Is this the vacuum line for the canister? - S-10 Forum
post #1 of 8 Old 06-11-2019, 07:12 PM Thread Starter
novisreilly's Avatar
User is: novisreilly is offline
Is this the vacuum line for the canister in the driver's fender / vac line that goes through the fire wall? Or is it for something else? Everything was pretty disintegrated under there and I'm trying to put new hoses on.
Put a fresh hose on it (pictured), has a whole lot of vacuum.
ID:	317469   Click image for larger version
post #2 of 8 Old 06-11-2019, 08:47 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Is this the vacuum line for the canister?
Well....not much detail in tiny pics so we'll just wing it. Assuming it's not 4x4, the vac line goes to a valve that splits between the can and a line that transitions to a hard plastic line that goes thru the firewall by the column.
Apple Red 96 SS
post #3 of 8 Old 06-11-2019, 10:39 PM Thread Starter
I have bad luck with pics on here...this is a pic of how I think it should go (which I think is what you suggest)
post #4 of 8 Old 06-11-2019, 10:40 PM Thread Starter
Also it's a 99 S10 v6 rwd
post #5 of 8 Old 06-11-2019, 11:32 PM
B4U Task Force
It's not bad luck, it's how you post your pics. If you use a 3rd party host such as www.postimage.org, you can store you pics in multiple folders, and choose the image you want to post. I choose the Hot Link for Forums. It copies it to your clipboard, paste it in your post and your pics will be full sized.....and it can be done from a phone. It's a couple more steps, but the results are worth it. If you decide to give it a try and have problems...let me know.
Apple Red 96 SS
post #6 of 8 Old 06-12-2019, 07:34 AM
oldeerslayer's Avatar
Vacuum lines look OK.
Here's a Postimage pic.
post #7 of 8 Old 06-12-2019, 08:44 AM Thread Starter
Thanks for the tips on pics and for taking a look. To clarify, the vacuum comes straight from the engine and is split into those two hoses? Not through any switches or solenoids etc. first?
post #8 of 8 Old 06-12-2019, 08:47 AM
B4U Task Force
Correct.
Apple Red 96 SS
