What is this plug for? - S-10 Forum
post #1 of 25 Old 04-14-2019, 06:25 PM Thread Starter
User is: 808GMCSONOMA is offline
Hey guy was playing around with the truck learning how to remove the headlights, grill and bumper I discovered a loose plug in front by the radiator and wondered what this plug is for?
Here is a pic of the plug so please lmk your guys thought on what this is for? Thanks guy aloha
post #2 of 25 Old 04-14-2019, 07:06 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Re: What is this plug for?
Ambient temperature sensor for a digital overhead console.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #3 of 25 Old 04-14-2019, 07:17 PM Thread Starter
Ohh I see where would do I plug it in too am I missing something?
post #4 of 25 Old 04-14-2019, 08:06 PM
B4U Task Force
Rhotpursuit's Avatar
The sensor should be on the hood latch support.
Apple Red 96 SS
post #5 of 25 Old 04-14-2019, 09:12 PM Thread Starter
So if my over head display console is off it’s because there’s no sensor? So if I don put the sensor in and display is still black could it be something else like a fuse?
post #6 of 25 Old 04-14-2019, 09:14 PM
B4U Task Force
I'd check all of the fuses....even if you know exactly which one it is...can't hurt.
Apple Red 96 SS
post #7 of 25 Old 04-14-2019, 11:36 PM
oldeerslayer's Avatar
Did you mean do or don't?
post #8 of 25 Old 04-15-2019, 02:43 AM Thread Starter
Where would the fuse location be for this over head console? Could it be in the fuse box located in the cab or the one under the hood?
post #9 of 25 Old 04-15-2019, 02:46 AM Thread Starter
Sorry I meant “do”
post #10 of 25 Old 04-15-2019, 02:53 AM
Mr Goodwrench's Evil Twin
thebadwrench's Avatar
User is: thebadwrench is offline
In the cab... it gets power from the "RDO IGN" fuse and the "ILLUM" fuse
14 years Professional Automotive Repair Tech. If you attempted to fix it, it will now cost you more for me to fix
My DIY Guide to OBD2 Scanners
"Blind belief in authority is the greatest enemy of truth" - Albert Einstein
"Ignorance is never a valid excuse" - Me
post #11 of 25 Old 04-15-2019, 03:05 AM
I should add that if the sensor is not plugged in, the overhead console will display "OC" indicating that the ambient temp sensor circuit is open. So if it's not displaying anything at all, it's not because the sensor isn't plugged in... there's another issue with it. The displays do go bad sometimes.
post #12 of 25 Old 04-15-2019, 03:15 PM Thread Starter
Oh okay I should check my fuses first than to see if there blown
post #13 of 25 Old 04-15-2019, 03:16 PM Thread Starter
I see I know I have issues with my headlight switch not illuminating my cluster would that have to do with anything in the overhead console also?
post #14 of 25 Old 04-15-2019, 03:25 PM
B4U Task Force
I'll have to check the wires Blazer2 and see if the dimmer affects the overhead console. I'm pretty sure it does. I'm sure turning on the headlights does. I don't drive it often enough to be positive.
You do have the dimmer wheel rotated up...right?
Apple Red 96 SS
post #15 of 25 Old 04-15-2019, 03:38 PM
Yes, if your gauge's don't illuminate with the headlights on, the display in the overhead console will not illuminate. The overhead console display should also illuminate with the headlights off though. But the gauge lighting and the display illumination in the overhead console get their power from the same place (that ILLUM fuse) so the issue is probably one in the same, and yes the problem could be the dimmer switch
post #16 of 25 Old 04-15-2019, 05:21 PM Thread Starter
Okay so driving today I noticed my overhead console was on even without the sensor installed but than later it would turn off and than would turn back on so I’m guessing it’s a connection issue so where would I start to look for looked connection for the overhead console?
post #17 of 25 Old 04-16-2019, 01:44 AM
BravadaX's Avatar
What kinda truck are we dealing with here? I see in the picture it’s a Generic Made Chevrolet without the grille. What configuration is this truck/suv?..crew cab? Xcab? Jimmy?
BravadaX is offline
post #18 of 25 Old 04-16-2019, 04:08 AM Thread Starter
Just bought a new headlight switch guys gonna install it and see if that will help the overhead console
post #19 of 25 Old 04-16-2019, 07:12 AM
If it's intermittently turning on and off by itself, more than likely the unit itself is bad, You could take it out and check all the solder joints on the board with a magnifying glass.
post #20 of 25 Old 04-16-2019, 01:39 PM Thread Starter
Hey sorry still new this forum things but it’s a 2003 gmc Sonoma crew cab 4x4
post #21 of 25 Old 04-16-2019, 01:40 PM Thread Starter
So would that mean I would have to take down the whole over head console? Or can I just pull out the overhead display?
post #22 of 25 Old 04-16-2019, 02:13 PM
BravadaX's Avatar
Hey sorry still new this forum things but itís a 2003 gmc Sonoma crew cab 4x4
Alright,makes more sense. Those overhead consoles are only on blazers&crews. I pretty much group them together as a subspecies of each other...electronically a crew cab is actually just a 4x4 blazer with a bed...they share the same harnesses&modules...ride pretty much the same too.
BravadaX is offline
post #23 of 25 Old 04-16-2019, 04:10 PM Thread Starter
Alright,makes more sense. Those overhead consoles are only on blazers&crews. I pretty much group them together as a subspecies of each other...electronically a crew cab is actually just a 4x4 blazer with a bed...they share the same harnesses&modules...ride pretty much the same too.<img src="https://www.s10forum.com/forum/images/smilies/laughing.gif" border="0" alt="" title="lol" class="inlineimg" />
Oh I see that’s good to know yeah sorry dude still new to these vehicles and this is my first truck project so I still have a lot for learn but yeah so do these overhead console go bad after a while or maybe it might be loose connection I realized I didn’t have a sensor plugged in so I guess I need to get a new one
post #24 of 25 Old 04-17-2019, 09:22 PM
leoman924's Avatar
User is: leoman924 is offline
could it be this. Mine is a crew cab as well
http://forums.s-10crewcab.net/viewtopic.php?f=12&t=8718
2017 Hyundai Elantra: Daily Driver
2002 Sonoma Crew Cab V8: Build Thread
post #25 of 25 Old 04-18-2019, 03:10 AM Thread Starter
So guys I put in a new headlight switch and I think it solved the problem of my overhead console going off and on been driving it for a while and seemed that the overhead console didn’t turn off and on it just stayed constantly on I’m not to sure why it works now after putting in the new switch but oh wells main thing it’s works. Now just got to install the new outside temp sensor lol
Similar Threads
97 4.3 Spark Plug Question Andhonor 262ci Forum (4.3) 4 04-07-2017 07:44 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto RockAuto 0 01-12-2017 01:54 PM
help pulling plug on head ?? blazed2 262ci Forum (4.3) 7 05-25-2016 10:25 AM
