post up some pics of your welds. - Page 3 - S-10 Forum
post #101 of 265 Old 04-05-2012, 08:05 PM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
Re: post up some pics of your welds.
We have a microwave that we put a 100w light in and made it where it stays on. It works awesome and its how we been doing it for years.
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #102 of 265 Old 04-05-2012, 08:55 PM
Registered Asshole
rstadelmaier's Avatar
User is: rstadelmaier is offline
Yeah I hate when people do that at my work. 6013's aren't supposed to go in an oven. They have a water based flux, but we do and i never noticed a difference.
because i just can't be normal>>> https://www.s10forum.com/forum/f125/p...ckhalf-488914/
post #103 of 265 Old 04-12-2012, 11:42 PM
Tim89's Avatar
User is: Tim89 is offline
orb of traction for my truck. specs in sig.
front spring mount, buddy came and checked out the new welder(lincoln 170hd) and he welds with the curly Qs and i did c's before. first time doing that method. i dont have any current but alot better now.
c stitch
his weld(guess where he started)
mine
94 s10, hp60 front 5.13, 14 bolt, disc converted, lincoln locked, 5.13s, all ss brake lines, 5spd swap with 17.5 inches of lift on 44" tsl's with M/T true Beadlocks, full custome 1/4" bumper. R.I.P
2013 silverado 1500 lt ex cab w/tow pkg.
07 yfz450 full sparks exhaust, Jetted, Boysen high flow water pump, 13t front sprocket, itp hole shots.
03 trx400ex under construction.
01 polaris scrambler 500 4x4 wife's toy
Tim89 is offline
post #104 of 265 Old 04-13-2012, 09:21 AM
PANFACE
blznnp's Avatar
User is: blznnp is offline
Send a message via AIM to blznnp Send a message via Yahoo to blznnp
Tim, how long did it take you to weld up those spiders like that?
'12 ram 2500 diesel.....stock
1995 4 door blazer, 6.0 LQ4, 40" Mtr/kevlar , 1 ton axles, 5.38 gears....
68 camaro LS3, T56
blznnp is offline
post #105 of 265 Old 04-13-2012, 12:01 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
"Orb of traction" LOL!
Getting better with every failure
Project threads:
Punching bag
Unicorn XJ
post #106 of 265 Old 04-13-2012, 10:17 PM
Tim89's Avatar
About 4 total with cool down then ground down. Google orb of traction it will show you an guy doing it step by step.. I know it should have taken longer so it had proper cool down time but was tired of it being apart on my bench
Tim89 is offline
post #107 of 265 Old 05-01-2012, 07:06 PM Thread Starter
Bagged
chevy power's Avatar
User is: chevy power is offline
Send a message via AIM to chevy power
I just bought a tig I am gettig into that a bit now. Have to post some pics up soon of more mig welds. Some of your guys tig stuff makes me jealous. It's a whole new art. Migs boring compared to tig.
post #108 of 265 Old 05-10-2012, 07:10 PM
Hot Rod Enthusiast
s10kid17's Avatar
User is: s10kid17 is offline
Just learning how to weld properly. I started today with some pretty thick steel. What can I do to make them better? Should I trace the pool larger so the weld doesn't look so close together?
Mike.
s10kid17 is offline
post #109 of 265 Old 05-10-2012, 07:59 PM
22 psi...stock
low-s-dime's Avatar
User is: low-s-dime is offline
Send a message via AIM to low-s-dime
read the how-to's i posted
Dan
04.5 2500HD LLY CCSB 4wd
07 impala SS
mig...tig...stick...any questions
low-s-dime's (lincolnmetal) welding learning center
http://www.gmtruckforum.com/fab-shop/
s10forum.com member since 2002
post #110 of 265 Old 05-10-2012, 08:28 PM
Hot Rod Enthusiast
s10kid17's Avatar
Thanks, I didn't see them at first. Ill be sure to read through them all. Hopefully they'll answer all my questions.
Mike.
s10kid17 is offline
post #111 of 265 Old 05-13-2012, 08:36 PM
Mafia Customz
mafiacustomz's Avatar
User is: mafiacustomz is offline
Send a message via Yahoo to mafiacustomz
Im no pro welder but it dont look like you are hot enuff or dont have a high enuff wire speed maybe both.
The last welder i had HF 151 dual mig blow up welding exhaust 1 year old so i dumped that shit and ordered a hobart handler 187 and a tweco fire and skull auto darkening helmet i cant wait.
S.E.S.
post #112 of 265 Old 06-03-2012, 09:40 PM
Tim89's Avatar
recent welds i did.
Tim89 is offline
post #113 of 265 Old 06-11-2012, 02:40 PM
I <3 Primer
noma97's Avatar
User is: noma97 is offline
Haven't stopped by this site in a long time but I'll try to remember to snap a few tonight of some welds on some stainless restaurant equipment.
Here's a mig weld on 3/16" plate. It was a lap joint and this was a repair on my dad's equipment trailer jack.
Project Truck:97 Sonoma extended cab,built small block,t56,explorer 8.8,4" stockfloor,new frame from the firewall back,20's,finally gonna get paint.
Frame should hopefully be ready for some '08 shows.
My Truck
noma97 is offline
post #114 of 265 Old 06-11-2012, 09:26 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
suppose ill post up my booger welds.
the part is a hand operated pallet jack handle that bent, then snapped. 2 "L" brackets welded on opposite sides. the square tubing is 14 gauge, the brackets are 1/8" plate.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #115 of 265 Old 06-11-2012, 11:17 PM
Tim89's Avatar
Noma97, what method do you use or do you just have that steady of a hand. Nice bead
Tim89 is offline
post #116 of 265 Old 06-11-2012, 11:27 PM
Warheads on Foreheads
Z06killinsbf's Avatar
User is: Z06killinsbf is offline
post #117 of 265 Old 06-12-2012, 08:05 AM
I <3 Primer
noma97's Avatar
Push and pause with a slight weave and thank you. I'm self taught in MIG, Stick, and TIG but I've also taken a few classes to learn about the metallurgy.
My Truck
noma97 is offline
post #118 of 265 Old 07-14-2012, 03:43 AM
First Gens FTW!
Kansas Dime's Avatar
User is: Kansas Dime is offline
Layed this down a few hours ago with a Lincoln 175. Sorry for the crappy iPhone pic, but I was happy with it and it will get the job done.
post #119 of 265 Old 09-27-2012, 05:53 PM
gmc666's Avatar
User is: gmc666 is offline
3 pass 1/8" 7018 fillet weld
first pic is fully welded out and second shows every layer of the weld.
gmc666 is offline
post #120 of 265 Old 09-27-2012, 08:59 PM
Dems 22s
mattadams13's Avatar
User is: mattadams13 is offline
I laid this down earlier today on a quick bracket i made to hold a regulator at work. I use the cursive e technique.
Matt Adams
Project thread: Laying on billet 22s https://www.s10forum.com/forum/f30/si...thread-486853/
post #121 of 265 Old 09-27-2012, 10:11 PM
User is: frostystones is offline
It's the only pic I can find at the moment...
This is a test done by the CWB (Canadian Welding Bureau)
For those interested, there was an approx. 1/2" gap, I had to fill it with weld, I could make as many passes I needed yet not let the weld go 1/8" over the plate. (hope that makes sense.)
plus after they cut a 1/4 inch(or 3/8" not sure) off each end, the weld can not be below the plate as well. The weld length was 8 inches.
as you can see, no flaws. Passed 100%
I was so nervous waiting a week for the results.
post #122 of 265 Old 09-29-2012, 02:22 AM
NOW AIR RIDE EQUIPPED!
vortec97's Avatar
User is: vortec97 is offline
Send a message via AIM to vortec97
work area when cars in garage
playing with TIG pulse/standard settings
http://sphotos-a.xx.fbcdn.net/hphoto...74989048_n.jpg
and this is is from tonight 9/29/12 1:21AM
....1997 S10 LT1/TH400 just a little Neil Chance converter, slammed w/33mm, QA1 #450 coilovers, poly bushings, caltracs, 3" lowering leafs, 2" blocks, ROH Snyper wheels DAILY DRIVEN! building a 6.0 w/LS3/L76 combo/E85 should be a killer.
vortec97 is offline
post #123 of 265 Old 09-29-2012, 02:22 AM
vortec97's Avatar
TIG from same time
vortec97 is offline
post #124 of 265 Old 09-29-2012, 11:20 AM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
Welded with a miller diversion 180 tig
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #125 of 265 Old 10-02-2012, 01:00 AM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
this is how my welds look
tohoopty is offline
post #126 of 265 Old 10-02-2012, 11:25 PM
vortec97's Avatar
TIG Miller syncrowave 200
vortec97 is offline
post #127 of 265 Old 10-25-2012, 11:55 PM
tsayyote's Avatar
User is: tsayyote is offline
Need some input on an etch thats on a 1/4" test plate i did. I've never really "read" an etch before and don't know really if I achieved optimal penetration for this size plate. What's the general rule for penetration? 20% of the metal thickness?
Done with Miller 211 on 230v at recommended settings in flat position. .035 L-56 Lincoln solid wire 75/25 gas and a beveled edge. A stringer root and a 2nd pass with an inverted V weave.
Best pic I can get right now of the weld face
'00 S10, 5.3L/T-56 swap under way, ext. cab, metallic space blue, FBSS
'02 S10, 4.3L Auto, ext. cab, olympic white, 3/2 lift, 31" tires - The old DD
'02 Ranger, 2.3L manual, ext. cab, island blue metallic, lowered 2/3 - The new DD
tsayyote is offline
post #128 of 265 Old 10-26-2012, 08:36 AM
Dems 22s
We do cut and etch daily at work. in the automotive industry penetration percentages varies from customer to customer. I really dont think you are going to have to worry about that weld failing though.
Matt Adams
post #129 of 265 Old 11-06-2012, 10:34 PM
I drive
SoloSDN's Avatar
User is: SoloSDN is offline
Havent used my welder in a long while. But we finally finish the sfbd frame for my jimmy. Heres a couple of the welds
SoloSDN is offline
post #130 of 265 Old 11-07-2012, 04:20 PM
User is: Stay Tuned is offline
Some nice welding but also some nice fab work in here too!
Green Hornet Movie Car Suicide Door Hinges
A shocker Turbo manifold half complete
Log Style SBC Twin Turbo manifolds
Coarse Pie Cuts
We ported out the housing to match the 38mm external wastegate to eliminate Zero Boost more common to collector mounted wastegate setups.
Some Special Order Lambo Door Hinges Welds are painted but still kinda interesting to look at
post #131 of 265 Old 11-08-2012, 11:09 AM
vortec97's Avatar
^sick
vortec97 is offline
post #132 of 265 Old 11-14-2012, 10:36 PM
Tech Mod
beandip's Avatar
some pics of the welds ive done in the past on a few projects.
custom length shackles.
piece of sway bar from a full size, rough cut and welded (both sides and ends) to my buddies drag bumper.
notch
shock bar.
final result.
bumper ive built for a buddy.
not really any closeup pics but oh well.
Still learning new things
-Jonathan
beandip is offline
post #133 of 265 Old 11-16-2012, 01:51 PM
User is: Fish&chips is offline
I want my welds to be as good as some of them
post #134 of 265 Old 11-16-2012, 07:18 PM
User is: happyisthealero is offline
Stay tuned that is some great work!
post #135 of 265 Old 11-20-2012, 07:49 PM
Thanks for the comment, i'd like to point out the nice welds beandip and many others on here. I do a lot of welding on the bench whenever possible. Its a whole lot harder to do it on a vehicle upside down and vertical!
post #136 of 265 Old 11-20-2012, 08:24 PM
I know what your saying. I've done a little and its tricky.
post #137 of 265 Old 12-04-2012, 04:15 PM
User is: pavmentscreaming is offline
I built my tig welder, Rewired my mig welder to run dc negative on the tig torch. Flip two switches and it turns back into a mig welder. The tig lead pushes into the front of my welder and then you turn to lock. cost me 400.00 and a set of balls to tear into my new mig welder to do the conversion. yep Its a hybrid.
ID:	129333   Click image for larger version
post #138 of 265 Old 12-04-2012, 06:17 PM
Sold :'(
^^^ Cool stuff!
Project threads:
Punching bag
Unicorn XJ
post #139 of 265 Old 12-09-2012, 11:42 PM
headroom
MNbdblazer's Avatar
User is: MNbdblazer is offline
Messin around with some aluminum lap welds and a stainless t joint .
ID:	129408   Click image for larger version
Nasty Lowz
94 blazer(project stock)
post #140 of 265 Old 12-21-2012, 10:28 PM Thread Starter
Bagged
Making some brackets for a york 210. And a couple other pics I took at work. Loving the TIG, havent had much time on it, out of position and around a radius I suck, love the control though. Welded a friends turbo oil feed line when he was in a pinch a few months ago, never would have turned out so good with MIG.
1/2" weld, 1 root pass and 2 covers passes, End of a boom that would hook onto a front end loader. Very hot spray arc mig at work. That will be used to hold a lot of weight.
Honda civic Crankshaft holder tool, for removing the crankshaft bolt.
Customers trailer, rusted out was very dangerous he towed it over missing over 2/3 of the tube on the front. Had to make my own tube out of 3/16" plate. Thank god for my plasma cutter.
Merry Christmas! Just made this yesterday out of a bunch of scrap.
post #141 of 265 Old 12-26-2012, 10:47 PM
Tech Mod
beandip's Avatar
few pics from when i was building my bumper. all 3/16". dont remember why i stopped halfway through this weld.
15" continuous bead.
3/4" plate to 3/16. beveled and welded with a good root pass, then a final pass. should have turned the heat up a tad more.
-Jonathan
beandip is offline
post #142 of 265 Old 12-27-2012, 01:09 PM
The last pic looks good non-the-less. I was actually surprise by the size of the material. Glad you explained it.
post #143 of 265 Old 12-27-2012, 08:10 PM
post #144 of 265 Old 12-27-2012, 10:50 PM
Tech Mod
beandip's Avatar
well i figured its only as strong as the metal its welded to. doesnt look like its beveled much but it is quite a bit.
it is a quite sizable chunk of steel. thickest i have ever messed with.
also full penetration from the back of the bumper. this is where i had 2 pieces corner to corner 90
-Jonathan
beandip is offline
post #145 of 265 Old 01-09-2013, 07:42 PM Thread Starter
Bagged
When we are welding something very heavy at work, we have to make multiple passes. A root and two covers is most common, some things however have about 10 passes, makes for a very large weld and a lot of heat. Even if you only have a 110 welder you can achieve great strength on the right joint with enough passes.
post #146 of 265 Old 01-29-2013, 04:35 PM
Registered Asshole
post #147 of 265 Old 02-19-2013, 03:39 AM
Registered Asshole
post #148 of 265 Old 03-23-2013, 05:57 PM
Hey guys watch this!!!
ToLows10's Avatar
User is: ToLows10 is offline
My Old Blazer
https://www.s10forum.com/forum/f3/my-...f-pics-466111/
The New S10
https://www.s10forum.com/forum/f30/my...ckhalf-736129/
My back tires are STILL wider then your motor!
ToLows10 is offline
post #149 of 265 Old 04-02-2013, 10:33 PM
tohoopty's Avatar
heres one of mine.nothing special
Originally Posted by The Griff View Post
I looked at my asshole in the mirror today. It blew my ****in' mind!
tohoopty is offline
post #150 of 265 Old 04-03-2013, 12:23 AM
tohoopty's Avatar
and another one
tohoopty is offline
