3-4 Solenoid loose? - S-10 Forum
 1Likes
  • 1 Post By Tranzman
post #1 of 5 Old 05-20-2019, 05:00 PM Thread Starter
User is: Jackhnmcmillin is offline
3-4 Solenoid loose?
Quick post, last year when I bought my truck i serviced the tranny, upon dropping the pan i noticed my 1-2 solenoid (which I was replacing at the time, to fix a hard 1-2 shift) was tightly fit, however my 3-4 was a little loosey goosey, at rhe time, my brother said he thinks thats how its supposed to be. So i stupidly went along with that, now my transmission has always had some odd problems such as slipping 2-3 when its really cold, but shifts fine when it warms up, and delayed shifting especially going up hill ill have the pedal all the way to the floor for a few seconds before it shifts, and if i dont let off the pedal soon enough itll go straight into OD,
Recently I was replacing my int wiring harness when got to looking at it again and it still bugging me
Now ive read that a loose or bad 3-4 solenoid will burn out tour clutch pack, but i figured after a year it would of ate up something, and i drive 6 hours there and back every month for drill, so my old truck is getting some mileage, any thoughts?
post #2 of 5 Old 05-21-2019, 12:37 AM
Randy
Tranzman's Avatar
User is: Tranzman is offline
Re: 3-4 Solenoid loose?
Either the plastic part of solenoid is loose in the metal frame or the o-ring is bad. I have never seen a valve body worn in the bore for the solenoids. The solenoid just pushes in to the bore and is held in by a clip. The whole solenoid can be bought from just about any parts store.
"Most people do not listen with the intent to understand; they listen with the intent to reply."--Ernest Hemingway.
Black 2000 S10 Base 2.2L Flex Current LS10 swap project
Red 2000 Blazer LT 4x4 3.73 SOLD
Red 1998 S10 SS 4.3L Deceased 10/31/2014
Tranzman is offline
post #3 of 5 Old 05-21-2019, 08:41 AM
oldeerslayer's Avatar
Tranzman knows what he is talking about. Heed is advice.
post #4 of 5 Old 05-21-2019, 10:15 AM Thread Starter
Alright looks like I got a project this weekend, also, would that loose solenoid throw any kind of code?
post #5 of 5 Old 05-22-2019, 12:35 AM
Randy
Tranzman's Avatar
No, not any codes if it is functioning. I checked a couple of vb's today. Because they aren't bolted down. A guy might consider it to be loose. The 2-3 solenoid has no springs in the valve line-up. Because of that it will seem looser than the other. The 1-2 solenoid has a pretty stiff spring in the line-up, be careful when/if you pull that clip. I've seen it shoot out of the bore.
Transman304 likes this.
Tranzman is offline
Similar Threads
Loose door handle Tedster S10 / Sonoma 2 04-02-2019 01:23 PM
loose hood latch cable Raney S10 / S15 2 03-07-2018 06:43 PM
EVRV solenoid problems jayyk31 60v6 Forum (2.8/3.4) 1 10-26-2017 08:59 AM
Evap Vent Solenoid Evap Purge Solenoid Brian charlebois S10 / Sonoma 6 07-19-2016 02:13 PM
Tie rod sleeves loose. etaomicron Steering & General Suspension 5 06-17-2016 02:39 AM
