C6 corvette steering wheel swap with airbag - Page 2 - S-10 Forum
Closed Thread
post #51 of 90 Old 05-20-2013, 11:02 PM Thread Starter
LSX Jimmy
moon509's Avatar
User is: moon509 is offline
Send a message via MSN to moon509
Re: corvette steering wheel swap R&D
2000 GMC Jimmy 2wd 2 door / LQ9, L92 heads, 224/230 cam and LS3 intake, She has been parted, stripped and retired.
1998 Pontiac Firebird Formula, engine from the Jimmy and a built t56
2006 Trailblazer SS
2000 Olds Bravada- SOLD
moon509 is offline
post #52 of 90 Old 05-22-2013, 01:05 AM Thread Starter
LSX Jimmy
moon509's Avatar
ok, I am almost there. I have some pics of removing the tilt pivot bushings. I ordered a tool for $20 shipped on impulse, then stopped by a hardware store for $1.15 worth of bolts and nuts to make the tool. Using a socket as a spacer I threaded the 8-32 bolt through with a washer on top. Turning the nut pulls the bushing out. It was pretty easy. Remove the tilt spring before pulling the bushings.
After removing the bushings I pulled the top half off and installed the new upper shaft. I didn't get pics of that because my hands had grease on them.
wheel installed. I need to trim the column cover, the rim sticks out too much
2006 Trailblazer SS
moon509 is offline
post #53 of 90 Old 05-22-2013, 01:08 AM
B4U Task Force
Rhotpursuit's Avatar
Nice work as usual...you have too much time on your hands....lol
Apple Red 96 SS
post #54 of 90 Old 05-22-2013, 01:23 AM Thread Starter
LSX Jimmy
moon509's Avatar
Now for the hard shit! The clock spring does not line up with the holes on the vette wheel. I had to trim some plastic from the clock spring in the lower circled portion. The wire still has yellow covering level with the clock spring. The trimming did the trick, not the horn spring is the other issue. I can't fix it until I get the other wheel puller from AutoZone.
I am posting what I am doing and any mods you make are at your own risk.
2006 Trailblazer SS
moon509 is offline
post #55 of 90 Old 05-22-2013, 01:25 AM Thread Starter
LSX Jimmy
moon509's Avatar
Time, lol. I do this in between work and life. Yesterday was my day off. I went grocery shopping until 2pm, came home put that crap up and pulled the ford 8.8 out in the driveway to clean up. Then cleaned up the garage to back the jimmy in and pull out the column along with the front bumper to get at the trans cooler. I'm like a rabid rabbit on my free time!
thanks for the props! Helps when you don't have kids.
2006 Trailblazer SS
moon509 is offline
post #56 of 90 Old 05-22-2013, 02:01 AM
B4U Task Force
So...what did you do with the rest of the day...haha...
Apple Red 96 SS
post #57 of 90 Old 05-22-2013, 01:57 PM Thread Starter
LSX Jimmy
moon509's Avatar
The clockspring has been trimmed around the wires, the horn plug has been trimmed also. They both fit behind the steering wheel now with no issues.
If you removed the tilt pivot bushings remember to stake them again after you install them. I used a hammer and metal chisel to put three nicks around the bushing to keep them in.
pic of the clock spring where I trimmed plastic away from the base of the wires.
The horn wires had a long plastic tube that goes through a hole on the wheel, the vettes do not have this so I had to shorten the tube enough that it would still go in the ring but not stick out too much.
soldered the horn wire to the wheel horn wire and got rid of one of the wires. I don't need two.
The column cover had to have the neck trimmed down to clear the steering wheel back cover. I used an angle grinder with a sanding disc to take it down a little at a time until it cleared.
She's ready to go. I am going to keep it out while I swap out my hydroboost pump. Need all the clearance I can get.
2006 Trailblazer SS
moon509 is offline
post #58 of 90 Old 05-22-2013, 02:19 PM
GM Addict
User is: koots is offline
Awesome work!!
I always admired the steering wheel in my 04 2500HD parts truck, but it wouldn't fit my 02' 2500HD. Now I can just swap out the columns (or at least the upper shaft) and have it fit right on.
Thanks for doing the legwork!! I've had those tilt columns pulled and rebuilt before and they do eat up some time. Luckily I bought the pivot pin remover tool beforehand
koots is offline
post #59 of 90 Old 05-22-2013, 02:27 PM Thread Starter
LSX Jimmy
moon509's Avatar
Originally Posted by koots View Post
Awesome work!!
Yea, I bought the tool also, but was impatient and made my own for $1.15. Now ill have a $20 tool laying around. Ill sell it for $10 shipped if anyone reads this and wants it.
2006 Trailblazer SS
moon509 is offline
post #60 of 90 Old 05-22-2013, 09:20 PM
sprinterman52's Avatar
User is: sprinterman52 is offline
looks awesome. So I dont remember which airbag set up did you go with since you had a few to try out? Or did you not end up using it?
2002 2.2l 5 speed ext cab. OBX header, ASP underdrive pulleys, Magnaflow cat and exhaust, Spectre filter, 56mm throttle body, ZQ8 Front and Rear Sway bars. Boss 4 channel amp for 2-6x9's in boxes in the back and 2- 6.5's in the doors.
Now a Mitsubishi Big 16G turbo mounted in the front.
post #61 of 90 Old 05-22-2013, 11:04 PM Thread Starter
LSX Jimmy
moon509's Avatar
I am going to use the 2007 express van, its a single stage unit The fit seems tight in the cover, if I feel its a lot tighter then the vette one ill try a gto unit. I know that has been done on another forum. Most expensive part is buying a vette bag unit to take it apart only to use the cover and back cover. My cost's so far
$40 for a 09 vette column, wheel and deployed airbag. (Don't think anyone will get one cheaper. I was lucky)
$70 new leather wrapped wheel
$35 1999 s10 airbag (was way to big to use)
$50 2007 express van airbag
$250 2006 corvette airbag unit. (bought off a corvette forum member)
$400 is a bit much for a wheel swap, but its unique as long as it functions as intended
2006 Trailblazer SS
moon509 is offline
post #62 of 90 Old 05-23-2013, 08:04 AM
I turn.
rentedmule's Avatar
User is: rentedmule is offline
$400 isn't that ridiculous - a new Momo wheel can be $200+ and the hub adapter is close to $100.
'09 G8 GT
'95 Firebird Formula auto-X build
'03 4.3L heads, cam, turbo donor for future 1st gen project
Red Jimmy '94 4dr 4wd, stock. Sold
Auto-X truck with stuff bolted to it and unbolted from it. Sold
post #63 of 90 Old 05-26-2013, 05:38 PM Thread Starter
LSX Jimmy
moon509's Avatar
New wheel is in! Airbag will be here Thrusday. Ill test drive before that, just waiting on some fittings for my trans cooler.
2006 Trailblazer SS
moon509 is offline
post #64 of 90 Old 05-27-2013, 06:42 AM
GM Addict
Nice work, gives me lots of ideas now for interior mods.
02' 2500HD Silverado- LQ4/4L80E...basically stock...
83' GMC Jimmy K5- 6.2 Diesel/TH350 swap
95' Chevy Corsica- 2.2/3T40 daily driver/sleeper project.
koots is offline
post #65 of 90 Old 05-27-2013, 01:01 PM
That 3D picture dude guy
DfntPntbll's Avatar
User is: DfntPntbll is offline
Send a message via AIM to DfntPntbll Send a message via Yahoo to DfntPntbll
Wow. clean work so far. *subscribed*
1998 Ext. Cab S-10 4.3L bagged front/lowered 6" and rear disc
1993 Std. Cab S-10 4.8L bagged, traditional 3.25" BD
ASE Certified Alignment Tech
post #66 of 90 Old 05-27-2013, 07:32 PM Thread Starter
LSX Jimmy
moon509's Avatar
I was testing the horn after install and found no toot. After looking at the steering wheel I see the vettes actually have a power and ground to the horn switch on the wheel where as the s10 grounds to the wheel it self. I took the ground wire on the vette wheel (its small and had a small connector) soldered it to a small washer and put the washer between the spoke cover and metal part of the wheel. Plugged it all back and hit the horn toooooooooooooot! Just so you know.
2006 Trailblazer SS
moon509 is offline
post #67 of 90 Old 05-31-2013, 10:01 PM Thread Starter
LSX Jimmy
moon509's Avatar
Got this today. I have been driving it for two days. I like the smaller 3 spoke wheel over the 4 spoke. When I get home tonight ill transplant my bag and igniter in to this.
2006 Trailblazer SS
moon509 is offline
post #68 of 90 Old 06-01-2013, 11:39 AM Thread Starter
LSX Jimmy
moon509's Avatar
I put the two igniter bag units side by side for comparison. They are close enough. I did put two long zip zips around the unit to keep it from spreading out on insertion. The vette unit actually has a wrap around it.
Putting the unit in the cover was not bad. I used the end handle of a screw driver to push the corners in and pull the rubber over the tabs. Just took my time and it went in fine.
Airbag system went through it's checks and no airbag light BAM. "I HAVE EXORCISED THE DEMONS, THIS HOUSE IS CLEAR!"
Can we make this a sticky and is it worthy. Remember this is what I did, not you. You go F#ucking around with your SIR system and get a face full of bag, NOT MY FAULT. (Public service announcement)
2006 Trailblazer SS
moon509 is offline
post #69 of 90 Old 06-03-2013, 01:51 AM
Maybe later.
tytotheler92's Avatar
Damn! You should get some leather seats or solid colored 02+ fabric seats and that wheel will not look out of place at all. Looks great either way!
1988 S-15 - 5.5/6 drop
1985 S10 Blazer 4WD
1998 Blazer ZR2 5 Speed!
post #70 of 90 Old 06-03-2013, 10:45 AM
a mintruck is never done
sonoma2bdifferent's Avatar
User is: sonoma2bdifferent is offline
nice swap and very different
post #71 of 90 Old 06-06-2013, 07:40 PM
User is: twomanyjeep is offline
The ultimate test is slamming the front bumper with a baseball bat and seeing if the airbag goes off
Just kidding: great work as usual, very easy for me to do something similiar (and I know, it would be done at own risk)
post #72 of 90 Old 09-16-2013, 12:31 AM
Emmett8181's Avatar
User is: Emmett8181 is offline
Re: C6 corvette steering wheel swap with airbag
Want to do the wheel swap just looking for the right one for the right price
Sent from AutoGuide.com App
post #73 of 90 Old 09-16-2013, 05:07 AM Thread Starter
LSX Jimmy
moon509's Avatar
yea, I hear ya. The vette airbag was the single most expensive piece and I only used the cover. I picked up the wheel it self for about $70 new. It was listed for a pontiac solstice, but its the same as the vette.
2006 Trailblazer SS
moon509 is offline
post #74 of 90 Old 10-02-2013, 10:06 PM
User is: c2vette is offline
And here I was trying to figure out how to put a leather S10 wheel in my HHR SS. Seriously though, great engineering job, and thorough info for anyone willing to tackle it. Well done !
c2vette is offline
post #75 of 90 Old 10-02-2013, 11:38 PM Thread Starter
LSX Jimmy
moon509's Avatar
thanks man!
2006 Trailblazer SS
moon509 is offline
post #76 of 90 Old 12-30-2013, 04:10 PM
User is: JOESMTOY is offline
Really looking for another post and an update.....
I have a 2004 vette and I am doing the swap as well.
Really looking for an update on the airbag situation
Joe
PS GREAT work so far the corvette forums have nothing on you.
JOESMTOY is offline
post #77 of 90 Old 12-31-2013, 02:52 AM Thread Starter
LSX Jimmy
moon509's Avatar
Joe
What kind of pics and update you looking for. Its been going strong. I haven't have an SRS light so I won't know until I hit something.
2006 Trailblazer SS
moon509 is offline
post #78 of 90 Old 01-01-2014, 10:44 AM
I finally finished reading the entire thread..... brought tears to my eyes.
You should charge for that much info. I have ordered all e parts and I will be walking down this same path soon.
thanks fr all your help.
Joe
By the way maybe I can just send you all my parts and you could put them together for me???
JOESMTOY is offline
post #79 of 90 Old 01-01-2014, 12:03 PM Thread Starter
LSX Jimmy
moon509's Avatar
Joe
When I figured out the tilt piece was the same I was amazed no one else figured it out. Luckily for me I was able to buy a whole c6 steering column from a guy for $40. The only part I can't stress enough is the airbag system. I can't condone what I did to anyone or be held responsible if someone else attempts it and has a problem. Just make sure if you do swap out the bag, the connectors are then same. Let me know if you have any questions.
2006 Trailblazer SS
moon509 is offline
post #80 of 90 Old 01-02-2014, 04:10 PM
Could you verify the air bag part number for me.... it looks like 16866042 is the right one.
JOESMTOY is offline
post #81 of 90 Old 01-02-2014, 08:35 PM
User is: ppi12x4 is offline
If the SRS light is off its good. The module continually monitors the integrity of the system.
03 cobra with a few bolt ons.
89 s10 project
89 rcsb on 01 zq8 frame. Comp 270hr cam, 10:1 4.3, 97 nv3500 w4m tune
mr2 turbo
ppi12x4 is offline
post #82 of 90 Old 01-02-2014, 11:45 PM Thread Starter
LSX Jimmy
moon509's Avatar
Airbag from the truck? or vette?
2006 Trailblazer SS
moon509 is offline
post #83 of 90 Old 01-03-2014, 11:42 AM
From the truck.
I have the airbag from a c6 which I only need the cover.
I just need the airbag from a gm truck so I can change the mounting bracket and install to the c6 cover.
JOESMTOY is offline
post #84 of 90 Old 01-03-2014, 01:22 PM Thread Starter
LSX Jimmy
moon509's Avatar
From the truck.
I dont have a part number. I searched ebay and it seems there using the gm number on the cover, so when you search by that number its giving me single and dual stage units.
2003-2007 chevy express van or 2500HD silverados. I bought mine off ebay and they can be had for around 50-60. Just preview the pics to make sure the connector is the same. I was going to solder on the right airbag connector had mine not been right. Some say thats a bigger no-no but I would have done it with out a problem. If you have more detailed questions shoot me a pm with a number and ill give you a call.
2006 Trailblazer SS
moon509 is offline
post #85 of 90 Old 03-23-2014, 09:15 PM
mitchr97's Avatar
User is: mitchr97 is offline
is there any way to hook up air bags to a 92 s10? I don't want to die in an crash, but as a 16 year old, I cant afford a newer car.
mitchr97 is offline
post #86 of 90 Old 03-25-2014, 12:31 AM
svmcgover's Avatar
User is: svmcgover is offline
NO. there is a LOT of engineering that goes into air bag systems. there are a ton of sensors and computers incorporated into the system, and it would be very difficult to throw something together yourself.
It could be done, but it would take alot of money to do it properly. SRS systems are something you don't want to cut corners on because if you do, they will cause more harm than no airbags at all.
wear your safety belt, drive conscientiously, and use common sense and you should be fine.
But bravo for making safety a number one concern!!
post #87 of 90 Old 03-26-2014, 08:19 PM
mitchr97's Avatar
Thanks. I kinda figured there were computers involved. I only ask because I know there are lots of retard drivers out there. I've only had my lisence for 4 months and I've almost been in 3 accidents... AND my friend just got rear ended in his brand new car by a girl texting and driving ( she rear ended him doing 50, after skidding for 50 feet. he was at a complete stop)
Thanks for the help!
mitchr97 is offline
post #88 of 90 Old 04-03-2014, 03:32 PM
User is: Costelloboy is offline
Well I read this all and WOW!!! I'm in but honestly not even gonna try to make the airbag work. I just one question could you wire up the steering wheel controls to work?
post #89 of 90 Old 04-03-2014, 03:35 PM Thread Starter
LSX Jimmy
moon509's Avatar
Not sure on this. You might be able to use the s10 clockspring with wheel controls and wire it to the switches on the vette wheel. I think it depends on if the switches are the same style. I thought about this but the wheel was in and I didnt want to spend anymore money.
2006 Trailblazer SS
moon509 is offline
post #90 of 90 Old 04-03-2014, 06:19 PM
B4U Task Force
One thing you may want to keep in mind when messing with airbags...the chemical (sodium azide) that makes them go boom will also kill you if inhaled or ingested. Last I heard, there is no antidote. If you have a broken or leaking container of this stuff be very careful.
Apple Red 96 SS
Closed Thread
