post up some pics of your welds. - Page 6 - S-10 Forum
post #251 of 265 Old 01-01-2014, 12:56 AM
NOW AIR RIDE EQUIPPED!
vortec97's Avatar
User is: vortec97 is offline
Send a message via AIM to vortec97
Re: post up some pics of your welds.
Seems like my posts are backwards but here's the weave and that's obviously 2 razor blades : )
....1997 S10 LT1/TH400 just a little Neil Chance converter, slammed w/33mm, QA1 #450 coilovers, poly bushings, caltracs, 3" lowering leafs, 2" blocks, ROH Snyper wheels DAILY DRIVEN! building a 6.0 w/LS3/L76 combo/E85 should be a killer.
vortec97 is offline
post #252 of 265 Old 01-12-2014, 07:55 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
Did some stainless for the first time today. its on a keg for a home brewing station.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #253 of 265 Old 01-26-2014, 11:59 AM
Tech Mod
beandip's Avatar
Some more stainless.
Who needs engraving when you can weld it?
Welded a retainer clip to the 5th gear.....it was on a free T-5 Trans my buddy got for his car. said the 5th gear popped out. took it apart and found the retainer was worn out and there was a chip on the output shaft where the clip broke it off or something....doesnt matter, free transmission, probably will hold up fine. kept the heat real low. gear never got hot to the touch.
-Jonathan
beandip is offline
post #254 of 265 Old 02-10-2014, 12:18 AM
*Just Do It*
Fabrication Addiction's Avatar
User is: Fabrication Addiction is offline
Quick shot
post #255 of 265 Old 02-16-2014, 09:38 AM
User is: GaneshMoto is offline
Stuff.. stainless and alum.
Completed project www.moto-studio.com
ID:	159457   Click image for larger version
ID:	159465   Click image for larger version
ID:	159473   Click image for larger version
ID:	159481   Click image for larger version
post #256 of 265 Old 03-16-2014, 04:14 PM
*Just Do It*
I thought these turned out pretty smooth
post #257 of 265 Old 03-16-2014, 05:57 PM
Tech Mod
beandip's Avatar
^ they sure did! I really need to buy some pipe just to practice radius welds.
This wrench was cracked, so i did a little repair for fun.
-Jonathan
beandip is offline
post #258 of 265 Old 05-27-2014, 09:14 PM Thread Starter
Bagged
chevy power's Avatar
User is: chevy power is offline
Send a message via AIM to chevy power
At work our weld test are a fillet joint and a 6" pipe welded to a flat plate. Being able to do the radius well and having a good attitude are how people get jobs where I work. Spray arc MIG around a radius is a bit more tricky than a simple multi pass fillet joint. Im still having a hard time feeling comfortable around a radius with TIG.
post #259 of 265 Old 05-28-2014, 12:21 AM
Tech Mod
beandip's Avatar
^ thing is i dont do it often enough. really i try to get a long bead on the piece, when i should really be doing smaller beads and not try to overextend myself around the corner...
some people at work said the wrench repair was a waste of time. i dont care, free practice and even so, its still a good usable wrench if i were to put a cheater pipe on it in the end it was a Proto wrench so not exactly a "junk" brand.
-Jonathan
beandip is offline
post #260 of 265 Old 06-03-2014, 04:03 PM
plskthompson's Avatar
User is: plskthompson is offline
I'm not a frabricator, nor a welder, but I'm having to build a set of ramps for a trailer that I bought. My dad took a lot of welding classes in school many many years ago, so he's attempting to teach me how to weld a little at a time. This is a picture of my second ever bead. It's not exactly pretty, but in my opinion, it isn't as bad as it could have been.
1998 S10 LS 2.2 Auto with 207,xxx on the clock.
Click the pic for my build thread.
post #261 of 265 Old 06-26-2014, 09:48 PM
Tech Mod
beandip's Avatar
made a 1" crows foot for work. kind of a specialty tool because the turnbuckle to tighten the #80 chain has little room around it. I could just buy a regular crows foot, but this way it wont fall off the extension, and i have the 1 1/8" on the other end to tighten the jam nut.
Untitled by bean4dip, on Flickr
-Jonathan
beandip is offline
post #262 of 265 Old 07-03-2014, 11:51 PM Thread Starter
Bagged
Still kind of new to TIG but here are some link bars I made a while ago.
Spray arc 555 IPM 29.5 Volts 95/5 gas. I need a pic of a few radius welds, anyone can weld a straight line.
post #263 of 265 Old 07-31-2014, 04:02 PM
*Just Do It*
A lil stiffer I added
post #264 of 265 Old 02-07-2016, 04:52 PM
LOOK AT MY NIPPLES!
IhaveNoPantsOn's Avatar
User is: IhaveNoPantsOn is offline
Gonna do a little digging here...
Finally bought a welder yesterday, and did a few quick passes.
First attempt
2nd
Third, filling a slight gap
Not nearly as good as some in here, but not bad for my first time in almost 12 years.
S-10's - because they're cheap and easy, and I'm poor and lazy
RIP Scotty 'Gimp' Oliver 6/6/84 - 5/31/16
MyTruckHasNoPantsOn!
Junkyard Gem
post #265 of 265 Old 02-07-2016, 11:31 PM
Hey guys watch this!!!
ToLows10's Avatar
User is: ToLows10 is offline
MIG
My Old Blazer
https://www.s10forum.com/forum/f3/my-...f-pics-466111/
The New S10
https://www.s10forum.com/forum/f30/my...ckhalf-736129/
My back tires are STILL wider then your motor!
ToLows10 is offline
