How to free stuck wiring connectors on 4L60E - S-10 Forum
 2Likes
  • 1 Post By BrandonHall10
  • 1 Post By Racer-X
post #1 of 10 Old 04-20-2019, 01:55 PM Thread Starter
Racer-X's Avatar
User is: Racer-X is online now
I managed to break the outer shells on one of the connectors on Richard's transmission months back when I pulled his engine and transmission. The electrical connections on the transmission were really, really stuck.
What do you guys use to loosen them up. I'm not sure if PB Blaster or a similar penetrating oil would damage the plastic or the rubber seals in the weather pack connectors. Would I be better to use a silicone based spray lube? I wasn't sure if that would "penetrate" into the stuck connections.
I'll be off to the yard this weekend or early next week to try to pick up a pigtail for the connector I broke. I'm hoping I can just push the pins out (I have the pin tools for the weatherpack connectors) and install the connector frame pieces on the wires on Richard's harness now. I'm pretty sure that what I find at the yard will be about as seized up as what was on Richard's transmission, and I'll need to pull them apart without damaging the connector shell parts that I'm trying to reuse. So I'll need to bring some appropriate spray lube to the yard and lube a few of them up while I walk around, then try to grab one without damaging it. I'm just not sure what will be the best to free them up without damaging the plastic outer shells or the rubber seals.
Or are the connectors available as "kits"? Could I just get new parts for this and push the pins on the existing harness into a new connector with fresh rubber seals?
post #2 of 10 Old 04-20-2019, 02:45 PM
BrandonHall10's Avatar
User is: BrandonHall10 is offline
Re: How to free stuck wiring connectors on 4L60E
One word: Heat
1988 RCSB S10 - Stock 2.5/5 speed - Sold
1983 RCSB S10 - Carb'd 4.3/700r4 - Sold
1997 RCSB S10 - LQ4/4L80e swap - In progress
post #3 of 10 Old 04-20-2019, 03:09 PM Thread Starter
Racer-X's Avatar
Hmmmmm, I hadn't considered heat because plastic. But maybe I should try it.
Now, if I could find a heat gun that fits my cordless tools battery packs. Or just us a cigarette lighter at the parts yard as a "mini-torch."
post #4 of 10 Old 04-20-2019, 04:04 PM
You might get away with a small propane torch if you're SUPER careful. It really doesn't take much heat. On a hot day with a warm transmission, they will almost come apart without a struggle.
Very low flame, like a bic lighter, and keep the heat moving. That's what I would try.
Or...
Most of the time when I'm pulling a trans, I will pull the range switch off the trans and leave it with the vehicle still plugged in.
In your case, depending on the cost of the switch, it might be worth cutting the plug pigtails and pulling the switch with plugs. Maybe the junkyard will let you return the switch after safely extracting the plugs in the comfort of your own garage.
There's a couple different ways to skin that cat.
Harley likes this.
post #5 of 10 Old 04-20-2019, 04:32 PM
User is: pmpueo is offline
if you want new parts try these guys. https://www.allelectronics.com/categ...sistant/1.html
pmpueo is offline
post #6 of 10 Old 04-20-2019, 05:51 PM
Harley's Avatar
User is: Harley is offline
This would be my suggestion too. It's a heat activated resin. The connectors are designed to be "stuck" in there from the factory for whatever reason GM had.
Harley is offline
post #7 of 10 Old 04-20-2019, 06:01 PM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is online now
thin bladed putty knife and a set of probe/picks and patience- no torch under a boneyard beast- you don't know what has been split where you are laying.PB is ok as long as you clean it with contact cleaner later.
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
post #8 of 10 Old 04-20-2019, 06:21 PM Thread Starter
Racer-X's Avatar
I'm getting heat, gentle heat, but heat nonetheless as the #1 suggestion.
The plan now is to grab an entire switch with the pigtails attached at a pull-it-yourself yard, work it with heat when I get it home, and use the connector pieces to reassemble the one on the truck now. I've got the "pin pusher" tools and everything I need to disassemble the connectors.
BrandonHall10 likes this.
post #9 of 10 Old 04-20-2019, 08:11 PM
Harley's Avatar
A heat gun won't have to be so gentle with, but definitely be careful with open flames melting the plastic to start with.
Harley is offline
post #10 of 10 Old 04-25-2019, 11:15 PM
User is: dime-dozen is offline
Ive gotten luck a couple times and popped them apart without heat
must have been lucky day
But a little heat never hurts
Similar Threads
2000 S10 2.2l LS Swap wiring JohnstonOctober S10 / Sonoma 1 02-12-2019 03:47 PM
Wiring Connector Info zumrodrs Electrical / Lighting 1 01-31-2019 11:33 AM
1992 4l60 to 1993 4l60e swap Help! jakerbaker V8 Discussion 13 12-02-2018 11:42 PM
4L60E Deep pan trans filter and pan gasket: Free bikerider Misc. 0 11-27-2017 11:35 PM
4l60e wiring question. Will it run? s10slave Transmission & Rearend 7 09-16-2016 06:26 PM
