S10 Fuel Injector types - S-10 Forum
 2Likes
  • 1 Post By BravadaX
post #1 of 9 Old 04-22-2019, 07:14 PM Thread Starter
User is: cjb108 is offline
Does anyone know how important matching the serial numbers on a set of injectors is? I have an S10 that I put used injectors in not paying attention to the serial numbers. Ever since it runs rich. I got a new set of injectors, but only two out of the four worked. So right now I've got injectors with at least three different serial numbers on them. I read somewhere that, when replacing injectors on an S10, it's very important to match the serial numbers due to the different flow rates. Can someone please tell me if this is true or not?
cjb108 is offline
post #2 of 9 Old 04-22-2019, 07:22 PM
I'm super serial
manbearpig's Avatar
Re: S10 Fuel Injector types
Not sure there are serial numbers, but I would match part numbers... I don't think you would want to mix flex and non-flex injectors together for instance, if that's even possible. Never had to change any of mine.
post #3 of 9 Old 04-22-2019, 09:39 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
What year/engine are they going on?
I have Ď96,Ď97,í98,í99,í00 VIN 4
Engines,..í00,01,02 VIN5 engines,and a 03 VIN H engine either in my shop,or in trucks I own..I can look to see whatís in them.
RangerWeaver likes this.
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #4 of 9 Old 04-22-2019, 10:20 PM Thread Starter
It's a 1996 2.2L VIN 4. Is the part no. the number that's printed on the injector itself?
cjb108 is offline
post #5 of 9 Old 04-22-2019, 10:28 PM
oldeerslayer's Avatar
Have you put a scanner on the truck and read all the PID's?
post #6 of 9 Old 04-23-2019, 10:27 PM
BravadaX's Avatar
I got a Ď96 engine sitting on the floor of my shop. Iíll go take a look tomorrow.
BravadaX is offline
post #7 of 9 Old 04-24-2019, 12:54 AM Thread Starter
Yes, I've got a scanner that can read and record live data. I get code P0172(System too rich bank 1) all the time, and P0108 (Manifold Absolute Pressure sensor circuit high)and P01441(EVAP EMISSIONS SYSTEM FLOW DURING NON-PURGE). I read that P0108 can be caused by excessive cranking(which happens all the time due to the rich-running condition).
cjb108 is offline
post #8 of 9 Old 04-24-2019, 08:34 AM
BravadaX's Avatar
Put a purge valve on it. If itís getting a purge during non purge the valve is stuck open,and itís sucking fuel from the evap system. I have a couple of those valves too,lol.
I really need to put these things on eBay. Since S10warehouse doesnít even sell S10 parts anymore Iím the closest thing to what they used to be stock wise
BravadaX is offline
post #9 of 9 Old 05-08-2019, 12:07 AM Thread Starter
Yeah, it does seem like a likely cause. The purge solenoid itself tested out good, so I'm going to check the eecs system again first. Do you have good purge solenoids? What would you charge to get one to me here in San Diego, California? ZIP is 92102 - 2428.
cjb108 is offline
Similar Threads
95 s10 wont start fuel pump wont kick on nickbalazs_ 262ci Forum (4.3) 12 05-01-2018 12:27 AM
2000 fuel line schematic lehawk S10 / Sonoma 1 11-04-2016 01:09 PM
89 s10 2.8 TBI - No power to fuel pump relay David Huff S10 / S15 5 05-24-2016 10:51 AM
