Clanking sound from rear of truck - S-10 Forum
 5Likes
post #1 of 72 Old 07-07-2019, 02:16 AM Thread Starter
New Member
TranceAmerica's Avatar
User is: TranceAmerica is offline
Hi guys, so I'm trying to figure out why when I go into reverse and I'm going up an incline in Reverse I get a clanking that sounds like it's coming the back of the truck. it seemed to go away when I had less of weight inside the truck but now I'm loaded back up with tools probably four hundred pounds inside my cab . and I just went up a little bit of a incline in reverse and it seems like the clanking increased I wonder what's causing this?
post #2 of 72 Old 07-07-2019, 02:20 AM
B4U Task Force
Rhotpursuit's Avatar
Re: Clanking sound from rear of truck
Clank or ping? I'd check u-joints 1st .Ext cab? Heck all joint in the driveline...trans mount. Are you lowered?
Apple Red 96 SS
post #3 of 72 Old 07-07-2019, 02:27 AM
New Member
Shane Cary's Avatar
User is: Shane Cary is offline
I would start with joints as well. I did have a rear end fail because it had excessive wear on the ring and pinion. It would clank when going into opposite directions ie if I stopped and went into reverse it would clank. When I stopped going in reverse and went forward again it would clank again
post #4 of 72 Old 07-07-2019, 09:33 AM
Gears and Differentials
big gear head's Avatar
User is: big gear head is offline
If you have an extended cab 2WD with the multi piece drive shaft then there are lots of things that can go wrong with it. If you don't find anything wrong with the drive shaft then check the pinion nut to see if it's still tight. Also check the bolts that hold the rear end to the leaf springs.
'84 S10 4X4 st. cab 3.4 SFI (from a '94 Camaro), T5, 3.73, Lock Right. SOLD
'99 S10 4X4 ex. cab 4.3, NV3500, 3.42, Lock Right. SOLD
'02 S10 4X4 ex. cab 4.3, NV3500, 3.42, Yukon Grizzly Locker.
post #5 of 72 Old 07-07-2019, 10:01 AM Thread Starter
New Member
Clank. I checked the u's before and had a couple other people check it too. It's an. Ext cab. Not lowered.
post #6 of 72 Old 07-07-2019, 11:13 AM Thread Starter
New Member
Anyone know the size of the pinion nut off hand?. It's your standard 7.625 rear end stock on a 03 LS
post #7 of 72 Old 07-07-2019, 11:27 AM
1 1/4 inch
goes2fast likes this.
post #8 of 72 Old 07-07-2019, 12:53 PM Thread Starter
New Member
Thanks big gear, I've never tried to tighten the pinion nut before. Is this going to require me to remove the axels and pull the guts out of rear end?
post #9 of 72 Old 07-07-2019, 01:00 PM
B4U Task Force
No need to remove the axles. I doubt that would be your though. Even if it was, you can't just crank on it because of the crush sleeve. Did you check the other items mentioned?
Apple Red 96 SS
post #10 of 72 Old 07-07-2019, 01:08 PM Thread Starter
New Member
Im going to check those now, how do i check the tranny mounts & what size are the leaf spring mount bolts if you know off hand?
post #11 of 72 Old 07-07-2019, 01:10 PM Thread Starter
New Member
What am feeling for with a bad u and how check the whole drive shaft?
post #12 of 72 Old 07-07-2019, 01:19 PM
B4U Task Force
Grab it and try to shake it in different directions...try some back & forth rotational movement also. You can unbolt the tranny mount, use a jack to raise the tranny just enough to remove the mount. If it comes out in pieces...problem solved. The rubber separates from the steel.
Apple Red 96 SS
post #13 of 72 Old 07-07-2019, 01:25 PM Thread Starter
New Member
Ok, thanks Rhot. How much play in each direction and back and forth is considered it needs to be replaced?
post #14 of 72 Old 07-07-2019, 01:37 PM
All you need to do to check the pinion nut is to remove the drive shaft from the rear yoke. It's very common for the pinion nut to back off, but don't tighten it any more than what you are able to do with a common 1/2 inch drive ratchet. Be sure that the truck can not move when you do this. Nobody wants you to get crushed by your truck.
If you feel any loose movement in any of the U joints it's too much.
post #15 of 72 Old 07-07-2019, 02:02 PM
User is: TomA is offline
Make sure your driveshaft splines are greased (if your driveshaft has a slip joint). Sometimes they can stick and release under load, which causes a clanking noise.
TomA is offline
post #16 of 72 Old 07-07-2019, 03:21 PM Thread Starter
New Member
Does this look normal? Ok I have to figure out how remove the shaft from the yoke. How do I grease the splines if I need to is it a zerk grease fitting? Im hearing some clanking inside the tranny housing when i twist it back n forth Thanks
ID:	317997   Click image for larger version
post #17 of 72 Old 07-07-2019, 03:38 PM Thread Starter
New Member
The four bolts that hold the rear end to the leaf springs are tight, the tranny mount seems ok but it has a 1/4" gap on the top, the plastics still rubbery and flexible, I don't want to take out then not have a mount there huh? I see only one zerk fitting on the drive shaft and its been greased not too long ago.
post #18 of 72 Old 07-07-2019, 03:44 PM
B4U Task Force
The back of the driveshaft will have straps or u-bolts holding the joint on. Use a Sharpie to mark the shaft and the yoke so that they can be installed in the same place. It looks like there's a lot of rust residue around the joint. If it's questionable at all, I'd take it in and have the entire d/l serviced. It's not that expensive and will save a lot of grief if the joint blows apart. You can do it yourself, but unless you've done them before, I'd let the pros do it.
When you remove the d/s, pull one of the joint caps off and take a look. I'd bet they are close to dry. At that point...replace all of them.
Apple Red 96 SS
post #19 of 72 Old 07-07-2019, 03:45 PM Thread Starter
New Member
My left rear wheel is really really hard to rotate both ways when I'm off the ground in neutral, the right rear wheel rotates both directions easily.
post #20 of 72 Old 07-07-2019, 04:10 PM Thread Starter
New Member
Hmmm... I took off the brake cover and it spins normally, mega brake powder came out, must've been a locked up brake.but now when put the rear drum cover on its like the rear drums over engaged causing the difficulty rotating, I'm in neutral with no parking brake on, I wonder if this resistance is what's causing the clanking, its a sporadic resistance when rotating the rear right.
post #21 of 72 Old 07-07-2019, 04:25 PM Thread Starter
New Member
I wonder if it's the lip of the drum cover along with brake dust and corrosion that's making it not be able to seat all the way back fully.
post #22 of 72 Old 07-07-2019, 04:44 PM
Someone explain to him how to disassemble the drive shaft. I've only had one of those 2 piece units apart, so I'm not real familiar with them. If I'm not mistaken you can get the shaft out of balance if you don't assemble the splines exactly the same way that they came apart.
post #23 of 72 Old 07-07-2019, 04:53 PM Thread Starter
New Member
That was it. A simple too much dust in the drums and drum covers, from taking the drum covers off and not cleaning them completely water for in and created a build up and they weren't able to fully set back. That must've caused too much resistance in the rear end making it clank. Plus that solved why my ebrake would slowly release and not fully. Thanks all your help.
post #24 of 72 Old 07-07-2019, 04:56 PM
B4U Task Force
Did you grease the contact points on the brake hardware...should do it. There are points on the back of the shoes also. You'll see the rub points when you take the shoes off...or at least pull them away from the backing plate...gently.
Apple Red 96 SS
post #25 of 72 Old 07-07-2019, 05:17 PM Thread Starter
New Member
no I didn't grease those points. I'm going to take both of the covers off again and clean them out with brake parts cleaner and I'll grease them then. What type of Grease do I use high temperature grease for your zerk fittings will that work
post #26 of 72 Old 07-07-2019, 05:19 PM
B4U Task Force
Get some hi-temp brake grease.
Apple Red 96 SS
post #27 of 72 Old 07-07-2019, 05:40 PM Thread Starter
New Member
Ok, thanks Rhot.
post #28 of 72 Old 07-07-2019, 06:50 PM
New Member
User is: dime-dozen is offline
if you ever remove the driveshaft put a line or mark thru everything that comes apart so it can go back the same.
big gear head likes this.
post #29 of 72 Old 07-07-2019, 07:35 PM Thread Starter
New Member
Okay, thanks dime.
post #30 of 72 Old 07-07-2019, 07:37 PM
B4U Task Force
Thought I mentioned that...
Apple Red 96 SS
post #31 of 72 Old 07-08-2019, 12:39 AM
time to get cereal
manbearpig's Avatar
I'm not sure about all 2 piece driveshafts, but on my '01 there is only one way to put it together, no way to mess it up.
post #32 of 72 Old 07-09-2019, 04:01 AM Thread Starter
New Member
It started doing it when backing again a fast rattle though in the rear of the truck but then other times after it wouldn't doing. Seems like I'm getting vibration in sound and feel from the rear or like up to kinda by my seats. It's not likes a shaking violently though it's been doing this for awhile.
post #33 of 72 Old 07-09-2019, 09:09 AM
New Member
Shane Cary's Avatar
Is there a howling sound from the rear?
post #34 of 72 Old 07-09-2019, 11:44 AM Thread Starter
New Member
No not a howl.
post #35 of 72 Old 07-09-2019, 11:52 AM
B4U Task Force
I think you need to check the entire driveline as suggested. If it comes apart at speed...it's going to be a bad day.
Apple Red 96 SS
post #36 of 72 Old 07-09-2019, 12:06 PM
New Member
Shane Cary's Avatar
My friend had bad ujoints in her full size 93 blazer. I kept telling her to replace them. They broke and the driveshaft took out the tranfercase and cracked transmission housing.
Check those ujoints asap. Her blazer clanked for 2 weeks before breaking
post #37 of 72 Old 07-09-2019, 12:36 PM Thread Starter
New Member
Thanks, so any play in the u joints means they're bad right when I twist them it should be completely tight?
post #38 of 72 Old 07-09-2019, 12:51 PM Thread Starter
New Member
No play in all 3 when I'm on the ground and in park, when I'm in neutral lifted off the ground there is.
post #39 of 72 Old 07-09-2019, 12:58 PM
New Member
Shane Cary's Avatar
What happens when you fully apply the brake pedal and switch slowly between drive and reverse and back to drive?
Dont allow vehicle to move when doing that
post #40 of 72 Old 07-09-2019, 01:03 PM Thread Starter
New Member
The truck wants to move a little bit but it doesn't make any clanking or clunking.
post #41 of 72 Old 07-09-2019, 01:07 PM
New Member
Shane Cary's Avatar
Does the movement feel like the entire truck wants to go forward and back or does it feel like the rear is trying to shift sideways?
post #42 of 72 Old 07-09-2019, 01:16 PM Thread Starter
New Member
It feels like the whole truck wants to go forward. It doesn't seem like the rear wants to go sideways but I can't seem to tell. Is there another way to check?
post #43 of 72 Old 07-09-2019, 01:20 PM
New Member
Shane Cary's Avatar
When you checked u joints on the ground did you have 1 hand on opposite sides of the u joints? Try turning the driveshaft in opposite directions at each u joint? I also push and pull driveshaft in opposite directions both up and down and left to right
post #44 of 72 Old 07-09-2019, 01:41 PM Thread Starter
New Member
Yeah did that all tight maybe 1/6"- 1/8" of play at the rear end joint, I think I found what could be doing it though a crack on the top rubber of the drive line mount near the center.
post #45 of 72 Old 07-09-2019, 01:46 PM Thread Starter
New Member
There's a crack in that Mount, is this hard to replace?
post #46 of 72 Old 07-09-2019, 02:01 PM
If you have the truck on the ground and the transmission in park then there is probably a little load on the drive shaft. This will prevent you from feeling any loose movement in the joints. You need to check it with no load on the drive shaft, which means have the transmission in neutral and set the brake so that the truck doesn't run over you.
post #47 of 72 Old 07-09-2019, 02:04 PM Thread Starter
New Member
Thanks big gear, yeah I did that the other day it had all kinds of movement, so any play means there bad?
post #48 of 72 Old 07-09-2019, 04:19 PM
A U joint should be tight, with no movement other than the rotation in the cups that it's supposed to have. If you have any other movement then it's bad.
post #49 of 72 Old 07-11-2019, 02:48 PM Thread Starter
New Member
Thanks big gear, I checked my U-joints off the ground in neutral and they're all tight don't even move it all but when I rotated at the rear end I can hear a little bit of a Clank like the gears are just locking in place or I don't know if that's them wore out and causing the problem and then also I checked the drive shaft that comes into the transmission and I have a little bit of in and out play right there maybe about a half inch or so and then also I have a little bit of clanking right there where the drive shaft goes into the transmission. Is this normal for the have the little bit of Clank in the rear end and where the drive shaft comes out of the transmission and also the In-N-Out play?
post #50 of 72 Old 07-11-2019, 04:25 PM Thread Starter
New Member
I saw that pinion nut you were talking about big gear, I can't tell if it's loose though without taking it apart looks like I had maybe about 3/16 to 1/4 inch of thread showing on the end of the bolt.
You may post new threads
You may post replies
