Trouble turning key far enough to engage starter. - S-10 Forum
 1Likes
  • 1 Post By click
post #1 of 26 Old 05-24-2019, 11:30 PM Thread Starter
Old New Member
User is: aaarrg is offline
--I had to rejoin the site because I am too stupid to remember what e-mail or user name I was using before.
For the last 10 years I have had to use more and more force turning the key far enough to engage the starter of this poor old farm use truck.
It didn't bother me so much because it kept most others from using it.
Now I am the only one with the strength to turn it hard enough to start it and it is starting to take every thing
I can give it to get the starter to engage.
--I have to fix it before my wife figures out how to use a pair of vise grips to turn it and break the key off or something.
Because of some vision problems that I am getting taken care of, I am having trouble navigating to a thread that deals with replacing the parts, what parts I should replace and how to remove the steering wheel etc.
--I am sure it has been discussed before.
If somebody would be so kind as to steer me towards a thread discussing this issue for this 1984 tough truck I would really appreciate it since I assume it involves pulling the steering wheel etc.
If not, just call me lazy and tell me to look the info up myself (I deserve it).
Thanks for your time.
1984 Chevy S-10 Tahoe 5sp 4wd 2.8L 6C
Old Blue- The Wonder Truck
aaarrg is offline
post #2 of 26 Old 05-25-2019, 12:29 AM
B4U Task Force
Rhotpursuit's Avatar
Re: Trouble turning key far enough to engage starter.
The actual switch is on the lower part of the column. Remove the knee bolsters and take a look....can't miss it. You can turn the key and see the rod move. This may be a simple fix. Looses the screws that hold the switch in and slide it towards the top of the column. It won't move much...doesn't take much.
Apple Red 96 SS
post #3 of 26 Old 05-25-2019, 10:03 AM Thread Starter
Old New Member
Thank you very much for the info. I will check it out. I assumed I would have to rip a bunch of stuff apart. I might luck out. Thanks again.
aaarrg is offline
post #4 of 26 Old 05-25-2019, 10:19 AM
B4U Task Force
Check back in and let us know what you found.
Apple Red 96 SS
post #5 of 26 Old 05-25-2019, 01:06 PM
JAD
JAD's Avatar
User is: JAD is offline
Pics to show the stuff
ID:	317027   Click image for larger version
1991 Sonoma ST xCab 4.3Z 700R4 350,000+ OD
JAD is offline
post #6 of 26 Old 05-25-2019, 01:59 PM
B4U Task Force
^^^Score!!
Apple Red 96 SS
post #7 of 26 Old 05-25-2019, 05:24 PM Thread Starter
Old New Member
THANK YOU for your help and time.
Thank you both Rhotpursuit and JAD (thanks for the pictures) and anybody else involved.
It worked!!! But once again I did too much, too fast, didn't pay attention, and don't know what I did.
Reason I am going to spell this out is to see if you can figure out how you guys managed to get me to fix it because I never did see the rod mentioned and didn't do a few other things I thought I would have to.
So here is the run down as I remember it:
Started to get under the dash with some tools.
Moved the steering wheel to a higher position. I didn't even know you could adjust the steering wheel but I pulled the knob on the left side of the column, wiggled it and managed to move the wheel to a much higher position.
Took the four screws and one bolt off of the panel under the dashboard that covers part of the steering column and removed the panel which also has an air vent attached to it which contained a dead lizard.
I than used the socket wrench to try and pound the life out of this big frigging spider that magically appeared. It was one of those wolf jumping spider types that seem to have about 20 eyes.
Almost forgot, I also hit myself in the head with the wrench a couple of times.
I than used half a can of lube spray that is for the tractor that happened to be next to me to try and exterminate the spider also getting some of it in my eyes and hair. I am glad I didn't have a lighter or this could have turned out badly.
The only smart thing I did today was to have blocked the tires and put the truck into neutral because after getting my vision back, for some reason I turned the key lightly and the truck started. Had I left the truck in gear I probably wouldn't be writing this for a couple of more days.
It now continues to start with very little key turning effort which means my wife can now (after 10 years) drive the truck, load it, take it to the burn pile and unload it herself.
The attached pictures are there because I thought I would need to start taking pictures to use as a guide to put the thing together again.
Name:	100_0866 (Medium).jpg
ID:	317049   Click image for larger version
Name:	100_0865 (Medium).jpg
ID:	317051   Click image for larger version
Name:	100_0864 (Medium).jpg
ID:	317053   Click image for larger version
Name:	100_0863 (Medium).jpg
ID:	317055   Click image for larger version
Name:	100_0862 (Medium).jpg
aaarrg is offline
post #8 of 26 Old 05-25-2019, 05:59 PM
B4U Task Force
The important thing is you killed the spider.
Apple Red 96 SS
post #9 of 26 Old 05-25-2019, 08:46 PM
the new guy
superj's Avatar
User is: superj is offline
That's a funny tale, ha ha ha. At least the truck is going again, ha ha ha
the joys of living on the ocean. sun, ocean breezes, non-stop rust
superj is offline
post #10 of 26 Old 05-26-2019, 05:21 PM
User is: Shannon1241 is offline
Your problem was the position of the tilt was binding the rod against something and when you moved the tilt it freed up the binding, you can try moving the wheel in every tilt position and see if it's hard to turn the key
Sent from my HTC One_M8 using Tapatalk
post #11 of 26 Old 05-26-2019, 05:43 PM
B4U Task Force
I find it hard to think it was the cause. My '85 Blazer started in any position...same with the SS & Blazer2.
Apple Red 96 SS
post #12 of 26 Old 05-26-2019, 05:51 PM
It's not supposed to be a problem, it should start in any position without any issues, but I had a Silverado once that had this same problem in the downward position it wouldn't hardly turn but I could tilt it up and it would turn easily but it turned out my tilt joint was bad wore out once I replaced it then the problem was fixed, however op could have some other issues I just think something was binding his rod because he didn't do anything but moved his tilt column and now it turns free
post #13 of 26 Old 05-26-2019, 05:54 PM Thread Starter
Old New Member
I bet you are correct in a way.
The key doesn't actually turn any easier now but it doesn't need to be turned as far (ie as far as it would go and than some).
Since I emptied half a can of spray lube chasing the spider I than used more of the spray on the tilt knob, wiper switch and anything else that hadn't been moved in years.
Also pounding on the exposed column with the socket wrench trying to get the spider may have moved something just enough to make it all better.
Main thing is it is working fine again since we use that truck for everything including pull starting the Ford 2N tractor with the cutter on it.
Thanks again guys.
aaarrg is offline
post #14 of 26 Old 05-26-2019, 09:54 PM Thread Starter
Old New Member
JAD and Rhotpursuit
Because it is working good I am not going to mess with it anymore. I thank you guys again for the picture and help.
I was wondering if the red arrow that JAD has pointing to #80 is the part I should adjust/replace if it goes wonky on me again.
Crud, I am too stupid to be able to repost your picture and am not able to post the picture of the switch I think you are pointing at.
Instead I am posting a link to https://www.oreillyauto.com/shop/b/l...Attr_10072=Yes
OK!!! Grrrrrr If I am never heard from again it is becuase I blew a head gasket (my brain) from trying to post/repost the dang thing again.
Still cant get the part number and picture to come up. I may wind up spraying this computer with lube stuff to get rid of any bugs it has in it.
aaarrg is offline
post #15 of 26 Old 05-26-2019, 11:42 PM
the new guy
superj's Avatar
Talking about spiders... When driving to feed my brother in laws dogs (they are in Conan this weekend), my wife comments on the HUGE spider that was in the street.
I turn the car around to look and its a tarantula, a baby though. I jump out to grab him and my wife is screaming he is not riding in her car and I better not bring that spider back to the car.
So, I scoot him across the road and make sure he is not going to get run over but man, I sure wanted to take him home for the kids to see.
Tarantulas are very common here in south texas, as are wolf spiders that are four inches across.
Anyways, i attached a pic for you with my hand near him so you can see how small he is.
superj is offline
post #16 of 26 Old 05-26-2019, 11:58 PM
the new guy
superj's Avatar
Concan, not stupid conan
superj is offline
post #17 of 26 Old 05-27-2019, 12:08 AM
B4U Task Force
Me vs spider...
Apple Red 96 SS
post #18 of 26 Old 05-27-2019, 06:15 AM Thread Starter
Old New Member
Small!! Its still bigger than I like.
Though now I am trying to imagine if I want baby Tarantulas crawling on me or the bigger ones.
We did have a tarantula living under our Travel Trailer where we were camped in Februray in the big river area.
It was cold enough that it was barely moving but it could somehow detect the heat from the campfire from 15 feet away.
When it got warmed up enough it became way too fast for me and was no longer fun to watch.
aaarrg is offline
post #19 of 26 Old 05-27-2019, 06:23 AM Thread Starter
Old New Member
Originally Posted by superj View Post
I attached a pic for you with my hand near him so you can see how small
aaarrg is offline
post #20 of 26 Old 05-27-2019, 06:26 AM Thread Starter
Old New Member
Me vs spider...
LOL!
I have to share that one with a couple of people. Its great.
aaarrg is offline
post #21 of 26 Old 05-27-2019, 11:51 AM
JAD
JAD's Avatar
JAD and Rhotpursuit
It is the 80# this is the electrical switch (r n run start) that does get loose on the column or falling apart. The rod runs all the way down the column. The next to the other is the dim switch with yet another rod.
JAD is offline
post #22 of 26 Old 05-27-2019, 01:13 PM Thread Starter
Old New Member
Those parts are cheap if I wind up needing them. Thanks again.
aaarrg is offline
post #23 of 26 Old 05-27-2019, 06:55 PM
User is: ericknight is offline
If it's just a farm use truck you can take the switch off the column and let it hang, then start it with a small torx screwdriver in the slot where the rod went. I had to do that on my 85 for a while, the geared rack that the key cylinder turns broke and I couldn't start it, it's my daily driver so had to do something quick. You can still use the key to lock the wheel.
post #24 of 26 Old 05-28-2019, 12:03 AM Thread Starter
Old New Member
Originally Posted by ericknight View Post
I You can still use the key to lock the wheel.
Thanks for the info. Luckily the ignition key, column lock and everything seems to be working great now thanks to the spider lubricant but its good to know I have options.
aaarrg is offline
post #25 of 26 Old 05-29-2019, 10:56 PM
click's Avatar
User is: click is offline
Funny story, but glad you didn't get hurt fighting that spider. Also, I named a beer Blow a Head Gasket one time. But it all really comes down to: The key problem was the fault of the spider being in the column. Once gone, your key works.
aaarrg likes this.
click is offline
post #26 of 26 Old 06-06-2019, 09:49 PM
User is: crice63 is offline
Any responsible lizard would have eaten the spider, but apparently the spider struck first.
Great story. I’m afraid you may have missed your true calling—comic writer. I eagerly await the next installment.
I’ve seen the tilt position bind the starter rod but when the tilt is loose. Look for that to be the next problem to ignore until it gets unbearable. Judging from some I’ve seen in the jy, that will be several more years.
Dead Lizard is a good band name. Dead Lizard in the Vent could be the first album.
1985 GMC S-15 / 2.8L / Auto
crice63 is offline
Similar Threads
Key Switch Housing Problem makthemo S10 / Sonoma 1 05-22-2018 08:05 PM
1999 S10 Starter Problems 21mbald1999 Electrical / Lighting 7 06-19-2017 02:10 PM
Starter going nuts and dash turning off. aguy 2.2L - 2nd gen 4-banging 15 01-18-2017 03:07 AM
