83 S15 tie down rings?? - S-10 Forum
post #1 of 10 Old 04-15-2019, 09:57 PM Thread Starter
User is: Cisneroz209 is offline
Where can I find these same ones? Junkyard? Online? Can't find them on eBay.
Thanks
post #2 of 10 Old 04-15-2019, 10:16 PM
B4U Task Force
Rhotpursuit's Avatar
Re: 83 S15 tie down rings??
Truck or Blazer?? J/Y is probably your best bet.
Apple Red 96 SS
post #3 of 10 Old 04-16-2019, 01:44 AM Thread Starter
post #4 of 10 Old 04-16-2019, 01:45 AM Thread Starter
Truck
post #5 of 10 Old 04-16-2019, 02:27 AM
B4U Task Force
I've seen those before...always thought they were aftermarket.
Apple Red 96 SS
post #6 of 10 Old 04-16-2019, 07:13 AM
Been there Done it
oldeerslayer's Avatar
Agree. Those aren't anything GM made.
They look like cast potmetal. Gm wouldn't risk the product liability chances on something that prone to failure.
post #7 of 10 Old 04-16-2019, 10:49 AM Thread Starter
Well only one is broken but thanks.
I'll check the salvage yards to see if I can get lucky.
post #8 of 10 Old 04-16-2019, 11:29 AM
Old Fart
goes2fast's Avatar
User is: goes2fast is offline
If you are talking about tie downs for the bed, I add aircraft cargo tie downs to my trucks for additional tie downs in convienient spots in the bed. They work great because the ring is removable so it's not in the way when not in use. I know they don't look very sturdy, but they are quite strong and light, when mounted properly, the FAA does not allow junk. When I was working I could get them for free too!
Too Much Horsepower is ALMOST ENOUGH!
"I have a car-sickness. I need to be checked into the HENRY Ford Clinic." -Tim "The Tool Man" Taylor
post #9 of 10 Old 04-16-2019, 11:46 PM
Been there Done it
Since they are FAA approved, I bet they cost somebody a bunch of money.
post #10 of 10 Old 04-17-2019, 12:29 AM
B4U Task Force
A whole boatload of money. We used them on our aircraft, albeit a larger size. The regular container flip-up locks were about $1500 each.
Apple Red 96 SS
Similar Threads
Trouble fitting new tie rod ends wideopenplain S10 / S15 2 06-02-2018 02:14 PM
Upgrade tie rod ends? dcefiacsjr Steering & General Suspension 2 04-14-2018 11:04 AM
New s15 guy here 1984 s15 build bigtmoney S10 / S15 9 09-19-2017 01:40 PM
Tie down rings location 96 sonoma Eran Kaufman S10 / Sonoma 1 09-04-2016 03:32 PM
Tie rod sleeves loose. etaomicron Steering & General Suspension 5 06-17-2016 02:39 AM
You may post new threads
You may post replies
