Machinists discussion - Page 2 - S-10 Forum
post #51 of 74 Old 08-17-2013, 01:55 AM
Tech Mod
beandip's Avatar
User is: beandip is offline
Re: Machinists discussion
^ that is pretty damn sweet.
we are in machine shop class now, made this.... Still thinking about what to make....
its in .050 each step.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #52 of 74 Old 08-17-2013, 03:20 PM
My mirror hates my sub
Speedy2222's Avatar
User is: Speedy2222 is offline
Send a message via AIM to Speedy2222 Send a message via MSN to Speedy2222 Send a message via Yahoo to Speedy2222
i think i've already posted these pics.. but make something that may be useful around the house/shop. here's a plum bob i made back in HS shop class
-Speedy
97 s10 - Audioque SDC2.5 15 3.5cu 34 hz
post #53 of 74 Old 08-21-2013, 05:05 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
User is: hi_im_sean is offline
i made a 38mm self aligning v band setup for the waste gate on the miata.
Shitty website to be updated soon!
http://sadfab.com/
my projects:
94 S10 SS- https://www.s10forum.com/forum/f18/my-white-94-a-485474/
86 S15 corner carver- https://www.s10forum.com/forum/f30/86...beware-475623/
gay miata-http://www.miataturbo.net/build-thre...ru-td04-74776/
Gone postal, will be back later...
post #54 of 74 Old 08-22-2013, 11:52 PM
Tech Mod
beandip's Avatar
^ nice.
nothing fancy, but made a spinning top. pretty fun project, just too bad i dont have anything i could make for my trucks.
might look different but its pics from a second top i built.
Spins so smoothly there is no visible movement.
spun for over 4 min on my glass table when i leveled it.
-Jonathan
beandip is offline
post #55 of 74 Old 08-23-2013, 02:12 AM
A work in progress...
jasond's Avatar
User is: jasond is offline
Just started my machine tool classes last week. Gotta say love it so far. That spinning top is cool as hell. I plan to make a spare tire drop plate for my blaZeR2 before class is over. Tired of not being able to see out of the back window. Lol
Sent from AutoGuide.com App
jasond is offline
post #56 of 74 Old 08-23-2013, 10:05 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Nice knurls, that's something I need to get better at. But i need a decent knurling tool first.
http://sadfab.com/
my projects:
post #57 of 74 Old 08-23-2013, 05:31 PM
Tech Mod
beandip's Avatar
my 4th time actually using it. its very easy, cant really see how anyone cant do "good" knurling.
not sure how "good" the tooling was, but i suppose that has a large play in the quality. i always start out at .010 and increase by .010 each pass. just feed it manually and add a bit more each pass and you should be good.
Well this is interesting. we have this big rack of steel free to us to use, out of this rack, is a weird piece of 1 1/4" "stainless" looking round bar. its odd because its very light, not quite aluminum but for a 10 foot stick, it should weigh a good 40lb or more but doesnt. our instructor has no freaking clue where it came from, google the numbers, and its AMS-4965 TITANIUM!!! took ****ing 20 min to cut on the bandsaw, its crazy hard. so, i could not resist making a top out of it! lol. confirmed its titanium too, shoots a beautiful spray of bright white sparks when put on a belt sander.
took basically 6 hours to make this. its retarded hardened stuff. the edge where the cutting tool and metal meets had a tiny spark, then white hot metal shavings, that cooled to red hot, then "normal" color as it cut. and that was only taking .015 at a time! very "different" stuff for sure. no clue how much that stick of steel was.
this stuff is so hard, that the deflection was crazy. when i got to this spot, there was a .020 difference between one side and another. i had to do 22 passes without adjusting anything just to get it to level down even. it was taking off .0005 at a time or less each time too. just insane stuff to work with. you couldnt tell visually, it would always seem to take off the same material each pass and leave a long thin metal shaving.
did a test spot on the thicker part of the shaft. i had no idea how this would come out and didnt want to chance it. i put the tail stock close by to see how much the material was deflecting.
Finished product after what felt like forever.
-Jonathan
beandip is offline
post #58 of 74 Old 08-23-2013, 07:34 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
i can assure you it can be done. ive only tried once with the fixed cheap chinese knurler that came with my "hobby" lathe, it turned out like shit. you have a dorian toolpost there and a floating knurler so i can bet tool quality makes a huge difference. not to mention machine rigitity, especially while knurling. my lathe is only a 10x22 and just barely 500lbs :
im curious why a machine shop bought treated titanium. thats funny
http://sadfab.com/
my projects:
post #59 of 74 Old 08-23-2013, 10:47 PM
The Vehicle Dynamics Bro.
badmatt's Avatar
User is: badmatt is offline
Send a message via MSN to badmatt
Try a CNC knurling too Sean,
They cut rather than roll, but Again machine and part rigidity is a big thing. try and have the tail stock in use.
If your S-Series truck is V6 or V8, then your the gay that likes to give it to the other guy.
If your S-Series truck is a 4 cylinder, then your the one who likes to receive it in the ass.
RIP Neil Bursey aka Gearstix you will be greatly missed.
Project Nera:
SB2.2, 4spd dog box, FF9", Full Frame, Brembo's, and WAY to much stupidity.
LA GRAY: The shitty ZR2.... Express unit, now with 5.3
badmatt is offline
post #60 of 74 Old 08-23-2013, 11:28 PM
Speedy2222's Avatar
the key is to feed in hard, don't stay on too long, than pull off twice as fast.
should note.. the only knurling i have ever done in a cnc was on stainless.
-Speedy
post #61 of 74 Old 08-24-2013, 12:50 AM
Tech Mod
beandip's Avatar
^ i stayed on as long as i felt like really, moved back and forward to get an even design.
the school didnt buy that titanium, no way. we all have no clue how it got here, or how long its been here. all i know its badass and a unique metal to work with.
-Jonathan
beandip is offline
post #62 of 74 Old 08-24-2013, 11:07 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
that's what I was thinking, at work we have tin coated carbide knurling tools with replaceable wheels that cut instead of forming. ill probably get one when a project demands knurls.
bean, you should grind a slot in that stepped rod and see if you can make a step drill with it. at the machining school I went to, we got a lot of things and stock donated from Honeywell, garret, etc, so id imagine it was something along those lines.
http://sadfab.com/
my projects:
post #63 of 74 Old 08-24-2013, 11:21 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
my riding buddy is the solid works guy for an aerospace machine shop. he sent me pics of the front landing gear hydraulics theyre machining for the airbus a350.
manifold
hydraulic cylinders, or maybe they are accumulators, I forgot what he said, the manifold bolts to the top of these.
pistons
piston rods
http://sadfab.com/
my projects:
post #64 of 74 Old 08-30-2013, 01:07 AM
Tech Mod
beandip's Avatar
lathe speed knob at school...
Chunk O' aluminum (you can see my plain boring speed knob, not fancy enough)
made 2 more for the machines that didnt have one.
set screw hole drilled/tapped as well.
Mill at school, one of 3. drilling some knuckles out for a buddies high steer conversion on his wrangler. had to get a tad creative supporting it.
press fit.
Tig welded (tad bit undercut on the bottom one
All this machine work makes me want to buy a mill/lathe lol. its very addicting.
-Jonathan
beandip is offline
post #65 of 74 Old 08-30-2013, 08:52 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
the machinist at work always says, i can machine anything if we can figure out how to hold it.
http://sadfab.com/
my projects:
post #66 of 74 Old 08-31-2013, 06:55 PM
Slowly but eventually
98lowerednewproje's Avatar
User is: 98lowerednewproje is offline
^^My grandfather has said that to me many times.
You guys make me jealous. Awesome work!
Procrastination has carried me this far in life, it will carry me to my grave, and hopefully put that off as well.
'98 RCSB on jack stands, waiting on me to get the 4.8 and T56 swap together, while I steal parts off of it to keep the daily going.
'99 2DR 2WD Blazer that I bought for a daily but just can't leave it alone.
post #67 of 74 Old 09-11-2013, 10:20 PM
PhilBuilt Customs
User is: slvrs10 is offline
Latest side project...
^^ doesn't look like that anymore ^^
2002 "Philbuilt" S10 Check out my project thread <-- Magnacharged LS6, 325's, rockerdrop and dually bed underway
1998 Tahoe Utility Winter Warrior - 2 door, 2wd, Lowered 3", 17" Fikse wheels
Facebook.com/PhilbuiltDesigns
slvrs10 is offline
post #68 of 74 Old 09-12-2013, 11:21 AM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
Made a shift knob for the miata
http://sadfab.com/
my projects:
post #69 of 74 Old 09-12-2013, 01:31 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
some past gifts i've made.
post #70 of 74 Old 09-12-2013, 10:03 PM
Tech Mod
beandip's Avatar
Turner's cubes are awesome.
-Jonathan
beandip is offline
post #71 of 74 Old 12-12-2013, 06:27 PM
22 psi...stock
low-s-dime's Avatar
User is: low-s-dime is offline
Send a message via AIM to low-s-dime
toolmakers do what they say cant be done
Dan
04.5 2500HD LLY CCSB 4wd
07 impala SS
mig...tig...stick...any questions
low-s-dime's (lincolnmetal) welding learning center
http://www.gmtruckforum.com/fab-shop/
s10forum.com member since 2002
post #72 of 74 Old 08-04-2014, 02:05 PM Thread Starter
9" strait pipes...
hi_im_sean's Avatar
speaking of interesting mill setups. this was a pain in the ass
weld el turbo mani i made for the miata. trying to mill the flanges flat
Dshaft made... well, non- Dshaft
miata throttle body TPS retrofit
vbands
td04 divorced downpipe vband flange adapter
http://sadfab.com/
my projects:
post #73 of 74 Old 08-05-2014, 12:33 AM
Dems 22s
mattadams13's Avatar
User is: mattadams13 is offline
Nice work guys. I really miss getting to do some machine work since i got put into engineering. Its a pain in the a** at times, but its also something thats very rewarding.
Beandip, you look like your a natural at machining. I wasnt that lucky, but after screwing up a bunch i finally started to get a little bit better lol.
Matt Adams
Project thread: Laying on billet 22s https://www.s10forum.com/forum/f30/si...thread-486853/
post #74 of 74 Old 08-14-2014, 09:05 PM
badmatt's Avatar
Meh. and yes I realize the bungs are not centered in the runner.... They are centered to the valve.
Matt
Project Nera:
badmatt is offline
