Yet another dumb question - S-10 Forum
post #1 of 11 Old 06-18-2019, 08:03 PM Thread Starter
oldfogey47's Avatar
User is: oldfogey47 is offline
I don't plan to use A/C in my 2002 pickup build. (It's Colorado, we hardly sweat).
Anyway, the question: did any S-10 pickup NOT come with A/C?
I want the firewall-side heater box cover and they're just not to be found, at least by me.
They DO exist, right?
Thanks...
post #2 of 11 Old 06-19-2019, 12:03 AM
Been there Done it
oldeerslayer's Avatar
Re: Yet another dumb question
Harley had a couple.
https://www.s10forum.com/forum/f293/...er-box-849899/
post #3 of 11 Old 06-19-2019, 12:03 AM
SNF
SNF's Avatar
User is: SNF is offline
If your talking 4.3, no idea. Tutu, I know they have.
SNF is offline
post #4 of 11 Old 06-19-2019, 12:55 AM
time to get cereal
manbearpig's Avatar
I believe 2001 was the last year for non-AC trucks, but lucky for you a 2002 isn't any different.
The 4.3L uses an idler pulley in place of the compressor, the 2.2L just uses a shorter belt.
Controls:
Blower Box and Blower Motor (it's different too)
Recirculation door block-off
post #5 of 11 Old 06-19-2019, 02:05 AM
New Member
Harley's Avatar
User is: Harley is offline
Originally Posted by oldeerslayer View Post
I still have a couple. No 98 controls at the moment, but I've got an extra firewall box and 1 set with the 96 controls. I do find these somewhat regularly.
Harley is offline
post #6 of 11 Old 06-19-2019, 04:44 AM
Been there Done it
Can't you just leave the A/C controls on the dash. I did that on a 1st gen and everything worked fine. Of course when you set it to A/C nothing happened, but everything else functioned as normal.
On the 1st gen you gained 1 blower speed if you changed the resistor on the motor because non A/C only had lo, med, & hi.
post #7 of 11 Old 06-19-2019, 01:01 PM Thread Starter
oldfogey47's Avatar
this is a LS swap, so engine related stuff doesn't matter (pulleys...etc)
post #8 of 11 Old 06-19-2019, 03:28 PM
New Member
Harley's Avatar
You're right. Don't need the controls or the recirculation block off panel, but some people want it all, so I grab whatever is there to resell. Well I don't grab the motor or resistor because the yards charge close enough to new prices on those it isn't worth it.
At a minimum you need the firewall housing and blower motor. The resistor is the same for the 2nd gen between the AC and no AC.
That might be the case on the earlier 1st Gen, but the later interior style has the same number of fan speeds between the 2.
Harley is offline
post #9 of 11 Old 06-19-2019, 06:38 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Controls:
Wow! Iíve never seen a second gen w/o AC
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #10 of 11 Old 06-19-2019, 06:52 PM
time to get cereal
manbearpig's Avatar
Really? 94-97 trucks w/o AC still turn up regularly in junkyards here in St. Louis. Only seen a couple 98+ though.
post #11 of 11 Old 06-19-2019, 08:07 PM
BravadaX's Avatar
Yeah,Iíve only seen it on box bodies,..
Then again I live in the south. Thereís not a big market out here for cars w/o air conditioning. My buddy had a Canadian model Tercel w/o AC,and literally couldnít give it away,..weíll,I finally bought it for a couple hundred bucks,and quickly resold it to another buddy once the tank was empty
BravadaX is offline
You may post new threads
You may post replies
