pieces
jrd1962 is offline
post #7 of 9 Old 03-28-2018, 03:46 PM
Joe Cool's Avatar
User is: Joe Cool is offline
I helped a friend change his front shocks and we could only get about 5 turns on the top nut before it locked up. Ended up using a small hacksaw to cut it below the nut. Kind of a last resort, but it worked.
Joe Cool is offline
post #8 of 9 Old 03-28-2018, 06:04 PM Thread Starter
i didnt even think of the dremmel. my sawzall is kinda bulky and looks like i couldnt even get a blade into there.
could i use the plasti-dip in a can and shmoo it all over the new threaded area when i put them in? i was thinking it would solidify and keep this from happening again
mrrcom is offline
post #9 of 9 Old 03-28-2018, 07:43 PM
B4U Task Force
Rhotpursuit's Avatar
Try anti-seize instead.
98Sonosls likes this.
Apple Red 96 SS
