post up some pics of your welds. - Page 2 - S-10 Forum
post #51 of 265 Old 02-25-2012, 11:33 AM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
Re: post up some pics of your welds.
Originally Posted by low-s-dime View Post
Dude...get some better pictures of this joint...more clear on this angle, a shot looking at the side, and one towards the back of the c-channel.
Sorry I havent seen this thread in a while. There are a ton of pics of it in the link in my sig.
To the discussion about using C channel and why its on top of the frame, The bed that I HAD and was going to use was cut up kinda wierd. My way of "bracing" the floor so that the back of the notch cover wouldnt be loose or flex was this. The hole ended right on top of this bar so it braced the bed floor. I wanted to mount it in the frame, But also wanted to brace the floor so this was the way I went about doing it. but I junked the bed so now its just there
And thanks for the constructive critisism When people point out stuff I do wrong or where I could have done better it will help me when I do my next one. Ill admit I could have built something that looked a little better, But this was my first time building something like this. I wasnt too worried about how it looked since I was going to cover it
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #52 of 265 Old 02-27-2012, 10:01 PM
Mafia Customz
mafiacustomz's Avatar
User is: mafiacustomz is offline
Send a message via Yahoo to mafiacustomz
well why not do some round stock with some realy nice bends or even better try to make it look like their is no notch at all by doing a c-notch more under the truck LOL alot of ideas and no funds
S.E.S.
post #53 of 265 Old 02-27-2012, 10:09 PM
Meh...noob
User is: oh so slow is offline
I know that feeling. I wanna bag mine bad but I just can afford it right now and from what I hear it's a bad idea to try to do it on a budget so I'll just wait
post #54 of 265 Old 02-28-2012, 12:15 PM
Registered Asshole
rstadelmaier's Avatar
User is: rstadelmaier is offline
I like using 2x4 tubing because it's personally alot easier to get square accurate measurements. Also id life a little c notch but for as much travel that I needed it was necessary to make it that big. I would've loved to have it underslung but for dd and something id be towing with I felt that was the best way
because i just can't be normal>>> https://www.s10forum.com/forum/f125/p...ckhalf-488914/
post #55 of 265 Old 02-28-2012, 07:51 PM
Mafia Customz
well i was looking for a notch for my caprice and i hate the mini c and the monster c notch thats out i found a real C notch thats made out of a 3/8" steel pipe built like a mini c it looks good
S.E.S.
post #56 of 265 Old 02-28-2012, 08:01 PM
Registered Asshole
mini notch like a pipe cut into a half moon?
post #57 of 265 Old 02-28-2012, 09:03 PM
Meh...noob
post #58 of 265 Old 02-28-2012, 11:51 PM
Mafia Customz
yea thats right a half moon mini c it works alot better for cars thin truck
also that is a sweet c notch on that 50's chevy
S.E.S.
post #59 of 265 Old 02-29-2012, 12:01 AM
Budget Ballin FTS!
BrandonR's Avatar
welding today
BrandonR is offline
post #60 of 265 Old 02-29-2012, 12:01 AM
Budget Ballin FTS!
BrandonR's Avatar
BrandonR is offline
post #61 of 265 Old 02-29-2012, 02:12 AM
Mafia Customz
why dont any one flush weld the c notch its always like that i no you will never see it but if it was mine i would know it looks like that.
im not saying your welds are bad im just saying i dont like the way the c notch is done.
S.E.S.
post #62 of 265 Old 02-29-2012, 07:03 AM
Registered Asshole
I did a half moon notch on my static s10 it works out great on the setup.
post #63 of 265 Old 03-04-2012, 12:53 PM
*Just Do It*
Fabrication Addiction's Avatar
User is: Fabrication Addiction is offline
post #64 of 265 Old 03-04-2012, 01:21 PM
22 psi...stock
low-s-dime's Avatar
User is: low-s-dime is offline
Send a message via AIM to low-s-dime
been a few years since i tig'd aluminum...had to do some at work figured id run a practice bead first on the scrap i use to prep my tungsten...the pieces i was welding were just in need of small tacks tho.
Dan
04.5 2500HD LLY CCSB 4wd
07 impala SS
mig...tig...stick...any questions
low-s-dime's (lincolnmetal) welding learning center
http://www.gmtruckforum.com/fab-shop/
s10forum.com member since 2002
post #65 of 265 Old 03-04-2012, 01:21 PM
22 psi...stock
low-s-dime's Avatar
wtf 2x
Dan
07 impala SS
post #66 of 265 Old 03-04-2012, 05:52 PM
selfmade__brandon
slownoma63's Avatar
User is: slownoma63 is offline
modified x member for a 65 buick skylark
not the best, was done with 80/20 which i do not like personally
modified oil pan for 64 buick for ground clearance, tig welded
TCI front clip i did on a customers 65 mustang.
This week ill take some more pics of some good welds and post them from my truck
@selfmade_fab @selfmade__brandon
post #67 of 265 Old 03-06-2012, 03:58 PM
Longbeds FTMFW
gunther19820's Avatar
User is: gunther19820 is offline
Because he did it the correct way. It is stronger like this.
https://www.s10forum.com/forum/f143/p...nto-it-490214/<---- my body drop thread
Originally Posted by aaronweisler View Post
I can one up the hummer
Originally Posted by s10xtremist View Post
By blowing bubbles before you swallow?
post #68 of 265 Old 03-06-2012, 05:46 PM
Registered Asshole
because its not yours
post #69 of 265 Old 03-08-2012, 09:02 PM
Registered Asshole
post #70 of 265 Old 03-09-2012, 09:28 PM
blake293209's Avatar
User is: blake293209 is offline
Some recent sheet metal welding.
post #71 of 265 Old 03-15-2012, 12:28 AM
Budget Ballin FTS!
BrandonR's Avatar
I need a mig? welder
Also my 4 link bars I built
(Before wire brushing all the welding dust? off)
After
And all done
BrandonR is offline
post #72 of 265 Old 03-15-2012, 12:29 AM
Budget Ballin FTS!
BrandonR's Avatar
And if you notice, in the last pic, I had rewelded all the way around on the bushing to get rid of any holes
BrandonR is offline
post #73 of 265 Old 03-15-2012, 06:43 AM
Registered Asshole
was just about to say, watch for holes those are no good. did you just weld right over it or grind everything back out? just be careful welding over. more welds isnt necessarily good, you could make the steel brittle. but it looks like you just didnt connect the welds together. just make sure you grind down that section a little to make sure your weld penetrates down in or else it won't.
other than that props for stick welding all this. i love stick welding but i don't use it much anymore at work.
post #74 of 265 Old 03-20-2012, 12:12 PM
Mafia Customz
any one have pics of co2 vs c25 welds
S.E.S.
post #75 of 265 Old 03-20-2012, 07:28 PM
PANFACE
blznnp's Avatar
User is: blznnp is offline
Send a message via AIM to blznnp Send a message via Yahoo to blznnp
the biggest difference is that CO2 is going to burn hotter than C25, and is cheaper. But i could give you a picture of a CO2 weld and a C25 weld and look the same.
'12 ram 2500 diesel.....stock
1995 4 door blazer, 6.0 LQ4, 40" Mtr/kevlar , 1 ton axles, 5.38 gears....
68 camaro LS3, T56
blznnp is offline
post #76 of 265 Old 03-20-2012, 10:05 PM
Budget Ballin FTS!
BrandonR's Avatar
I didnt grind it all the way down, Just smoothed it some, wire brushed it, then ran one bead all the way round. Boy was that fun :/
And thanks for the props man! I know the welds arent as good as the nicer welders, But I like to think that for stick, they are pretty dang good. Some places could be better tho Ill say that.
BrandonR is offline
post #77 of 265 Old 03-21-2012, 02:05 AM
Mafia Customz
if you dont mind on some sheet tack and bead and if you have some 1/8 inch tack and bead think you
S.E.S.
post #78 of 265 Old 03-21-2012, 06:45 AM
Registered Asshole
yeah man. just keep practicing and you'll be able to lay a bead just as nice as mig. what rods are you using?
post #79 of 265 Old 03-21-2012, 08:43 AM
PANFACE
blznnp's Avatar
i wont have access to any CO2 till next monday, i only run C25 at home so i will try to remember.
68 camaro LS3, T56
blznnp is offline
post #80 of 265 Old 03-21-2012, 12:49 PM
Registered Asshole
results for co2 and 75/25 look pretty much the same. c02 causes a lot of weld spatter
post #81 of 265 Old 03-22-2012, 12:47 AM
Mafia Customz
i hope alot less thin flux wire
S.E.S.
post #82 of 265 Old 03-22-2012, 12:53 AM
PANFACE
blznnp's Avatar
depends on the flux wire, innershield-yes, dual shield-no
68 camaro LS3, T56
blznnp is offline
post #83 of 265 Old 03-22-2012, 01:04 AM
PANFACE
blznnp's Avatar
here is weld that i have in the garage, its 3/8" welded to 14 gauge. CO2 gas, .030 GMAW, i believe .030.
68 camaro LS3, T56
blznnp is offline
post #84 of 265 Old 03-22-2012, 02:04 AM
Mafia Customz
that dont have no where as much splatter as the innersheild i use and it dont look like ash LOL
what size tank r u running i just got a 40cf tank of c02 and was wanting to know what it cost to fill.
S.E.S.
post #85 of 265 Old 03-22-2012, 02:18 AM
PANFACE
blznnp's Avatar
That's with a welder in my metal sculpting class so I have no clue how much it cost. I can't remember how much it cost to fill my c25 tank bit it isn't to bad an its a 80cu ft tank I believe. I like to use innershield to, the clean up is the only problem.
68 camaro LS3, T56
blznnp is offline
post #86 of 265 Old 03-28-2012, 12:49 PM
Registered Asshole
2.5" by 20" thick guide for steel slabs
lot's of
25 passes on each side
post #87 of 265 Old 03-28-2012, 02:29 PM
PANFACE
blznnp's Avatar
i hated doing stuff that thick and doing full pen welds. even worse was when i had to do full pen welds on I-beams that are installed and have no room to get to it to weld and no room to move the gun around so you end up having more stick out than you want and can't get the puddle to do what you want.
68 camaro LS3, T56
blznnp is offline
post #88 of 265 Old 03-28-2012, 03:03 PM
Registered Asshole
Yeah its not too much fun at all. This wasn't even fullpen theres a 1/2" in the middle. Ive done 1" vertical underneath a scrapyard scale with literally no room on either side. that sucked the most for me
post #89 of 265 Old 03-28-2012, 07:20 PM
22 psi...stock
low-s-dime's Avatar
the one thing i miss about my old job the most is the miller 350p...that shit was tits
Dan
07 impala SS
post #90 of 265 Old 03-28-2012, 10:09 PM
PANFACE
blznnp's Avatar
that's what I miss about welding school. We had the best equipment, new nice steel. Once I got a job I had 20 year old welders that said 30v when it was as hot as 22v on my own welder an had to deal with all types of condition steel.
68 camaro LS3, T56
blznnp is offline
post #91 of 265 Old 03-29-2012, 08:01 AM
22 psi...stock
low-s-dime's Avatar
Shame of it is...it hasent even been turned on since i resigned in sept 2010 lol...same with the hypertherm. But oh well, at least we have a tig machine here, i have a mig and stick at the house so its allllll good...
Dan
07 impala SS
post #92 of 265 Old 03-29-2012, 08:47 AM
Registered Asshole
I use a miller deltaweld 652 I love the machine
post #93 of 265 Old 04-01-2012, 03:13 PM
Budget Ballin FTS!
BrandonR's Avatar
6013 rods, They seem to be the best I have found. The slag just rolls right off and you can pick it up without having a chipping hammer if your welding right, and I run my welder on about 135.
Oh and do these count? They are welded...
*welded on both sides*
BrandonR is offline
post #94 of 265 Old 04-01-2012, 05:02 PM
Registered Asshole
those look good. i prefer 7018's. they're all the way round better in my opinion.
post #95 of 265 Old 04-01-2012, 09:37 PM
22 psi...stock
low-s-dime's Avatar
some brackets for the fairlead on the winch...nothing special, 3/4" L to 1/2" bar 1018
Dan
07 impala SS
post #96 of 265 Old 04-04-2012, 08:26 PM
I drive
SoloSDN's Avatar
User is: SoloSDN is offline
because of this thread, i played with my welder for the first time in over a year..and my bottle was still open since i last used it haha.
i just felt like welding a bunch of jun together.
project: FULL frame 4door
SoloSDN is offline
post #97 of 265 Old 04-04-2012, 08:40 PM
Budget Ballin FTS!
BrandonR's Avatar
Thanks broseph And I use some 7018's. But man they are a pain! its hard to find the right tempurature setting and they seem to burn alot different. The slag is always I bitch to get off. I just dont like them lol. The 6013 is easy to weld, slag rolls right off and is easy to start. As to the 7018 it seems like I have to strike 10 times sometimes.
BrandonR is offline
post #98 of 265 Old 04-04-2012, 08:43 PM
Budget Ballin FTS!
BrandonR's Avatar
These were done in the last couple of days
its all smooth now
BrandonR is offline
post #99 of 265 Old 04-05-2012, 06:51 AM
Registered Asshole
you just gotta make sure to keep them in an oven because they suck up moisture like a bitch. i use them alot at work, and they start to be a pain within like 5 hours of being out of an oven.
post #100 of 265 Old 04-05-2012, 09:32 AM
PANFACE
blznnp's Avatar
My old work could care less about ovens, and most of the time we just used what we had in our rod holders, needless to say we had to go through a bunch of rods when we went to use what we had. I seemed to be the only one out of the field crews that would actually try and get rods out of the only oven we had each time I was welding stick, or would care to put the rods from a new container into the oven. Use to make me so mad.
68 camaro LS3, T56
blznnp is offline
