anyone every heard of or used this plasma cutter - S-10 Forum
post #1 of 4 Old 05-22-2014, 01:04 PM Thread Starter
Layed Out Fabrication
bdydrp18's Avatar
User is: bdydrp18 is offline
http://www.amazon.com/Everlast-SuperCut-Inverter-plasma-Cutting/dp/B004K1MYNQ
looking into get a plasma cutter and not sure if this worth the money or i just just save a little more an get a Hobart
bdydrp18 is offline
post #2 of 4 Old 05-22-2014, 02:00 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
Re: anyone every heard of or used this plasma cutter
I've heard of it, but personally would not get one. I'm sure it would work fine, but i would stick with hypertherm, or miller for a plasma. it might be a bit more than you are willing to spend, but i put a ton of hours on mine and it has definitely been well worth the money.
http://www.amazon.com/Plasma-Cutter-Inverter-625-X-TREME/dp/B007FHSXOQ/ref=sr_1_1?s=hi&ie=UTF8&qid=1400780842&sr=1-1&keywords=miller+625
It really depends on what you are going to use it for. if you plan on doing general cutting like you would with a torch then that is fine, but if you plan on using it to cut sheets of steel with minimal cleanup, i would suggest getting a different brand because that drag tip is just a cheap wire and you wont get too precise cuts with that.
Untitled by bean4dip, on Flickr
it also has the ability to do a nice cut on 3/4" plate, but its just a tad out of the machines max "quality" cut range. though it can cut 1" plate but much slower.
-Jonathan
My Project thread--->https://www.s10forum.com/forum/f30/pr...driver-361848/
{PROJECT ZR2} 2000 S10 ZR2 200,XXX miles, 31x10.5 BFG KM2 MT on 15" Pro Comp 152s, Iron front diff, 1.5" T-bar crank & custom bumpers & shackles, + more
https://www.s10forum.com/forum/f30/be...ct-zr2-485836/
https://www.s10forum.com/forum/f30/da...status-520683/
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #3 of 4 Old 05-22-2014, 03:54 PM Thread Starter
bdydrp18's Avatar
yeah i would love to have something like that miller but i just not sure i want to put that much money into one. i know i will probably be cutting a lot of .25 but not sure i will be going over that that much. i looked at the Hobart ones too, i know some guys on here have their welders but don't know what there plasma cutters are like
bdydrp18 is offline
post #4 of 4 Old 05-23-2014, 03:48 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
Ive had my hypertherm for 8 years and love it. It cuts anything you put in front of it
I dont drive Chevys anymore....
1fast4by is offline
