flux core welder - S-10 Forum
post #1 of 21 Old 04-07-2014, 12:48 PM Thread Starter
shadow94's Avatar
User is: shadow94 is offline
Question flux core welder
i know i know ,flux sucks but i dont really have the money for a decent welder or pay someone to do it right now . ive done mig in highschool but that was 20 years ago. my neighbors father gave me this hf flux core welder ,looks cheap as shit .im gunna tri to use it and was woundering if there is any trick or tips i need to know about befor i start . ive looked on youtube today ,and got an idea .i only have to close up some holes the size of a sharpie marker or smaller in the floor boards . thanks guys
shadow94 is offline
post #2 of 21 Old 04-07-2014, 12:57 PM Thread Starter
shadow94's Avatar
Re: flux core welder
oops i didnt even see the stickey,ill read it but any advice is appreated
shadow94 is offline
post #3 of 21 Old 04-07-2014, 04:50 PM
needs a cheeseburger
tohoopty's Avatar
User is: tohoopty is offline
you were in high school when you were 11
Originally Posted by The Griff View Post
I looked at my asshole in the mirror today. It blew my ****in' mind!
tohoopty is offline
post #4 of 21 Old 04-07-2014, 05:49 PM Thread Starter
shadow94's Avatar
haha no, my son was home from skool today and was doing math homework ,i was multi tasking here and homework and writing a few checks for bills ,prob was writing while talking to him ,it was only 12 years to clear that up ,i bet my checks are messed up to. anyway what gauge is the metal on the floor.agian any help info would be great ,gunna try this sunday.
shadow94 is offline
post #5 of 21 Old 04-07-2014, 06:42 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
Lol @ "skool".
Anyway, for small holes in thin sheetmetal, using flux core may be more trouble than it's worth. Flux burns much hotter and is messier, so you're probably gonna make more of a mess than repair anything. Now, if you got a new floor board (new or a solid piece from a junkyard, and cut out the old one while leaving enough around the edge for the new panel to sit on, it would be easier to weld with the flux. But, you'd still have to be careful with the heat.
Getting better with every failure
Project threads:
Punching bag
Unicorn XJ
post #6 of 21 Old 04-08-2014, 08:37 PM
SlamBlackSdime's Avatar
User is: SlamBlackSdime is offline
Send a message via AIM to SlamBlackSdime
Shadow where in bergen county are you? I have a gas mig welder, what are you looking to repair>?
post #7 of 21 Old 04-09-2014, 01:33 PM Thread Starter
shadow94's Avatar
Im in garfield .were you slamblack
shadow94 is offline
post #8 of 21 Old 04-09-2014, 03:24 PM
CNC Plasma Cutting
GoingCustom's Avatar
User is: GoingCustom is offline
I've done everything from bodywork to structural welding with flux core. *IF* you know how to weld properly, flux will work just fine for doing the bodywork. As stated, it does burn hotter, so you'll have to account for that. If needing to make more than one tack weld, need to clean the previous weld first (wire wheel instead of wire brush if possible). You'll spend more time waiting for things to cool down before adding another tack is all.
Originally Posted by wildman ss View Post
GoingCustom has the nicest rides on this site
Originally Posted by Tex Star View Post
You're a true craftsman......
www.goingcustom.com (badass gates, art, corporate/holiday gifts)
1967 Mercedes Benz 230s - minor restoration - bagged (Accuair can suck a dick) - Project thread: https://www.s10forum.com/forum/f30/pr...rtimer-395664/
post #9 of 21 Old 04-09-2014, 09:49 PM Thread Starter
shadow94's Avatar
Thanks for the tip custom .ging to give it a try this weekend
shadow94 is offline
post #10 of 21 Old 04-10-2014, 09:18 AM Thread Starter
shadow94's Avatar
Slam black dont sopose you want to weld my issues for me if I can hack with the flux core .only thing is I dont have any other plugs in the house than the normal house hold plug. Pm me , let me know
shadow94 is offline
post #11 of 21 Old 04-11-2014, 03:13 PM Thread Starter
shadow94's Avatar
Ah hah I found a 220 v plug , now I got to get a welder with gas
shadow94 is offline
post #12 of 21 Old 04-14-2014, 02:38 PM Thread Starter
shadow94's Avatar
Well , I know im not a welder but this sh!t sucks .I tried to seal up two little holes (pencil size) an made them bigger . Had it on the lowest setting and wire spd slow and a little further away from the work and it burnt through. Not happy , is there anything I can do to stop that besides a new welder or someone else welding it .
shadow94 is offline
post #13 of 21 Old 04-15-2014, 08:53 PM
KarlW's Avatar
User is: KarlW is offline
Wire speed too low?
KarlW is offline
post #14 of 21 Old 04-15-2014, 10:19 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
Put a piece of thick copper on the backside of the hole you are trying to weld.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #15 of 21 Old 04-16-2014, 11:11 AM Thread Starter
shadow94's Avatar
like i said im no welder ,ive done some mig and tig in high skool but the teacher put me with a senior that set everything up and didnt really show me how to and its been a long time .i looked at the sheet that came with the welder and did it accordingly ,burt through .i changed the settings and it worked better , still burnt through tho .seemed to weld better to itself than the actual floor ,like once i had a tack . im gunna look at work for a thick piece of copper ,how thick does it have to be ?just thicker than the floor ?
shadow94 is offline
post #16 of 21 Old 04-16-2014, 03:24 PM
Yes, they're all mine
pwtr02ss's Avatar
User is: pwtr02ss is offline
Start welding on the good material and tack your way over the hole from the weld itself don't go to fast and just do tacks. Once you have a small tack you should be able to build from that without burning through.
Yes he said that...
Originally Posted by Noboundries View Post
Yes sir like a real man. Real men suck dick. Softies like women.
2019 Yukon Denali- All stock
2008 Avalanche LTZ- All stock
2002 Camaro SS- Heads, Cam, Forged Internals, Nitrous, Bla Bla Bla
1996 S-10- Lowered 5/5, Boyd Billets, Custom Paint, Daily Driver
1974 C-10- Lowered 5/5, Bonspeed Billets, 08 LSX Swap, Full Frame Off Build
pwtr02ss is offline
post #17 of 21 Old 04-16-2014, 09:26 PM
Tech Mod
beandip's Avatar
yes. i have a piece of 1/4" thick copper about 1.5" square that i use for filling holes on certain projects. it came from a 600 amp buss fuse.
either way, the weld wont stick to the copper no matter what. but the thicker the piece the better. it may "stick" slightly, but just knock it off with a hammer.
-Jonathan
beandip is offline
post #18 of 21 Old 04-16-2014, 09:55 PM
Sold :'(
Speaking of, anyone ever used the welding spoon from Harbor Freight? I'm pretty sure it's copper coated. I bought one, but have yet to use it. It was only $6 (on sale + 20% off coupon), but curious if the copper holds up.
Project threads:
Punching bag
Unicorn XJ
post #19 of 21 Old 04-16-2014, 10:34 PM Thread Starter
shadow94's Avatar
Im gunna go searching at my job in a little bit thanks guys
shadow94 is offline
post #20 of 21 Old 04-17-2014, 07:40 AM
Headbanger Boogie
BrutalityIsLaw's Avatar
User is: BrutalityIsLaw is offline
Flux sucks for this stuff. Only welder i have to use is my old mans beat up miller cricket and I hate the thing with a fiery passion. Only time I've ever got a decent weld with it was doing something standing up on my bench, used it for exhaust work and was wretched. I have used it on the sheet metal a little bit on the truck, and i will be using it to patch a small rust hole in my cab I recently noticed. I'm no welder myself by any means, but I did alright before by keeping the wire feed around 5-6 and lowering the heat down and going slow.
IG @r_ayyeee
post #21 of 21 Old 04-19-2014, 07:06 PM Thread Starter
shadow94's Avatar
Spoke to a professional welder old friend of my fathers today and hooked me up with a few tips , he didnt want to do the job for me but Told me what to do so im gunna give it a shot monday .
shadow94 is offline
