20x9 fitment up front on a 2nd gen blazer dropped 4” - S-10 Forum
post #1 of 7 Old 03-25-2019, 12:24 AM Thread Starter
ZQ8 Blazer's Avatar
User is: ZQ8 Blazer is offline
I’ve decided on the wheels I want, but there’s an issue with backspacing and bolt pattern. They come in 20x9’s(5x120mm pattern so I’d need adapters) with a 5.79”bs and 20x10’s (correct bolt pattern) with an 8.45” bs. Pretty sure 20x10’s would be too wide for the front how would the 20x9’s do with the correct adapters and what thickness do I need? I have a 4/4.5 drop on my 2000 2dr Blazer. I’m currently running 20x8.5’s with a 4.5” bs and have rub at full lock and bottom out on the front inner fenders on large dips. Out back I have the same wheel specs with a 1.4” spacer and nothing currently rubs. I’ll either be going with same width all around or 10” wide out back with meatier tires and dropping the rear more.
ℐustin
post #2 of 7 Old 03-25-2019, 01:16 PM
User is: dime-dozen is online now
Re: 20x9 fitment up front on a 2nd gen blazer dropped 4”
not to question the why but I think yours looks perfect as is
with that big of a spacer in back sounds like youre a candidate for an 8.8 or a 4WD rear
post #3 of 7 Old 03-25-2019, 04:35 PM Thread Starter
ZQ8 Blazer's Avatar
Thanks, but I’m wanting something different. I’ve decided I’ll be running 20x9’s all around and it looks like I’ll need a 1.25” spacer on the front, and I’m guessing a 3” in the rear. Yeah I could get a 4wd rear and sell my current one and probably make money since I have a 8.5” 2wd with disc brakes but I don’t really want to do that in case I decide to go back to something with a 4.5” bs. This is what I’m looking to run:
ℐustin
post #4 of 7 Old 03-25-2019, 04:54 PM
B4U Task Force
Rhotpursuit's Avatar
@ZQ8 Blazer ....what size tires are you going to run? If you're going completely off the rails, Harley can probably point you in the right direction.
Apple Red 96 SS
post #5 of 7 Old 03-25-2019, 07:54 PM Thread Starter
ZQ8 Blazer's Avatar
255/35's up front and idk if I'm doing the same in the rear or going with something a bit meatier.
ℐustin
post #6 of 7 Old 03-25-2019, 09:05 PM
those look like a Z06 copy.
Keep your rear and build an 8.8 or cut down a ZR2
3 inch spacer is a big chunk
post #7 of 7 Old 03-25-2019, 09:54 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
I think those will look pretty sinister on there.
TelAmeriCorp
Similar Threads
S10 Blazer 1st gen Weight DRLExpress 4wd SFA 9 01-11-2019 11:13 AM
Any 2nd Gen ExCab converted to 1 PC driveshaft? CDUBCustomz Transmission & Rearend 5 09-22-2018 10:45 AM
2nd gen 2 door Blazer hitch Youngblood16 Wanted, to Buy 0 12-03-2017 10:50 PM
Blazer front brakes.Bearing compatability IROC-Turbo Wheels, Tires & Brakes 5 07-31-2017 01:09 PM
Some LS info .... long post!!!! Wkeracing LSx Discussion 3 08-10-2016 05:41 PM
