Air Dam replacement - S-10 Forum
post #1 of 4 Old 05-27-2016, 12:16 PM Thread Starter
User is: mbsz53 is offline
Air Dam replacement
I have a 1983 S10. Before getting into the job I thought replacing the air dam would just be a half dozen screws connected to the bumper. Now it appears the entire from bumper needs to come of because the air dam is sandwiched between the bumper and frame. Removing the bumper looks difficult with minimal clearance to work a wrench.
Does the bumper have to be removed to replace the plastic air dam? Is it difficult to remove the front bumper without air tools? Any advice or experienced input is greatly appreciated. Thank you.
mbsz53 is offline
post #2 of 4 Old 05-28-2016, 07:55 PM
Dukedkt442's Avatar
User is: Dukedkt442 is offline
No, you definitely don't need air tools.
I've had my front bumper off twice and definitely don't remember the plastic air damn being sandwiched between it and the frame.
Pulling the bumper off was incredibly quick and easy, I really don't know what "tight space" you're referring to. I didn't even have my front end jacked up, and mine's a 2WD.
post #3 of 4 Old 05-28-2016, 10:26 PM
Blazin_Jason's Avatar
User is: Blazin_Jason is offline
Re: Air Dam replacement
Depending on which air dam it is, it can be between the bumper and frame. Pull the grill, headlight surrounds, then the bumper filler. Makes it a lot easier to get access and loosen the bumper up enough to get the plastic out.
85 Blazer 4x4, 350, 3" BL, 33's, project
89 Jimmy 4x4, 4.3-->5.7 project
90 Jimmy 4x4, 4.3, DD, 2" BL 31's
post #4 of 4 Old 05-29-2016, 12:10 AM
Rubber Cooker: Revisited
JChapoton's Avatar
User is: JChapoton is offline
Fog light air dam mounts directly to the bottom of the bumper. The no fog light air dam mounts directly over the bottom lip of the bumper.
Originally Posted by WhiteXtremeSdime View Post
"No officer. I did not kill that man. I aborted his ignorant ass of the planet."
Originally Posted by drivewaydime View Post
pee in her butt
trust me...she won't mention marriage again
Originally Posted by brakenit View Post
your opinion is worth the same as what I flushed 10 minutes ago.
