HVAC Fan issue - S-10 Forum
post #1 of 5 Old 07-13-2017, 10:44 PM Thread Starter
01S10 Owner
mrwiz's Avatar
User is: mrwiz is offline
HVAC Fan issue
Ok... I'm officially stumped and would appreciate any suggestions. It's a 2001 S10 2.2L LS. Manual HVAC controls.
The AC is working great in this hot Atlanta weather... but the fan refuses to operate at all when I move the fan speed selector to position "4"... high speed. Positions 1-3 operate as expected. But, turn it to position 4 and the fan simply dies.
Now, the odd thing is that this only happens when the AC is on. If I turn the mode selector to anything other than AC or MaxAC... the fan blasts fine in position 4.
What's even more odd (to me) is that if I select a non-AC mode and flip the fan to position 4... the fan revs up as it should... and if I then change the mode switch to AC or MaxAC the fan continues to run at full speed and stays running as expected in position 4. If I then flip the speed selector to any other fan speed position and then try to go back to high speed... it won't work.
So... the fan dies and won't run at all in position 4 as long as the mode switch is in an AC mode... but runs fine at position 4 high speed in any other mode... and continues to rin at high speed in AC mode once it's started at high speed from a non-AC mode... and won't go back to running at high speed when in AC mode if I turn it down and then try to turn it back up.
I'm open to any and all ideas.
Thanks in advance!
Now, the o
mrwiz is offline
post #2 of 5 Old 07-14-2017, 10:20 AM
Post Whore
chevymec's Avatar
User is: chevymec is offline
I would say to check the high speed relay and the resistor.
chevymec is offline
post #3 of 5 Old 07-18-2017, 11:20 AM Thread Starter
01S10 Owner
mrwiz's Avatar
Dumb question probably... but where exactly is the high speed relay? I can't seem to find any references to it anywhere.
mrwiz is offline
post #4 of 5 Old 07-18-2017, 12:27 PM
User is: Century7667 is offline
Re: HVAC Fan issue
Typically they are in the vicinity of the evaporator core box in the engine bay. Pretty easy to get to. Not sure on the S10 though.
Ken T.
post #5 of 5 Old 03-14-2018, 10:29 AM Thread Starter
01S10 Owner
mrwiz's Avatar
Changed the relay. Same problem. Any other ideas? I’m gonna try to trace the circuit this weekend.
Is everyone crazy... or is it just me?
mrwiz is offline
