Help !! What rear end do i have ? I need to order brake parts - S-10 Forum
 4Likes
  • 1 Post By Hoosier Rick
  • 1 Post By Rhotpursuit
  • 2 Post By oldeerslayer
post #1 of 22 Old 05-24-2019, 06:22 PM Thread Starter
User is: boboso21 is offline
Gents, i have a 10 bolt 8.5" posi rear end .... but i dont know what car it came out of. I need to order drums and the whole new springs and stuff and have no idea what to ask for .
Differential going in a 54 bel air . Much appreciated gents .
boboso21 is offline
post #2 of 22 Old 05-24-2019, 06:36 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Help !! What rear end do i have ? I need to order brake parts
Check the top of the tube...can't remember which side. It has stampings on it. GM dealer should be able to decipher. Someone here may be able to also.
BTW...welcome.
Apple Red 96 SS
post #3 of 22 Old 05-24-2019, 08:26 PM Thread Starter
The only numbers i can read are 5822 ??
boboso21 is offline
post #4 of 22 Old 05-24-2019, 08:43 PM
B4U Task Force
Page 24...
https://www.gmheritagecenter.com/doc...rolet-S-10.pdf
Apple Red 96 SS
post #5 of 22 Old 05-24-2019, 10:06 PM
User is: dime-dozen is offline
start with a width
wheel mounting surface to wheel mounting surface
then center of leaf spring to center of leaf spring
post #6 of 22 Old 05-24-2019, 10:36 PM Thread Starter
52.25 backing plate to backingplate . Has to be pre 98 .... drum brakes . Previous owner said s10 ... but this has 8.5 and posi .
boboso21 is offline
post #7 of 22 Old 05-24-2019, 10:54 PM
oldeerslayer's Avatar
The only width dimensions I'm familiar width are wheel mounting surface to WMS.
Those dimensions are:
The 3 original S10 axle widths are:
2wd 54.5"
4wd 59"
ZR2 63"
Since the backing plates are 52.25 I think you can rule out 2wd.
ZR2 is the most common and the 94-97 did have drums.
Not too many regular 4x4's built in those 4 years with the 8.5 except some 4.3 5 speed's.
Most all prior to that were 7.5. I'm sure there were a few exceptions.
post #8 of 22 Old 05-24-2019, 11:45 PM Thread Starter
Ok , thanks . Ill measure tommorow to double check . What year do the 5 spd 4x4s come in . The 4x4s are a common swap with the bel airs .
boboso21 is offline
post #9 of 22 Old 05-25-2019, 08:13 AM
The 5 speed 4x4's were available all years (except real early). It's only the 5 speeds equipped with a 4.3 that got the 8.5 rear and even then it wasn't a sure thing. Usually had to have a towing package or some other indication of possible additional stress. GM was pretty stingy about using the 8.5 and only did it to prevent warranty claims in the heavier duty equipped S10's. Both 2 and 4wd. It was never offered as an available option, so a buyer couldn't order it. Most original buyers didn't know it if they had one. It was when they started showing up in junkyards and guys noticed a few had the 8.5 that this was figured out.
I don't remember seeing any 8.5 in an S10 before 95. So yours is likely 95-97.
That should narrow it down enough to order brake parts, if they are any different than the 7.5. The 8.5 in the S10 has the axle tube diameter reduced down so standard S10 brakes will bolt on to it. Drums are likely the only variant.
post #10 of 22 Old 05-25-2019, 10:22 AM
looking more like its the 4x4 width
but measure as directed to be sure
Im guessing the leaf spring mounts are cut off?
cant see them and you didnt list that measurement.
Novas were very close to that width (just a little wider) and then there was the A body just a little wider too.
then the 2nd gen Firebird/camaro
post #11 of 22 Old 05-25-2019, 12:02 PM
B4U Task Force
Looks like a bulge on the cover for the ring gear...or is it an optical illusion?
Apple Red 96 SS
post #12 of 22 Old 05-25-2019, 02:42 PM Thread Starter
This is a pic of the car when i got it . I cut them off to weld in sping perches .
ID:	317031   Click image for larger version
boboso21 is offline
post #13 of 22 Old 05-25-2019, 03:18 PM
B4U Task Force
Well I'm confused...in your first post you said you didn't know what car it came out of...
Apple Red 96 SS
post #14 of 22 Old 05-25-2019, 03:41 PM Thread Starter
Sorry for the confusion . I bought the car , and this was the setup . The previous owner said " just tack welded the rear to move it around ... i think its from an s10 " so thats all the info i have on it . If that clarifies. Thanks again !!
boboso21 is offline
post #15 of 22 Old 05-27-2019, 03:05 PM Thread Starter
Ok , so i measured and its 59.25 ish from wms to wms . Prob a 4x4 from 94-7 ???
boboso21 is offline
post #16 of 22 Old 05-27-2019, 03:54 PM
B4U Task Force
All of the non ZR2 4x4 are the same no matter what the year.
Apple Red 96 SS
post #17 of 22 Old 05-27-2019, 06:56 PM
looking like a non ZR2 4x4
post #18 of 22 Old 05-27-2019, 10:24 PM Thread Starter
Ok gents , so ask for what year s10 4x4 parts ? Thanks again !!!
boboso21 is offline
post #19 of 22 Old 05-27-2019, 10:29 PM
Registered Hoosier
Hoosier Rick's Avatar
Really, with the exception of the wheel cylinders (a couple of different mounting options), they are all the same.
boboso21 likes this.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #20 of 22 Old 05-27-2019, 11:54 PM
B4U Task Force
If you have the old wheel cylinders, take them in with you. Since they are not disc brakes, I'd start with something pre-98.
Apple Red 96 SS
post #21 of 22 Old 05-28-2019, 08:28 AM
Drum brake 8.5 4wd S10 was only used in 95-96-97.
goes2fast and boboso21 like this.
post #22 of 22 Old 05-28-2019, 12:32 PM Thread Starter
Awesome , Thank you all !!!!!
boboso21 is offline
Similar Threads
4WD 3.42 8.5 disc brake rear end dime-dozen Wanted, to Buy 15 07-15-2018 11:22 AM
whining rear end vincent1972 Transmission & Rearend 4 06-13-2018 02:10 AM
Rear brake light problems gmguy S10 / Sonoma 11 02-28-2018 08:03 AM
Rear End Trudeau89 V8 Discussion 20 01-28-2018 08:52 PM
Rear end swap keystone Transmission & Rearend 17 01-05-2017 09:40 PM
