Careful when using brake clean if you are welding. - S-10 Forum
post #1 of 11 Old 09-06-2012, 07:45 PM Thread Starter
A CLEANMACHINE's Avatar
User is: A CLEANMACHINE is offline
Send a message via Yahoo to A CLEANMACHINE
http://www.brewracingframes.com/id75.htm
99 ext cab auto, 7psi mitsu 14b turbo ported, and coated 2 1/2'' exhaust to turbo muffler,fake cat,underdrive pulley,efan,56mm t/b,42lb racetronix inj,4.3 fuelpump,aem wideband,pyrometer,f/press guage,.lowered rear 2'',hhr seat , counsole,and finished fabbed cowl hood.5 angle valve job,ported head,methanol injection
post #2 of 11 Old 09-06-2012, 09:47 PM
SSRT-S10
my_nightmare's Avatar
Re: Careful when using brake clean if you are welding.
We used to, at my main shop, spray brakekleen in/over the 50 gallon drum. Somewhere down the line, this 50 gal steel drum became a trashcan(I wish I could find the idiot that started this). Then someone shoved this can near the main vise. You guessed it. I'm over there torching up a metal plate to make a braket..,and it didnt even cross my mind to think about that can.., and WHOOSH!! A BIG flame the size of hell came out of the can at me !!! No more eybrows.., no more hair in front.., and barely any moustache left.., burned my shirt.., it burned me up really good !! I cursed everyone in the shop out for 4 days afterwards !! "If ya got to spray it.., spray it on the concrete floor or in the parts cleaner!!!", I said to them. I forgot to mention.., 4 of the cans in the drum still had stuff in them AND THEY also exploded due to the trash catching on fire. I since removed the barrel from that area totally and painted on it "scrap metal only or your job !!!"
Now everyone there still thinks/and talks about this deal. To them, this is funny as hell.., `cause I sure looked stupid with no facial hair.
post #3 of 11 Old 09-07-2012, 02:09 PM
sas10's Avatar
User is: sas10 is offline
wow, that's crazy how a little puff of smoke can do that much harm. goo to know though!
Your brother drives a Sunfire. Is he gay?
Originally Posted by _juice_ View Post
The "dog" lol, that's my buddy 'Jerry with a G' there's another one behind him at the back of the car, that's 'pickles' thems my attack goats.
sas10 is offline
post #4 of 11 Old 09-07-2012, 04:16 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
This discussion pops up every now and then.
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #5 of 11 Old 11-17-2012, 05:57 PM
22 psi...stock
low-s-dime's Avatar
User is: low-s-dime is offline
Send a message via AIM to low-s-dime
my weld prep is limited to a degreaser and acetone or alcohol. both get the job done and both evaporate quickly.
Dan
04.5 2500HD LLY CCSB 4wd
07 impala SS
mig...tig...stick...any questions
low-s-dime's (lincolnmetal) welding learning center
http://www.gmtruckforum.com/fab-shop/
s10forum.com member since 2002
post #6 of 11 Old 11-18-2012, 02:24 PM
Registered Asshole
rstadelmaier's Avatar
User is: rstadelmaier is offline
i'ver read about this before, and heard about it from an older guy i used to work with. shits very dangerous
because i just can't be normal>>> https://www.s10forum.com/forum/f125/p...ckhalf-488914/
post #7 of 11 Old 11-18-2012, 04:19 PM
AWD V8's Avatar
User is: AWD V8 is offline
Many years ago I was gas welding across the roof on a Beetle, custom attempt. I had removed the headliner and the foam that is glued to the roof. I was tacking the panel and I guess I was too close to a patch of foam and glue residue and a wee bit of black smoke came up through the open door window. It suddenly felt like I had a knife jabbed up my nose into my sinuses and everything went black and I felt like I was falling. I was able to grab something as I went down and held the torch away from me. I came to sitting on the floor.
The by product of burning foam is arsenic, it only takes one good whiff to take you out. I just survived that one.
AWD V8 is offline
post #8 of 11 Old 11-19-2012, 10:41 AM
90blueS10's Avatar
**** that.
Ryan
post #9 of 11 Old 11-28-2012, 07:03 PM
sas10's Avatar
^^^ that's no good to say the least. glad you made it out ok. its good to know this stuff. i know i have welded some stuff and it was not clean on the opposite side, wont be doing that again.
sas10 is offline
post #10 of 11 Old 08-09-2015, 11:30 AM Thread Starter
Originally Posted by A CLEANMACHINE View Post
i'm updating this as some problem comes up on link i originally posted w/404page not found.try this as this info cannot be ignored thanks.
http://www.brewracingframes.com/safe...sgene-gas.html
post #11 of 11 Old 08-10-2015, 08:53 AM
RPO Delete
tealtank's Avatar
User is: tealtank is offline
Good write-up and I'm glad you're around to tell the tale.
Unfortunately, most people learn safety accidentally. Hopefully, this will prevent people from encountering a similar situation.
1995 - S10 Blazer - 4x4 - 4.3 W code CPI
www.cardomain.com/ride/3904104
My seller feedback
tealtank is offline
