Fluid recommendation for 4L60E - S-10 Forum
post #1 of 3 Old 04-17-2019, 11:22 AM Thread Starter
Racer-X's Avatar
User is: Racer-X is offline
I'm about to install the engine and transmission back into Richard, my 1997 S10 2WD 4.3L Vortec V6.
I've replaced the torque converter shaft seal at the front, and the rear seal at the back end where the drive shaft yoke goes in. I will also be dropping the pan and replacing the filter and pan. I have done nothing else to this transmission, and it has nearly 250,000 miles on it with no maintenance at all. It might have had the original, factory installed fluid in it (topped up a bit when I replaced the radiator). This will be a complete fill, as I drained both the transmission itself and the torque converter.
Should I just go with Valvoline Dex/Merc fluid https://www.valvoline.com/our-produc...s/dex-merc-atf at $13.97/gallon from a local source? or should I go with the Valvoline MaxLife Synthetic Multi-Vehicle full synthetic fluid https://www.valvoline.com/our-produc...ti-vehicle-atf at $17.97/gallon?
Also should I add Lucas "transmission fix" to the fluid I'm putting in? http://amzn.com/B000ARTZPO It says it "completely stops most seal leaks," and I'm concerned with new fluid going into it after all these years that I'll be cleaning out and unmasking damaged internal seals.
Racer-X is offline
post #2 of 3 Old 04-25-2019, 11:20 PM
User is: dime-dozen is online now
Re: Fluid recommendation for 4L60E
I use max life
I think the last time I bought it was on sale for $12 a gallon
buy at least 3
post #3 of 3 Old 04-26-2019, 09:30 PM
User is: kevinp1335 is offline
Ditto on the Max Life. That's what I put in mine.
94 S10 extended cab, 4.3L, auto
Similar Threads
Simplest fluid flush TranceAmerica Transmission & Rearend 4 02-06-2019 11:47 AM
99 S10 4x4 NV3500 transfer case fluid question semaj07 Transmission & Rearend 2 09-03-2018 10:36 AM
Fluid extraction through dipstick hole TranceAmerica Transmission & Rearend 12 05-07-2018 01:10 PM
Brake fluid reservoir fluid extraction. TranceAmerica Wheels, Tires & Brakes 14 04-18-2018 02:21 PM
1990 4WD S10 Blazer puking trans fluid after a long 4-year sit...? S-TenNoob S10 / S15 3 10-01-2016 06:15 PM
