Help! Don’t know where to find suspension parts for ZR2 - S-10 Forum
post #1 of 19 Old 02-22-2019, 02:10 PM Thread Starter
Tykub1's Avatar
User is: Tykub1 is offline
I’ve looked around the web a bit and I’m trying to find new control arms, tierod, and ball joints for a 2003 s10. There have been a few suspension kits from summit racing or a1 auto I have found but the do not specify if they are compatible with a zr2 or not. I know the suspension on a zr2 is different from a normal 4x4 but I’m not sure which parts are interchangeable and which ones I would have to get specifically for a zr2. Any help or links to parts would be greatly appreciated!
Tykub1 is offline
post #2 of 19 Old 02-22-2019, 02:47 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Help! Don’t know where to find suspension parts for ZR2
I've gotten all of these parts at Rockauto with the exception of control arms...didn't need them.
Apple Red 96 SS
post #3 of 19 Old 02-22-2019, 03:12 PM Thread Starter
Tykub1's Avatar
thanks! I’ll check it out
Tykub1 is offline
post #4 of 19 Old 02-22-2019, 03:44 PM
oldeerslayer's Avatar
User is: oldeerslayer is online now
AFAIK the ZR2 uses the same suspension parts as the regular 4wd except the centerlink which is longer and has the extra hole for the stabilizer. There is also an issue with the lower control arms for one as new as yours. No one seems to make them with the sway bar mount in the correct location. Some of the guys simply found an earlier ZR2 sway bar because the late model location is weak anyway. An improvement GM should not have made. Or the other option is to reuse your control arms and do the extra work of replacing the bushings and ball joints.
See this and go down and read all the negative reviews;
https://www.amazon.com/Moog-RK620464...ustomerReviews
Here's a pic of the early and late ZR2 LCA
post #5 of 19 Old 02-22-2019, 04:08 PM Thread Starter
Tykub1's Avatar
thank you very much this is exactly what I needed to know!!!
Tykub1 is offline
post #6 of 19 Old 02-22-2019, 11:02 PM
Lifelong S-10 Owner
67Truckin's Avatar
User is: 67Truckin is offline
Send a message via MSN to 67Truckin
We bought hubs, all ball-joints, brake parts etc from our local O'Reilly's and some from Amazon. Never had any issue getting whatever part we needed. 1994 ZR2 S-10 pickup.
Built... not bought. Scars to prove it.
post #7 of 19 Old 02-23-2019, 12:51 AM
OK, Rockauto to the rescue. They list Blazer 4wd LCA and Blazer ZR2 LCA separately with pictures of each part. They fit pickups, too.
https://www.rockauto.com/en/catalog/...trol+arm,10401
Only issue is they are the R Series which is Moog's low priced line with a 3 year warranty.
In the problem solver series, their HD upgraded LCA's, Rockauto only lists the right lower CK620464.
I suppose you could call Rockauto to find out if they can get the left lower problem solver CK620300
I found the number in an email from my son in law who is a district manager for Advance Auto. He contacted his rep at Moog last fall for me. They make the PS line for both sides and Moog provided the numbers. They are more money, but those LCA's have a lifetime warranty including the ball joints.
post #8 of 19 Old 04-05-2019, 08:04 PM
992drjimmy's Avatar
User is: 992drjimmy is offline
Detroit axle. Always had good results with them
Sent from my iPhone using Tapatalk Pro
*97 GMC JIMMY 4x4 on AR wheels with 275/60/15(SOLD)
*02 GMC Sonoma Highrider(ZR2) with 3" body lift on 15x8 ion wheels, 5.5" backspaced with 33x12.50 kumho road venture MTs
*98 MUSTANG GT Not at all Stock.
*01 Monte Carlo SS fully loaded
post #9 of 19 Old 04-17-2019, 10:01 PM
RedGuitars's Avatar
User is: RedGuitars is offline
I ordered a 12 piece kit from A1 Auto online. $85. Labor is $375.
My first quote was $3K so Iím pretty happy.
post #10 of 19 Old 04-17-2019, 10:12 PM
B4U Task Force
Re: Help! Donít know where to find suspension parts for ZR2
My first quote was $3K so I’m pretty happy.
$85 for 12 pieces...Lego blocks? You get what you pay for....
Apple Red 96 SS
post #11 of 19 Old 04-17-2019, 10:32 PM
RedGuitars's Avatar
Moog wanted $500 for the same kit. It’s an old truck. Just trying to keep it on the road for a few more years.
post #12 of 19 Old 04-17-2019, 10:36 PM
B4U Task Force
Same pieces...doubt it was the same quality...or lack of. These kits pop up every so often, and the buyers has buyers remorse after installing it...good luck though.
Apple Red 96 SS
post #13 of 19 Old 04-18-2019, 03:27 PM
RedGuitars's Avatar
Here is the kit - and it's 1A Auto, not A1.
https://www.1aauto.com/steering-and-...=621355&y=2001
post #14 of 19 Old 04-18-2019, 03:29 PM
992drjimmy's Avatar
Same stuff youíd get at parts stores. Just be sure to keep things grease. Since it doesnít appear they have zerks use a needle on your grease gun under the boot. Iíd install the stuff myself though. Itís not that hard.
post #15 of 19 Old 04-18-2019, 03:31 PM
992drjimmy's Avatar
Iíve always had great luck with Detroit axle. The parts Iíve gotten from them fro many trucks and cars have always had grease zerks.
post #16 of 19 Old 04-18-2019, 04:12 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
They're local to me and I've dealt with them face to face. Nice parts and a good bunch of people. I've used their stuff on 10 or so vehicles.
TelAmeriCorp
post #17 of 19 Old 04-19-2019, 09:12 AM
Hardhead
User is: eshaw is offline
I know the OP is working on a later model ZR2 but isn't there a difference in CV's also when dealing with early and late ZR2 vehicles? My understanding is that the ZR2 has different CVs than a base 4wd model and there are bolt on CVs for the early Z that are the same length and will interchange for both sides versus the slip in style that has two different lengths. Is this correct?
1998 ZR2 extended cab. Lots mods to go!
eshaw is offline
post #18 of 19 Old 04-19-2019, 09:36 AM
992drjimmy's Avatar
You canít interchange the slip in style CVS for the bolt in. Unless you swap
The whole differential. The cvs are also longer on zr2 vs
Non zr2.
post #19 of 19 Old 04-19-2019, 11:24 AM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
No greasable parts = short life + no control arm bushings so more money to spend. Buy quality parts that can be greased with synthetic grease and you will be money ahead in the long run. Do it once, and do it right! Like the man said before you get what you pay for!
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
Similar Threads
Air Ride Suspension Parts Shawn F. Suspension 9 01-01-2018 08:19 PM
RockAuto.com Discount Code for Parts & More - Expires January 3, 2018 RockAuto RockAuto 0 10-04-2017 11:00 AM
Where to find best prices on MOOG parts buildafriend Performance Suspension 12 07-24-2017 08:36 PM
RockAuto.com Discount Code for Parts & More - Expires October 3, 2017 RockAuto RockAuto 0 07-03-2017 04:27 PM
RockAuto.com Discount Code for Parts & More - Expires July 3, 2017 RockAuto RockAuto 0 04-03-2017 10:46 AM
