Need info on trannys - S-10 Forum
post #1 of 3 Old 03-24-2019, 02:25 PM Thread Starter
Gary Wedincamp's Avatar
User is: Gary Wedincamp is offline
Can anyone tell me what tranny this is please? Thank you.
post #2 of 3 Old 03-24-2019, 03:14 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Need info on trannys
A little more info might help. What did it come out of, auto or manual...
Moved to Transmission/Rearend
Apple Red 96 SS
post #3 of 3 Old 03-24-2019, 10:31 PM
oldeerslayer's Avatar
2006 Truck Vin T 5.3L 4WD 6KCD. That could include Silverado, Burb, Tahoe. Full size with a 5.3 and 4wd.
Any other year will interchange from 99-06 as long as it came behind a 5.3 and had 4wd. ie., 9KCD, 0KCD, 1KCD, The first digit is the year..
TC stall speed could vary depending on the weight of the truck, so be sure the tag on the original has the same code as what you're replacing it with. Or it will shift funny. That can be corrected in the tune with HPTuners or EFILive, but it's simpler to just use the correct one. Never reuse a TC if the trans was bad because it will hold many quarts of contaminated and abrasive fluid. Basically will toast a new trans. Also clean the cooler with a trans cooler flush kit.
Welcome to the forum.
Have any S10 questions?
Similar Threads
Wiring Connector Info zumrodrs Electrical / Lighting 1 01-31-2019 11:33 AM
more LS info dime-dozen LSx Discussion 0 05-31-2018 09:07 PM
Little 4.8 info needed Matthewswolf LSx Discussion 4 05-29-2018 09:51 PM
Trolling for Zr2 info ThomCarr ZR2 - BlaZeR2 - Highrider 10 02-03-2018 05:48 PM
Some LS info .... long post!!!! Wkeracing LSx Discussion 3 08-10-2016 05:41 PM
