Sway bars - S-10 Forum
post #1 of 12 Old 04-13-2019, 05:36 PM Thread Starter
User is: superj is offline
Sway bars
Do these trucks have rear sway bars from the factory? Even the 4 cylinder single cab trucks?
I just got this truck last night and wnjoy the fact that it has a solid ride, like a truck should have. It doesn't ride like a soft car
the joys of living on the ocean, sun, ocean breezes, non-stop rust
superj is offline
post #2 of 12 Old 04-13-2019, 09:33 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Sway bars
Any ZQ8 truck should have the rear sway bar.
Apple Red 96 SS
post #3 of 12 Old 04-13-2019, 11:27 PM Thread Starter
And thst zq8 is a code somewhere on the sticker in the glove box?
superj is offline
post #4 of 12 Old 04-14-2019, 12:04 AM
B4U Task Force
Re: Sway bars
It is...if it's a ZQ8 equipped truck. Assuming the glovebox door hasn't been swapped.
Apple Red 96 SS
post #5 of 12 Old 04-14-2019, 08:11 AM
Racer-X's Avatar
User is: Racer-X is online now
Re: Sway bars
ZQ8 = "Chassis Package, Sport"
Yes, that's a RPO code that will show on the SPIDS in the glove box. Tip: Sometimes it's easier to take a picture of the sticker with your phone and read the sticker than it is to read the sticker, especially if the sticker is stuck on the back of the floor of the glove box like many are.
ZQ8 package on the S10/Sonoma included a rear stabilizer bar (borrowed from the 4 door blazers) with bolted on brackets for the end links to attach to the frame, 16" wheels and tires, slightly stiffer, slightly lower springs and a quicker ratio steering gear box. From the factory, that was a complete package, either the truck got all of that (with the ZQ8 on the sticker) or the truck got none of that.
If your truck has fairly stiff rear springs and "rides like a truck," but doesn't have ZQ8, it might have the Z85, "chassis package firm ride, high payload." If you have those springs, you probably don't want or need a rear stabilizer bar. You've already got more rear stiffness than you can use with most tires, and the truck with Z85 springs leans generally slightly toward oversteer from a handling balance perspective, especially if the bed is empty. A rear bar is going to increase oversteer (in NASCAR terms, it "loosens" the handling), and unless you want to go drifting with your truck, that's probably not a good thing. Z85 springs are more common on 4.3L V6 trucks, but I've seen a few trucks with tutus (2.2L 4 banger) with Z85 springs.
The softer springs are RPO code Z83, "chassis package, solid smooth ride."
Of course, these trucks are all over 15 years old now, so there's always a possibility of previous owner(s) modifying the suspension, springs, shocks and whatever.
post #6 of 12 Old 04-14-2019, 01:50 PM Thread Starter
I got this from the original owner, and it appears totally stock with only 160 something thousand on it. I took a pic od the glove box sticker though so you guys can see it and see if anything wierd pops out but it does have that zq8 code on it, towards the lower set of alpha numeric codes. It does have rear sway bar, a monster size front sway bar, 16 in camaro looking rims, and looks really low.
ID:	316157   Click image for larger version
superj is offline
post #7 of 12 Old 04-14-2019, 03:43 PM
B4U Task Force
Re: Sway bars
I spy ZQ8
Apple Red 96 SS
post #8 of 12 Old 04-15-2019, 09:48 AM
Racer-X's Avatar
Re: Sway bars
Wow. It is a ZQ8 truck. A ZQ8 with a tutu.
I don't think I've seen ZQ8 and LN2 on the same truck before. It makes sense, though. If you can't accelerate quickly, better not to slow down as much for the twisty bits of road.
Read my post above, you got a lot of nifty suspension/steering stuff on that truck, including the rear sway bar and the wheels.
post #9 of 12 Old 04-15-2019, 09:53 AM
B4U Task Force
Re: Sway bars
There's a lot of Xtremes with the 2.2. They have the ZQ8.
Apple Red 96 SS
post #10 of 12 Old 04-15-2019, 03:53 PM Thread Starter
All i know, is even with the bed rust, i really like this truck. I am trying to find a local truck being parted with the stepside bed and rear bumper so i can try and bring her back to as close to stock looking as possible. I also need to find a hitch that fits with that rear bumper so i can pull my little trailer. This truck will basically just be used to haul my 5x8 trailer to the dump everyonce in a while and haul my bicycle to out of town rides and maybe races (if i can find one that will let me race my bicycle, its not legal according to uci rules)
But having a super cool sport truck will totally match my awesome lightning p-38 recumbent racing bike.
superj is offline
post #11 of 12 Old 04-15-2019, 04:00 PM Thread Starter
One thing i noticed while tracing out those rpo codes is i have a 100amp alternator. I wonder why
superj is offline
post #12 of 12 Old 04-15-2019, 07:10 PM
I'm super serial
manbearpig's Avatar
Re: Sway bars
That's the standard alternator...
Similar Threads
ZQ8 Sway Bars EZA Performance Suspension 18 03-07-2019 04:57 PM
Sway bars Stacyracing33 Performance Suspension 9 02-17-2018 09:19 PM
2000 xtreme sway bars on my 97 4wd Kv5137 S10 / Sonoma 2 01-14-2017 05:26 AM
fs zq8 sway bars txpro1200 Suspension 0 09-17-2016 11:29 AM
torsion bars blazer1993 4wd IFS 1 05-10-2016 09:19 PM
