Pushrod tube size - S-10 Forum
post #1 of 2 Old 07-06-2015, 12:29 PM Thread Starter
Sum Dude's Avatar
User is: Sum Dude is offline
Pushrod tube size
Any engineering gurus out there know what size and or wall thickness of tubing I should be using for my rear cantilever pushrods? Based on what I found out about buckling and deflection, the length is important (and I understand the shorter the better) so I will say they have of length of 12".They will be mounted at 90* vertical at ride height with heims on both ends. I would prefer to use weld-on tube end nuts versus tapping a thick wall tube. Im looking for something in between F1 carbon fiber and 1.5" 1/4"wall rock crawler but with the safety/ overkill intentions of a dd in mind. Thanks for any and all suggestions!
Sum Dude is offline
post #2 of 2 Old 08-15-2015, 09:26 PM
IRSd_mini's Avatar
User is: IRSd_mini is offline
Re: Pushrod tube size
I used to do a lot of cantilevers. I would use 1" x .156 wall and either direct thread it 3/4-16 or drill it to the size for 5/8-18 threaded ends to fit.
Larry
www.innovativeairsuspension.com
Building a custom truck... Buy your parts from someone that actually builds them
