MIG guys, speak up - S-10 Forum
post #1 of 6 Old 02-25-2014, 08:54 PM Thread Starter
AWD V8's Avatar
User is: AWD V8 is offline
MIG guys, speak up
Busted the gauge on my Weld=Pak 180HD, some stuff tipped over and trashed the low pressure gauge.
My original reg was a 2 gauge adjustable. I'm OK with only knowing the tank pressure.
Queation
Are the non-adjustable single gauge regs all set for the same output? Meaning if I buy a single gauge non-adjustable reg am I good to go?
Got my eye on this ebay item, http://www.ebay.com/itm/261406858167...%3AMEBIDX%3AIT
Thanks
AWD V8 is offline
post #2 of 6 Old 02-25-2014, 09:53 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
Re: MIG guys, speak up
Zero experience with non adjustable regulators, honestly didn't know they even made them!
IMO its very important to know gas flow. too much can cause issues and turbulence introducing air contaminating the weld.
I would jump on this deal. VERY well made regulator that i have for my TIG. Normally $120-150.
http://www.ebay.com/itm/SMITH-GAS-RE...item2ece89dae7
Sure you can buy a cheap regulator for $20-30, but at least have it let you see the amount you are flowing. if you are welding in a garage you can always turn down the gas and save $$ if there is zero wind.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #3 of 6 Old 02-26-2014, 07:58 PM Thread Starter
AWD V8's Avatar
Thanks Beandip, bought it
AWD V8 is offline
post #4 of 6 Old 02-26-2014, 08:11 PM
V8 with bags
V8Blaze's Avatar
User is: V8Blaze is offline
Send a message via AIM to V8Blaze Send a message via Yahoo to V8Blaze
that smith is what came with my 211 i got a few months back. Seems like a well made unit.
V8Blaze is offline
post #5 of 6 Old 02-27-2014, 11:41 PM
Blazin_Jason's Avatar
User is: Blazin_Jason is offline
Now that's sorted, been thinking about getting the 180 from CT for some time now. Have you been happy with yours? Just need it for general hobby use, rust repair, small diy fab jobs etc.
85 Blazer 4x4, 350, 3" BL, 33's, project
89 Jimmy 4x4, 4.3-->5.7 project
90 Jimmy 4x4, 4.3, DD, 2" BL 31's
post #6 of 6 Old 02-28-2014, 12:00 AM Thread Starter
AWD V8's Avatar
Jason, the 180HD that I'm using is great. 1/4" is no problem. Easy to use. I wouldn't recommend any 110 V. welder!
I never was taut how to use it, just plugged it in after hooking things up and away I went. Never a problem after 3 years with this one.
AWD V8 is offline
