SBC swap with t5 transmission clutch disc issue - S-10 Forum
post #1 of 5 Old 04-15-2019, 05:00 PM Thread Starter
White_1st_gen's Avatar
User is: White_1st_gen is offline
So im doing a 350 swap in my 84 s10 and I am using a t5 for the transmission, I've got the spacer between the bellhousing and the transmission and I'm going to make a custom slave cylinder mount, but I need to figure out the clutch disc situation. I know that it needs to be a 14 spline disc, but I've been having trouble finding one. Ive found one that is for putting a t5 on a flathead Ford that is 10.5 inches, here is the link: https://www.speedwaymotors.com/Flath...iABEgIHOPD_BwE My question is, will this disc work even though it is for a flathead ford clutch? It is the right diameter and it is 14 spline. If it wont work does anybody know of a clutch disc that will? Thanks.
post #2 of 5 Old 04-15-2019, 06:29 PM
B4U Task Force
Rhotpursuit's Avatar
Re: SBC swap with t5 transmission clutch disc issue
You have several threads on basically the same thing...pick one and stick with it. Let me know which one you want to keep and the others are history.
Apple Red 96 SS
post #3 of 5 Old 04-16-2019, 01:50 PM Thread Starter
Well I posted this in the v8 discussion section first and didn't get any replies, so I figured I would post it here in the transmission section to get a reply. I'll keep this thread I guess Haha, I only have the two and I didn't get a reply on the other one.
post #4 of 5 Old 04-16-2019, 03:37 PM
Gears and Differentials
big gear head's Avatar
User is: big gear head is offline
My brother used a Astro van clutch disc for his swap.
'84 S10 4X4 st. cab 3.4 SFI (from a '94 Camaro), T5, 3.73, Lock Right. SOLD
'99 S10 4X4 ex. cab 4.3, NV3500, 3.42, Lock Right. SOLD
'02 S10 4X4 ex. cab 4.3, NV3500, 3.42, Yukon Grizzly Locker.
post #5 of 5 Old 04-22-2019, 05:04 PM Thread Starter
Thanks for the information, I found a clutch disc that is 14 spline for a Chevy astro with the 4.3 v6 that I think I'm going to get.
Similar Threads
S10 V8 noob here - Which is "easier" 1st gen or 2nd gen SBC swap? Stilgar308 V8 Discussion 9 01-13-2019 08:23 PM
Monster Transmission 91sonomast Transmission & Rearend 7 05-14-2018 08:28 PM
2003 S10 ZR2 Manual Swap To Automatic Transmission Zmidkiff1 ZR2 - BlaZeR2 - Highrider 2 08-26-2016 11:46 AM
How to: remove transmission / replace clutch... shimaze Transmission & Rearend 11 06-12-2016 05:26 AM
Transmission Swap in a 1988 S-10 4x4 with 2.8L Engine - HELP! oldcraftsman Transmission & Rearend 0 05-23-2016 01:33 PM
